03-22-2021, 03:52 PM | #72 |
Rep 830
03-22-2021, 05:46 PM | #74 |
Rep 1,413
Is the exhaust burble still same as F80? Or is it eliminated or not noticeable? Personally I don't like it. So for me less to zero would be better.
03-22-2021, 06:42 PM | #75 |
Rep 87
It has a quiet mode that you can set if you want less exhaust sound. Not sure if that reduces the burble (I assume you mean on the downshift) but it is a noticeable difference in volume if you have the damper on.
03-22-2021, 07:14 PM | #76 |
Rep 177
my hellcat had a 16.5 gal tank got 15 mpg full tank was 250 miles 300 sounds great to me
03-22-2021, 07:27 PM | #78 | ||
Rep 143
snareman9071.00 |
03-22-2021, 07:58 PM | #79 |
9071
Rep 7,629
Is there a little spare room to fit an S20/21+?
03-22-2021, 08:16 PM | #80 |
Rep 143
See this pic of my S20+ case in the slot. There's maybe a mm or 2 left or right, meaning if your phone plus case is much taller it won't fit flat.
03-22-2021, 08:20 PM | #81 |
9071
Rep 7,629
Oops. I missed the word Plus on your first post. Thanks for the pic! I have a minimalist case so hopefully I should be fine.
03-22-2021, 10:05 PM | #82 | |||
Rep 2,858
BMW is now using B&W, as Harmon provides the B&W OEM parts, but BMW has never offered the "luxury" stereo in the 3 or 4 series, only 5 series and above, and X5 and above.
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
03-22-2021, 10:27 PM | #83 | ||||
Rep 1,636
Also BMW made the crazy decision that the M4CS didn't need HK for weight savings, LMFAO, but it still sounds better than the base supposedly so nbd I guess. |
03-23-2021, 10:19 AM | #84 |
Rep 87
Just an FYI, but I think that the manual doesn't have the large pad, but rather a bracket in the center console compartment. Not 100% certain since mine is the competition, but think I saw that some place. And i think that bracket isn't as roomy as the tray.
03-23-2021, 10:43 AM | #85 | |
Rep 585
Couple of questions to current owners:
What's the delta between what's shown on the speedo and actual gps verified speed at 80 MPH? What's the rpm at GPS verified 80MPH in top gear? Please include whether it's manual or automatic transmission Thanks. Quote:
EPA lists both current and previous gen at 19mpg combined so there is no difference in range. Expect to fill up every 200-250 miles. |
03-23-2021, 02:22 PM | #86 |
Retired Curmudgeon
2985
Rep 4,047
This is unfortunate.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
03-23-2021, 05:25 PM | #87 | |
Rep 143
03-23-2021, 08:51 PM | #88 |
Rep 585
