      03-24-2021, 05:33 AM   #1
BrooklynGreyM3
///MFlight Member
BrooklynGreyM3's Avatar
454
Drives: 2022 BMW M3CX G80
Enable Tach on HUD Display?
I just took delivery of my G80 on March 15th. I tried setting up my HUD to display the tachometer. I did this previously in my MX5 and other BMW's that have this capability. However, I found the setting in my HUD options in my G80 but when I switch the configure view to "Sport" instead of "Road", it won't stick or stay in Sport. I even tried driving in M1 and or M2 mode and the HUD still won't display the tachometer. Has anyone else ran into this issue or has gotten this to work?
      03-24-2021, 05:52 AM   #2
bri1042
bri1042's Avatar
5933
Drives: 2021 IOMG M3 6MT
You have to push "M Mode" by the shifter. It changes the gauge cluster and the HUD. It also turns off some of the nannies.
nathanm4683.00
      03-24-2021, 06:49 AM   #3
BrooklynGreyM3
///MFlight Member
454
Good to know. I'll try that later today. Do you know if you can have this setup when you press the M1 or M2 rather than using the M Mode button by the shifter?
      03-24-2021, 08:00 AM   #4
heavyD^2
heavyD^2's Avatar
Drives: X3M Competition
Yes you can configure it to come up with the M1/M2 buttons.
      03-26-2021, 02:59 AM   #5
BrooklynGreyM3
///MFlight Member
454
Pressing the M Mode by the gear shift does indeed display the tachometer within the HUD. However, I still cannot find where I can press M1 or M2 and the HUD will change with these buttons to include the tachometer. I can only enable the tachometer with the HUD if I use the M Mode button down by the gear shift.
Anyone experience this as well or am I just not seeing how to configure this correctly? Thanks in advance for any asssitance.
      03-26-2021, 08:39 AM   #6
Kansr
Drives: BSM M8
I was trying to figure this out to.
      03-26-2021, 02:45 PM   #7
BrooklynGreyM3
///MFlight Member
454
I've tried various ways to do this but I don't think you can
      03-27-2021, 04:51 PM   #8
jimbethesda
jimbethesda's Avatar
Drives: M3 (F80)
Well this sucks. I can currently do that in my F80.
2001 330Ci (sold)
2007 335i (sold)
2008 E90 M3 (sold)
2015 M3 (sold)
2022 G83
      04-14-2021, 09:46 PM   #9
gurns
gurns's Avatar
Drives: 2021 G82 Dravit Grey
I can get the tach (horizontal bar) to show up in the HUD but not the sideways “hockey stick” tach with shift indicators config as shown on pg 168 of the OM. OM does not give instructions how to call that up. Spoke to 2 genius’s and they don’t know either.
      04-24-2021, 03:16 PM   #10
golovko
Drives: 2021 BMW G80 M3C - IOMG/KO
not in the G80 unfortunately, M Mode is the only way to enable “sport” view. you can in the X3M though.
2021 BMW M3 Comp
2021 BMW X3M
2018 BMW M3 - SO/SS ZCP - Gone
2017 BMW X5 40e M-Sport - Gone
2015 BMW M3 - Gone - ED Pickup June 2nd, 2015
      05-02-2021, 11:06 AM   #11
MHOW996
MHOW996's Avatar
307
Drives: 2021 G82 M4, 2022 Ford Bronco
I too have the same challenge. Will try the button next to the shifter. The manual and my BMW Genius indicate that it should be able to switch through pressing the M buttons once you configure it in the set up. So far, no joy.....
      05-02-2021, 11:12 AM   #12
chris3g
Drives: 2023 M3 xdrive
that appears automatically when you approach the rev limit.
gurns48.00
      05-02-2021, 06:08 PM   #13
alz0rz
What goes here?
alz0rz's Avatar
450
Drives: 2019 G30 M550i
Yeah no luck setting it up to change to Sport HUD with M1/M2... seems like a pretty big oversight.
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      10-23-2021, 06:27 PM   #14
LukeM15
LukeM15's Avatar
Drives: M3 G80 Comp Xdrive
I was wondering about this today. Has anyone found a solution? Seems like an oversight from BMW maybe a simple update can solve this.
      10-24-2021, 12:31 PM   #15
madmedman
United Kingdom
275
Drives: G82 M4 Comp
Its still not possible. I have even updated to the latest idrive version and still no way to do this. It's as if BMW wants to keep the m-mode button relevant.
Hope bimmercode will be able to do that soon.
      10-24-2021, 12:36 PM   #16
LukeM15
LukeM15's Avatar
That make sense but sucks having to press that button everytime. I have yet to drive the car with non M view 😂
      12-06-2021, 05:18 PM   #17
madmedman
United Kingdom
275
Drives: G82 M4 Comp
Is this possible yet without pressing the button? There is an option in bimmercode and when I coded it, for a moment I jumped out of my seat when I saw the tachometer on HUD without pressing the m mode button. but restart car and all back to stock again. Huge oversight and this could have been added to the new idrive update
      12-06-2021, 06:12 PM   #18
jimbethesda
Drives: M3 (F80)
I can get the tach (horizontal bar) to show up in the HUD but not the sideways "hockey stick" tach with shift indicators config as shown on pg 168 of the OM. OM does not give instructions how to call that up. Spoke to 2 genius's and they don't know either.
Sounds like you have reduced height on for the HUD. Check to see if you do. If so, uncheck it and see if you get the hockey stick
2001 330Ci (sold)
2007 335i (sold)
2008 E90 M3 (sold)
2015 M3 (sold)
2022 G83
