      04-11-2024, 09:08 AM   #1
hinckley
hinckley's Avatar
3493
Drives: '24 M4C Conv
Intermittent slow leak in tire??
I know how crazy this sounds, but I have been experiencing an intermittent slow air leak in one of my tires. It's been going on for about six weeks now. Over the course of five days, I'll lose up to 10 psi in the tire. I fill it up with air and then go five or six days without losing any air.
I brought it to a reputable tire shop that I have good experience with, and they couldn't find a leak - from the tire, valve stem or wheel. I've checked tire pressure several different ways and they all match to within a couple psi as is the norm.
This is all crazy to me. I'm going back to the tire shop later today, but I was hoping someone out there may have an idea of what's going on.
CURRENT: '24 M4C Conv
RETIRED : '23 M8C Conv | '20 X4 M40i | '18 M4 6MT | '13 M5 6MT | '08 550i 6MT | '04 545i 6MT | '98 540i 6MT | '94 530i 5MT | '84 528e 5MT
Other retirees from Chevrolet, Buick, Subaru, Honda, Acura, Merkur(!), Volvo, Saab, Audi and Porsche
      04-11-2024, 09:19 AM   #2
Drives: S4
Inflate to 45PSI and dunk the wheel in the kiddie pool. You’ll find it. Chances are good it’s a puncture where a small nail got into the tread and just barely punctured the belts and then got flung out and left behind a very small hole or slit. Have you actually taken the wheel off yourself to look? I had one like this… basically had to poke a hole to patch it, it was that small, but I found it.
Take the wheel off and inspect the tread closely all around the contact patch. If you see any imperfections, spray it with soapy water or a little spit and check for bubbles.
mathys202.50
      04-11-2024, 09:30 AM   #3
hinckley
hinckley's Avatar
3493
Thank you. I have had the wheel taken off (after filling the tire to 45 psi) and dunked in water by a reputable tire store. They couldn't find a leak and were as perplexed as I was. After one attempt, the tech even came out to verify my story and went back to dunk the tire again. He couldn't find a leak on the first or second attempt. I'm going back there later today.
btw, I suspect there's a small finishing nail of some sort in there. But it's been the on-again off-again nature of the leak that's so perplexing. And yes, I know it sounds like I don't know what I'm talking about.
      04-11-2024, 09:46 AM   #4
StreetLethal
Drives: BMW M3 6MT
I have a summer tire like this currently. Inflate to 33, then over a week its down to 27 and holds there. When I swapped to winters I went over the tire with a fine tooth comb and found a broken nail wedged in the depths between the tread blocks. The hole is there, you just haven't found it yet. The pool trick is a good idea, but it may not leak until pressure is applied in just the wrong spot.
hinckley3492.50
      04-11-2024, 10:00 AM   #5
abg80m3
Drives: BMW M3 Competition (G80)
I had something weird happen with my G80 where if I tightened the factory wheel stem cap all the way (finger tight) the tire would start losing air. If I don't tighten the cap all the way my tire holds pressure steady without any issues. Not sure if this is happening with you but you might want to check.
I'm having the dealer look at what's going on with my tire later this week.
hinckley3492.50
      04-11-2024, 10:08 AM   #6
GladiatorOwner
Drives: 22 M4C
Stem
      04-11-2024, 10:55 AM   #7
BEAR-AvHistory-2
BEAR-AvHistory-2's Avatar
297
Drives: BMW Z4 M40, BMW M4C
Expect you did, but did you look inside of the cap to see if anything might touch the valve stem? Otherwise have them replace the whole assembly.
Kevin
Dravit Gray, 503BHP, AWD, Black Leather, Moonlight Roof, Red Calipers.
1965 Cobra Replica
hinckley3492.50
      04-11-2024, 12:21 PM   #8
BryanCO
Drives: E92 M3 997.1 GT3 G80 Manuals
Agree. May not leak until under certain uses, pressures, temps, etc.
hinckley3492.50
      04-13-2024, 08:09 PM   #9
RPM33
Drives: 2020 M2 CS
This happened to me on one of my rear PS Super Sports. Nail in the tire and almost $500 to replace.
      04-14-2024, 09:24 AM   #10
Aalfred
Drives: 2023 M3CX, 2018 X3 M40i
I think the air leak is prob coming from the stem or there is prob a hole thats too small that when its not on the car and under no weight, its sealed and so the water test isnt helping. But once you put it on the car, the weight of the car is able to expand the hole/cut and air starts leaking out. Either ways, if the tire shop doesnt find any issues, have them first replace the valve stem and if that doesnt work then might have to replace the tire or tires depending on the thread dept of the other tire
BimmerFix1390.50
