09-12-2022, 11:45 AM | #46 |
Rep 2,814
Ya, barring a miracle turn around, my SA is probably looking at his first review of not all 10s. I likely won’t be coming back for follow up services either. The communication and resistance to outside suggestions has been frustrating. In 2+ weeks they’ve tried one solution which was basically a software reset. Otherwise the car has been sitting while they wait for another G80 to magically come in to compare to (because there are sooo many cycling through ) or the BMW regional tech to tell them what to do.
09-12-2022, 02:06 PM | #47 | |
Rep 673
Realtor, Architectural Engineering
Remax 200 Realty Winter Park, FL |
09-13-2022, 06:45 PM | #48 | |
Rep 307
Drives: BMW M3 G80
Hey OP , Are you suggesting the issue was never present in 2WD setting ? If so , don't think replacing engine mounts will help lol. |
09-14-2022, 01:29 PM | #49 | |
Rep 2,814
09-14-2022, 02:27 PM | #50 | ||
Rep 307
Drives: BMW M3 G80
09-14-2022, 02:35 PM | #51 | |
Rep 2,814
Based on their course of action and the feedback I’ve received, I truly believe they have no idea what they are doing. They waited an entire weekend doing nothing. I was told “we are hoping for another G80 comes in for service so we can compare. When I asked if there was another one scheduled for service that weekend, I was told “I don’t know. They come in from time to time.” WTF? They also seem to need the regional tech’s permission to go to the restroom. I know our cars are new but the technology surrounding them is not. These guys should be able to use their mechanical knowledge to trouble shoot and figure out the problem without some higher-up’s permission. Ok. Off my soapbox. |
09-15-2022, 09:07 AM | #52 | ||
Rep 673
09-16-2022, 12:00 PM | #56 |
Rep 127
Curious to hear whether you got any feedback or response from your SA about the the SIB and if this might be the cause of your G80's issues? What is the status surrounding the engine mount replacement? It does sound like taking this up a notch or to BMW NA seems like a good step.
09-16-2022, 01:17 PM | #57 | ||
Rep 2,814
Wed: My SA did confirm that he spoke to his "techs" about the SIB and the cooling hose issue you had shared (thank you for that). He said they ruled out the SIB and were going to look into the cooling hose if the mounts did not fix anything. I never received a call back about the test drive after having installed the new engine mounts successfully as I mentioned above. So I concluded that silence = that didn't fix the issue. Thurs: SA texts me to ask if I noticed the issue after the break in service. I said, No..I noticed it a few days after you replaced the wheel that your guys curbed up during my break in service. I then gave him a screen shot of my original text to him informing him of he issue and asking if he thought I needed to bring it in. That was dated Aug 23. I also mentioned that it had been very hot recently before the issue first popped up, 90+ degrees everyday for the past 2 weeks. He responded the we would let the shop forman know. I also asked him once again if they had 100% ruled out a brake problem since a few master techs I have spoken to online think my rotors may have high spots and that it is actually a very common thing with our cars. He confirmed that they ruled out any brake issues. So that is where I am. Still waiting. I have not heard anything today and given their history that tells me I am probably without my car until mid next week.
BMWRacer5232519.00 colo3Kid154.50 |
09-16-2022, 02:14 PM | #58 | |
Rep 127
Very weird that this issue shows up after replacing the wheel THEY curbed?! Did they curb it hard? Maybe not.. but what if? What are the details behind this incident? Have they taken any data of the rotors and showed it to you as proof they have ruled it out? Same thought process for the SIB. I am a firm believer in Trust but Verify. At this point where is their data? |
KANdaddy2501.50 |
09-16-2022, 04:51 PM | #59 | |
Rep 2,814
I have no idea how hard the wheel was curbed. It was the right rear wheel and it did require a realignment. The wheel was scuffed all the way around 3/4 of the wheel's surface. Since this was the rear wheel, I do not think it is related to my current situation. They have not provided any data regarding the brakes. Only told me they thoroughly inspected the system and it checked out.
09-16-2022, 05:27 PM | #60 |
Rep 2,814
OK...here we go. SA just called me and said that they think it is the electronic power steering (EPS) programming. They did do a software update on my car when it was in for the new wheel. They think that is what caused the issue. Because BMW is closed over the weekend, they cannot get the new file from them and load it into my car until Tuesday (the dealer's service center is closed on Monday). He said if the software fix doesn't resolve the issue they will need to look into replacing the entire steering system! I know this happened to the YouTuber, What'sYourForte. I sincerely hope this is not going to be the case for me.
T0RM3NT3685.50 |
09-16-2022, 05:35 PM | #61 | |
Rep 6,991
YT: G Dubyou |
KANdaddy2501.50 |
09-16-2022, 05:37 PM | #62 | |
Rep 2,814
Edit: Just watched one of WYF's vids. It seems like his issue was with the steering wheel not returning to center after making a turn. That is def not the issue I have. But, who knows, it could be related.
Limegrntaln13525.50 T0RM3NT3685.50 |
09-16-2022, 05:41 PM | #63 |
Rep 6,991
Ok, cool. Lets hope.
YT: G Dubyou |
09-16-2022, 05:59 PM | #64 |
Rep 17,386
Man…I can't imagine the frustration you're going through. They sound like clowns at a circus and they're all scratching their heads.
Hang in there…fwiw I enjoy the updates and the side commentary. It just paints the picture so much clearer! I'm coming up on my 10k and I have a vibration/rattle in the drivers dash that I need to have them look at. Always scared of what that's gonna turn into… |
KANdaddy2501.50 |
09-16-2022, 06:20 PM | #65 | |
Rep 2,814
evoi191526.50 BMWRacer5232519.00 |
09-16-2022, 06:34 PM | #66 | ||
Rep 17,386
