      12-28-2023, 05:07 PM   #23
M3coco
Drives: Bmw x3m
I have the valves open all the time (with a valve controller). ASD is completely coded off with bimmercode. There is still a sound difference on the outside 100% when the button is on vs off, with valves permanently open. There is clearly more to it then just pumping in noise and valves.
vmalho2703.50
PVC156.00
      12-29-2023, 05:36 AM   #24
hinckley
hinckley's Avatar
3493
Drives: '24 M4C Conv
I do not believe ASD is ever turned completely off unless it's been coded that way. As an earlier poster stated, BMW wants us to believe that the natural exhaust sound and ASD are the same thing. They barely acknowledge ASD's existence. So if the natural exhaust note is reduced with partially or fully closed flaps, ASD's sound is reduced as well. But there's never no natural exhaust sound, so there's never no ASD exhaust sound (unless it's been coded off).
CURRENT: '24 M4C Conv
RETIRED : '23 M8C Conv | '20 X4 M40i | '18 M4 6MT | '13 M5 6MT | '08 550i 6MT | '04 545i 6MT | '98 540i 6MT | '94 530i 5MT | '84 528e 5MT
Other retirees from Chevrolet, Buick, Subaru, Honda, Acura, Merkur(!), Volvo, Saab, Audi and Porsche
      12-29-2023, 03:26 PM   #25
Kevin234
Drives: 2023 M3 G80
2023 BMW M3  [8.00]
Ahhh dammit!
Instead of ASD off, I was going to say ASD kinda disabled, and I forgot...
      12-30-2023, 12:27 AM   #26
PVC
PVC's Avatar
Drives: 2022 M3 xDrive
Is it a noticeable difference? Have you tried to measure the decibels (maybe using a phone app)?
2022 M3 Competition xDrive
2022 M340i
2018 M3 Competition
2015 335i
      12-30-2023, 07:56 AM   #27
TopJimmy
TopJimmy's Avatar
Drives: 2023 M3 Comp xDrive
I have noticed that even with ASD set to Off using BM3 there is still burbles in sport modes when the exhaust sound button is on. In BM3 I also have burbles set to Off and am running the OTS CSL tune.
      12-30-2023, 08:05 AM   #28
ChrisM4
ChrisM4's Avatar
Drives: 2024 M4 Comp X-Drive
The sound control button changes the exhaust flap operation, quiets ASD and also changes burbles. (Reduces them greatly)
      12-30-2023, 08:37 AM   #29
M3coco
Drives: Bmw x3m
I think so. It's much more burbley when you let off the throttle when you have the button on, vs off.
      12-30-2023, 12:24 PM   #30
jummo
Drives: 2022 M3CX 2023 x1
I'm probably the only one who doesn't find the fake sound objectionable.
If I'm just driving, I leave asd on. But if I am listening to music, I turn it off.
The stereo sounds much better with it turned of, at least to my ear.
natmad667.00
      12-30-2023, 12:33 PM   #31
Mike02z
Mike02z's Avatar
Drives: 2024 BMW M4 Base
2024 BMW M4  [10.00]
2024 BMW M4  [0.00]
Once ASD is coded out you will still get burbles and crackling when removing your foot from the gas. I was looking for something I read a few years ago about why. This is part of the article I found…credit to Justin Creamer, Mechanical Enginner…
“The pipe size of an exhaust exhaust must be optimized for a specific flow rate. This is usually at max RPM and max throttle for high-performance cars. But at idle, the size of the exhaust system is much too large to maintain a constant velocity of the gas for its entire length. This gives you a burbling sound as the exhaust stream has a push-pull effect: some exhaust is pushing out with flow of the engine, some is pulling back as it cools and contracts.
Crackling is the same concept, except more extreme. It happens when you lift the throttle at mid and high RPMs. You have hotter, high velocity exhaust, suddenly followed by cooler, lower velocity gas. The pressure difference between the two crackles while the they equalize. It's a sound that never fails to put a smile on my face!”
      12-31-2023, 01:14 AM   #32
Berzerker
Except...you can turn them off if you press the center console button :P
      12-31-2023, 02:20 AM   #33
TomGorka
Drives: G20, G80 on the way
When I was at the BMW training center the BMW trainer said , that only in Track mode the valves are fully open - because of some noise/volume standards etc
      12-31-2023, 11:14 AM   #34
Prossx
Prossx's Avatar
293
Drives: 21 G82 6MT SPY/YMB
Aren’t Euro noise standards way stricter than US? And BMW designs to that?
15 F80 YMB DCT - retired
14 F30 MSport MG/CR 6MT - retired
      12-31-2023, 12:22 PM   #35
Salex123
Salex123's Avatar
Drives: G80
2024 M3 comp  [0.00]
Originally Posted by Kevin234 View Post
Good info here. Think I finally have a handle on how this thing works.
Question - I assume the "M Sound On/Off" button in the 2023 M3s is the same as "ASD On/Off" button being discussed here?
To summarize (I tried uploading a table to make it easier, but didn't work ):
ASD Button On (same as M Sound On?)
Comfort Mode: ASD On, Valves Closed
Sport Mode: ASD On, Valves Open
Sport + Mode: ASD On, Valves Open
ASD Button Off (same as M Sound Off?)
Comfort Mode: ASD Off, Valves Closed
Sport Mode: ASD Off, Valves Closed
Sport + Mode: ASD Off, Valves Closed
So basically, there is no option to have the exhaust valves open and the fake speaker sound off at the same time, and that's why we need Bimmer Code, correct?
Just to clarify is that engine in sport and comfort or what setting has to be in sport exactly?
      12-31-2023, 07:18 PM   #36
kgelfen360
kgelfen360's Avatar
But how come Porsche doesn’t mind EU sound laws?
      12-31-2023, 10:05 PM   #37
Scott Z
Drives: 2023 M4
On one of my previous M3’s there was an easy way to disconnect a wire or two (perhaps it was a small wiring harness) in the trunk to kill the fake engine noise piped through the speakers.
Is there no such option now?
I’d like the physical exhaust valves open when called for but I hate the fake interior audio.
      01-01-2024, 11:17 AM   #38
christianb5s4
Drives: Built 2001 Audi S4
At least thus far, there's no easy way to do that like pulling fuses on prior generations.
2019 G05 X5 x40i, built 2001 600whp B5 S4.
      01-01-2024, 03:13 PM   #39
Mapper
Mapper's Avatar
Drives: M3 Competition
Which alters timing , AF and valvetrain timing on throttle lift or shift.
      01-01-2024, 03:58 PM   #40
biggripper
biggripper's Avatar
727
Drives: 2024 G80 M3 Comp xDrive
I can’t tell you exactly what the button is fully designed to do but I can tell you my experience with my current setup which is:
1) ASD coded off via bimmercode
2) valves full open with Dahler controller
3) MAD mid pipe
I went through several incremental stages of experimenting with this exhaust system. I started out with the Dahler controller so that I could have full control of the flaps. Then I moved to coding ASD fully off with bimmer code — which when done correctly is pretty obvious because the exhaust is significantly less prominent even when the valves are fully opened with the Dahler unit. Those changes were subtle enough that I was still unable to fully grasp what the hell the button was doing.
Once I installed my MAD mid pipe, the effects of the button were easier to observe and, therefore, much more clear. With a mid pipe, valve controller, and ASD coded off, it is now clear that the button only acts as a toggle switch for burbles.
ASD button on = lots of burbles.
ASD button off = zero burbles.
Personally I am unable to perceive any difference in volume.
CURRENT///G80 M3CX | Isle Of Man Green | Kyalami Orange | Bi-Color 826M Wheels
FORMER ///F80 M3 ZCP | Yas Marina Blue | Black | DCT | Black 666M Wheels
FORMER ///F87 M2C | Alpine White/Orange | DCT | Black 788M Wheels
FORMER ///F87 M2C | Sunset Orange/Orange | 6MT | Black 788M Wheels
FORMER ///F82 M4 | SSII | Full SO | 6MT | Black 437M Wheels
      01-01-2024, 05:19 PM   #41
Berzerker
I'd be inclined to ask for some documentation on where that's detailed
      01-01-2024, 05:55 PM   #42
FloridaM5
FloridaM5's Avatar
Drives: 2021 M3 Comp RWD
  [5.83]
3) MAD mid pipe
Yes, this 100%. Same here.
      03-11-2024, 03:13 PM   #43
G80_Bob
Drives: 23 M3 Xdrive
I would disagree, I have MAD Downpipes, R44 exhaust and ASD codes off. The ASD switch in Sport or Sport Plus mode does add and remove burbles, but the volume of the exhaust is very different when not at WOT.
      03-11-2024, 03:41 PM   #44
Berzerker
Then you don't have ASD fully decoded.
The button does absolutely nothing if you do, it just controls engine timing to add/remove burbles.
