04-21-2021, 08:06 PM | #23 |
Rep 82
Initial impression after 1st resonator delete: very little increase in volume( 10% or less) More defined pop and crackle. Zero drone. If you are after more volume I say just do them both.
04-21-2021, 08:10 PM | #24 |
Rep 2,067
04-21-2021, 09:26 PM | #25 | |
Rep 82
04-21-2021, 11:30 PM | #26 | ||
Rep 2,067
04-22-2021, 12:33 AM | #27 |
Rep 3,603
*Speculation here* but I'm assuming that the second resonator has a merge of some sort as both 3 cylinder banks need to be merged at some point and on F8X and F97/8 it happens in the resonator - so just check that when you remove the second one, and be ready to weld in an H or X if needed. I only say this because on S55, not merging the pulses results in an even bigger doo-doo sound than stock... not advisable.
I think deleting the secondary cats will have the biggest impact on volume. There's no sensors on secondary cats on F8X or F97/8, so I assume there's no sensors on G8X.
Current: F80
Prior: F82, F32 |
04-22-2021, 09:21 AM | #28 | |||
Rep 82
04-22-2021, 09:24 AM | #29 | |
Rep 82
RugbyBro7600.50 |
04-24-2021, 02:18 PM | #30 |
Rep 72
Looking forward to hearing some audio once you've dialed it in! Totally agree that the sound from factory is pretty tame
G80 M3, BG 6MT
Chevy Colorado ZR2 718 Cayman S |
05-01-2021, 09:51 AM | #31 |
Rep 257
I removed the primary resonator yesterday. Made a tiny tiny difference. I'm going back to remove secondary res. Agreed. It's quiet. Very quiet. My 2018 M440 was twice as loud.
Thanks.
Ario |
TrentMeister2854.00 |
05-01-2021, 09:56 AM | #32 | |
Rep 2,067
The interior is just really well sound proofed. In my m2c I ran with the back seats down at all times for more volume, maybe give that a shot too. |
05-02-2021, 03:19 PM | #33 | ||
Rep 257
I'm going back for secondary cat delete later this month. Sport plus is much louder than sport. Cold start sounds amazing. I just wish I could have the cold start sound all the time.
Thanks.
Ario |
05-03-2021, 09:43 PM | #34 |
Rep 405
Fwiw, I deleted the secondary cats and resonators from my X3MC via the Eisenmann mid pipe, and the volume difference was immense...
TrentMeister2854.00 mzcp2660.00 |
05-04-2021, 12:01 AM | #35 |
Rep 679
05-04-2021, 06:42 AM | #36 | |
Rep 257
I too want to know - any droning? Thanks for the vid.
Thanks.
Ario |
05-04-2021, 08:14 AM | #37 |
Rep 405
No drone whatsoever. I've gotten a lot of complements from people on the road. If I could pick on it, I would say there is slight rasp in the midrange under heavy throttle. Not bad like the S55, but not buttery smooth like the B58. Overall, I would highly recommend this setup until I see an equal length option come out.
Current: G87 M2 on deposit, 992 Carrera T incoming
Past: 997.2 911 Carrera S, Macan Turbo, G80 M3 Competition, X3M Competition, OG M2, MK6 GTI |
TrentMeister2854.00 ///MeraldCity_G821141.50 |
05-04-2021, 02:02 PM | #38 | |
Rep 10,146
05-04-2021, 02:42 PM | #39 | |
Rep 257
Thanks.
Ario |
05-04-2021, 02:45 PM | #40 | |
Rep 679
There is a company that claims their midpipe is equal length but they are asking $1900 for it LOL. https://valvetronic.com/collections/...m4-g8x-midpipe Last edited by ///MeraldCity_G82; 05-04-2021 at 08:46 PM.. |
05-05-2021, 03:13 AM | #41 | ||
Rep 405
Vic5519240.00 |
05-05-2021, 03:21 AM | #42 | ||
Rep 405
As strange as it may seem, I have a feeling the rasp is related to the OEM muffler more than the mid pipe. The valve operation is somewhat bizarre, and unless you are at WOT before 4-4.5k RPM, the system seems to keep valves partially closed in that range (perhaps for a performance reason?). I think this is the cause of the slight rasp. It's possible the M3/4 have a revised design / software, as us X3M guys have had trouble with the OEM valve operation (rattles).
05-13-2021, 09:03 PM | #43 |
Rep 257
Back with an update:
Primary res was deleted few weeks back 5% sound increase. Secondary cat was deleted today. Much better. 30% sound increase. No droning. Sounds good.
Thanks.
Ario |
M3LISSA784.50 hawaiiracer1275.00 |
05-13-2021, 11:10 PM | #44 |
Eleet Tech
181
Rep 295
