      05-14-2021, 09:25 PM   #23
moproblems
Beware of cheap bait!
moproblems's Avatar
709
G20 anti dazzle coding works just fine with Bimmercode on my G82. Did not do the extra coding that requires esysx.
      05-14-2021, 10:47 PM   #24
snareman
snareman's Avatar
Drives: ///M8 & X3 ///M40
Does it create well defined light tunnels?
Retired:
2021 Enzian Blue ///M4 ||| 2018 ///M4 ||| 2017 ///M4 ||| 2014 435i ||| 2009 335i Coupe ||| 2007 335i Coupe
      05-15-2021, 07:28 AM   #25
moproblems
moproblems's Avatar
709
Yes, very much so.
      05-15-2021, 10:01 AM   #26
snareman
snareman's Avatar
Yes, very much so.
Hmm... My 2017 was AMAZING at it, but when I got my 2018 they had changed the light module so it wasn't possible and you just got this half assed attempt by the car to do it. I never really knew if I was pising people off or not where as with the 2017 there were SHARP demarcations of the edge of the light. Ended up just never using the auto high beams on the last one because they were stuck esys coded in that half assed state. I guess I'll have to give it a try since I can easily undo it with Bimmercode
Retired:
      05-15-2021, 10:11 AM   #27
moproblems
moproblems's Avatar
709
I can post what modules I coded when I get home, gotta be fast so the car doesn't time out.
      05-15-2021, 11:40 AM   #28
snareman
snareman's Avatar
Which OBD adaptor are you all using. I've been using the Vgate iCar Wifi. I had a heck of a time getting it connected as opposed to my phone auto connecting to the cars wifi (which I'm not entirely sure I knew I had). The Bimmercode manual says to put the car into diagnostic mode by pressing the start/stop button 3 times which I did and the car said it was in the mode. I was able to code ASD off, but it told me that I couldn't access the lighting and a few other modules with the adapter I was using.
EDIT: I ordered this one as it says it was made for Bimmercode and is Bluetooth so it should be easier to connect Bimmercode OBD adapter
Edit, Edit - this adaptor works perfectly with Bimmercode
Retired:
JTO245274.50
      05-15-2021, 12:43 PM   #29
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Could you please post a screenshot, I can't find ASD off option. Also are you under G20 or X3M? I am using uniscan adapter. Or I may have to get a new adapter.
      05-15-2021, 01:11 PM   #30
snareman
snareman's Avatar
It has its own category labeled "Active Sound Design" and was the only thing in the category. I tried connecting under 4 series, but it didn't seem to like it so I tried again with 3 series (I think that was as specific as it got) and I was able to connect.
Retired:
      05-15-2021, 07:46 PM   #31
KevinGS
Drives: Past 2015 M4, Current 2013 M3
Is the Anti Dazzle with the new Laser LEDs offering the function of changing the direction of each bright light based on the conditions?
      05-15-2021, 09:24 PM   #32
moproblems
moproblems's Avatar
709
It's more of tunneling where instead of the high beams turning on and off it tunnels and moves the beam around to not blind traffic ahead of you or oncoming.
      05-16-2021, 10:07 AM   #33
KevinGS
Niiiice. So glad this is "code-able". I had this coded in my F82, and it was quite impressive.
Thanks!
JTO245274.50
      05-16-2021, 10:49 AM   #34
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Thanks! Finally was able to code.
      05-16-2021, 09:19 PM   #35
Der_Wolf
Der_Wolf's Avatar
Drives: 2021 G82 Comp
Why isn't this dazzle feature available by default? Never heard of it before but sounds cool
|2021 M4 Competition| |2018 M3 Competition| |1994 525i|
///M
      05-16-2021, 09:39 PM   #36
snareman
snareman's Avatar
I believe it's something along the lines of the US government doesn't allow it. Same with the full laser headlights. They have to be crippled for US consumption.
Retired:
      05-17-2021, 11:06 AM   #37
Der_Wolf
Der_Wolf's Avatar
God dammit Obama
///M
aremmell119.50
Buckeyes352.50
      05-17-2021, 11:13 AM   #38
snareman
snareman's Avatar
God dammit Obama
If you need a solution to a problem that doesn't exist just get the government involved and they will come up with an answer.
Retired:
      05-17-2021, 12:24 PM   #39
warcity
warcity's Avatar
Drives: 2021 G82 Manual
Originally Posted by warcity View Post
I've been fiddling with bimmer code and haven't yet been able to figure this out:
- I want the M sport display in my cluster "without" actually being in M sports. I don't want to lose my driver assistance - just want the display
- Lighted M Badge in the seats - I want to keep them on at night (i.e. come in with headlights)
If anyone figures these two out pls let me know.
Everything else works just fine.
Cheers.
+1
Thanks.
Ario
      05-18-2021, 05:04 PM   #40
snareman
snareman's Avatar
OK, so maybe I'm missing it. Where in Bimmercode do I look for the anti-dazzle? I looked under lighting, but didn't see it.
Retired:
      05-18-2021, 07:41 PM   #41
moproblems
moproblems's Avatar
709
Under expert mode only. Sorry I forgot, I'll type out the notes out for you here shortly.
snareman9050.50
JTO245274.50
      05-22-2021, 01:31 PM   #42
Wamion117
Wamion117's Avatar
89
Drives: BMW G82 M4C
Cheers.
Unfortunately the headrests are linked to the welcome lights in the car so if you even can code them on to stay on at night, so will all the welcome lights
As far as I know no one has untethered the two, let me know if you figure it out I want this pretty badly lmao!
Sincerely yours,
The Meat Man
      05-22-2021, 03:00 PM   #43
warcity
warcity's Avatar
Cheers.
Appreciate your input. Will let you know.
Thanks.
Ario
      05-22-2021, 04:33 PM   #44
snareman
snareman's Avatar
Retired:
