      03-10-2024, 09:21 AM   #1
RichardGM4
RichardGM4's Avatar
527
Drives: 2024 G80 M3 CS
Strut Brace Bolt Torque Setting
Asking for someone on another UK-based forum, as the guys in the US seem to know more of this type of technical info!
Anyone know the torque setting of this strut brace bolt?
Current: BMW G80 M3 CS (2024 BSM w/ Bronze/Gold 827M wheels)
- BMW G82 M4 Competition xDrive (2022 TBII w/ Silverstone/Black & M Carbon Pack)
- BMW F82 M4 Competition (2019 BSM w/ Silverstone)
      03-10-2024, 09:42 AM   #2
Hit_Apex
Riding the knock sensor
Hit_Apex's Avatar
2371
Drives: 21 X5MC | 23 M4CSL
2021 BMW X5MC  [0.00]
28NM plus 120 AoR.
https://g80.bimmerpost.com/forums/sh....php?t=1895116
Sonic RR118.50
M4Tejas788.00
      03-11-2024, 02:13 PM   #3
Hit_Apex
Hit_Apex's Avatar
2371
To clarify, that is 1 of 4 M8 bolts that fasten the strut top to the body which is listed as 28NM (~20ft/lbs) and then 120 degrees of additional rotation.
M4Tejas788.00
      03-11-2024, 04:59 PM   #4
christianb5s4
Drives: Built 2001 Audi S4
Thank you for sharing, I did 28nm but didn't know about the 120 degrees additional.
2019 G05 X5 x40i, built 2001 600whp B5 S4.
Limegrntaln13477.50
      03-11-2024, 07:20 PM   #5
USMC_Sam
USMC_Sam's Avatar
180
Drives: '24 M3CX
Seems odd that there would be a spec torque and then a wrench arch torque. I would think its either one or the other.
Limegrntaln13477.50
      03-11-2024, 07:24 PM   #6
Berzerker
I was curious also so I looked it up, here's a random r/askengeineers thread for some insight
https://old.reddit.com/r/AskEngineer...pecifications/
Hit_Apex2370.50
      03-11-2024, 07:54 PM   #7
USMC_Sam
USMC_Sam's Avatar
180
Drives: '24 M3CX
That implies that there is an interference fit that needs to be overcome with tension from torque. I haven't pulled off the tower mount yet so I dont know.
Digging a little deeper into the image, thats a grade 10.9 bolt, which is capable of 48.3 NM (35.6 ft-lbs) trq. Its very likely that it can handle a 28 NM + 120 deg of rotation.
https://www.engineeringtoolbox.com/m...ue-d_2054.html
Hit_Apex2370.50
      03-13-2024, 07:53 PM   #8
forcefed
forcefed's Avatar
Drives: .
Everyone replacing those bolts when removing the strut?
I wonder if its possible to compress the spring with a compressing tool while the strut is still installed and then pull the strut out by undoing the nut on top of the strut, on rwd this is possible without compressing the springs but on xdrive models there's only a bit of room to pull out the whole strut.
      03-13-2024, 08:17 PM   #9
M4Lou
Drives: 21'-x3m40i 23'-m4c 24'-x3mc
I wonder if its possible to compress the spring with a compressing tool while the strut is still installed and then pull the strut out by undoing the nut on top of the strut, on rwd this is possible but on xdrive models there's only a bit of room to pull out the whole strut.
I'm sure BMW wants you to. I loosened/tightened those or similar on M4 and X3M fronts and X3M rears. Did not replace. Very new vehicles.
forcefed2567.00
