05-27-2021, 10:38 PM | #1 |
Rep 1,729
Blackvue DR900X-2CH Dashcam
Has anyone installed the Blackvue DR900X-2CH Dashcam? Which fuse did you tap in for the MAIN type, where the power is always on, regardless of whether or not the car is running, and ACC-Ignition type, where the power is on when the ignition is on? Is the location of the front fuse box the same as in the G20? Thanks
08-09-2021, 09:30 PM | #2 |
Ryan
41
Rep 77
Does anyone have an answer to this? I'm looking for the same thing.
08-09-2021, 11:03 PM | #3 |
Rep 1,729
I used the Blackvue Battery B-124X for a much easier and cleaner installation. You just need to run the power wire to the front or rear cigarette lighter socket.
08-10-2021, 06:47 AM | #4 |
Ryan
41
Rep 77
Alright so stupid question, do the front and rear camera plug into each other or do you get two battery packs?
08-10-2021, 08:12 AM | #5 |
Rep 2,127
08-10-2021, 09:27 AM | #6 |
Ryan
41
Rep 77
Is there an easy way to do it so you don't see the cable running through the car?
08-10-2021, 10:12 AM | #7 |
Rep 1,729
08-12-2021, 07:25 AM | #8 |
Rep 2,127
08-12-2021, 07:32 AM | #9 |
Ryan
41
Rep 77
Gotcha - I'll look up some vids when doing it, assuming I ever get the car…
08-12-2021, 08:30 AM | #10 |
Rep 2,538
Are use this exact dash camera in all my cars. It works great and you can use a hotspot with it so you can remote into your car and also get notifications of impacts. You need the battery back up unit that they sell for it. You will power the camera so it is on 24/7. The battery backup is for parking mode so you don’t use the car battery.
08-12-2021, 01:21 PM | #11 |
Rep 46
View post on imgur.com View post on imgur.com View post on imgur.com View post on imgur.com If I remembered everything correctly, I used 29 and 70 or 71 |
mzcp2657.00 |
08-13-2021, 09:07 AM | #14 | |
Ryan
41
Rep 77
08-13-2021, 12:10 PM | #15 |
Rep 44
08-13-2021, 01:08 PM | #17 |
Rep 44
08-13-2021, 02:33 PM | #18 |
Rep 1,729
08-13-2021, 02:35 PM | #19 |
Rep 44
I have the B-112 battery pack. It uses the lighter plug as well. I'm gonna try to install it in the trunk.
08-13-2021, 02:41 PM | #20 |
Rep 1,729
Yes it uses the same plug. Should be an easy install. I routed my wires from the headliner to the trunk. Just remove the plastic molding from the doors and route to the Back seat. No need to remove any trim
08-13-2021, 02:42 PM | #21 | |
Rep 44
mzcp2657.00 |
08-14-2021, 12:31 AM | #22 |
Rep 46
Limegrntaln13014.00 |
