09-28-2020, 11:33 AM | #1 |
Rep 756
G80 Technology Improvements?
The launch of the F8x was surrounded with a blizzard of information about the technology improvements that helped to save weight, improve handling, chassis stiffness, engine responsiveness etc.
e.g. CF driveshafts, directly bolted rear axle/subframe, turbo lag mitigation. It would be great to see a compilation of articles like this for G8x... but I am struggling to find much by way of technical information. (if there's any out there it's buried under mounds of posts about 'aggressive styling' etc.) Would be great to collect some links here! |
09-28-2020, 11:52 AM | #2 |
Rep 270
Ditto to this...
One of the best improvements in the F8X was the inclusion of 3 separate cooling systems. I wonder if the S58 has a similar setup? I also looked at some engine photos, and it didn't look as maintenance friendly w/ the location of various parts.
Sakhir Orange M4||()
09-28-2020, 12:13 PM | #3 |
Rep 634
Drives: f32 430ix & 982 GT4 PDK
Here is some information regarding the engine.
https://g80.bimmerpost.com/forums/sh....php?t=1582884 https://www.bimmerpost.com/goodiesfo...S58-Engine.pdf |
09-28-2020, 12:17 PM | #4 |
Rep 634
And some engine output numbers. About +80whp over S55 like for like tune.
I haven't redlined the tech sheets yet but i'm sure a qualified engineer here can explain the technical technological improvements over the prior gen. I hope the technological improvements atleast somewhat offset the weight gain but we prob won't know until driving reviews and press gets their hands on the car. https://g80.bimmerpost.com/forums/sh....php?t=1760334 |
09-28-2020, 01:16 PM | #5 | |
Rep 756
The engine is one of the things I'm least concerned about (apart from perhaps the power/tq curves below 3000rpm - which perhaps explain some of the X3M "lag" comments) Would love to see similar technical docs for transmission (my #1 priority!), electrical power steering, suspension/chassis, AWD! |
09-28-2020, 02:22 PM | #6 | |
Rep 634
https://www.bimmerpost.com/goodiesfo...te-Vehicle.pdf I don't think they offer the SUVs in manual, but the ZF M8HP76 will be the exact same transmission for the auto. I think the M Xdrive also carries over. |
BMdoubleUTIFUL179.00 |
09-28-2020, 02:37 PM | #7 | |
Rep 1,201
10-03-2020, 06:54 AM | #8 |
General
21105
Rep 20,741
Drives: 2021 911 turbo
There's indeed no new tricks or technology in the S58 over the S55. From what I read, they simply went with the old proven method of lower compression ratio with bigger turbos to increase power through more boost at the expense of a higher boost threshold and more lag.
10-03-2020, 09:03 AM | #9 |
Rep 1,759
It's a clear tell-tale sign that BMW's R&D budget is slipping on the pure internal combustion engine platform. A paradigm shift all the way to Hybrid and pure EV.
The old M is gone. For people who opt AT instead of the 6MT you have now a much wider selection of cars to choose from since one primary ethos of classic BMW M - agility - is virtually non existent in this generation. |
10-03-2020, 09:42 AM | #10 |
Rep 2,577
The Alpina acknowledges the S58 coming out of box is quite laggy, therefore has already done the right thing to it with the B3.
The result is the lag free and more mid range punch, which is more than enough to make up for the top end loss.
Lemania 2320
10-03-2020, 11:22 AM | #11 | ||
Rep 2,554
10-06-2020, 09:51 PM | #13 |
Rep 634
10-06-2020, 10:40 PM | #15 | |
Rep 7,037
10-08-2020, 11:07 AM | #16 | |
Rep 756
Additionally, if you're city driving you're going to have to be really careful not to let the revs bog down below 3k. Again- this is probably not an issue in full auto - but I don't want to drive an M car like that. One of the reasons I drive a DCT in 'manual' mode is so that I can keep the revs where I want them, rather than letting it 'save fuel' for me. I'm also very interested in technological improvements to chassis, suspension and steering, and that is the main reason I started this thread. We know surprisingly little about any of these things right now.... I wonder when the press drives will start happening? |
10-08-2020, 12:03 PM | #17 |
///M Powered for Life
11421
Rep 10,294
I suspect part of the lack of info is the press drives haven't started. We'll get more info soon I hope
Driving an 8 sp manually is a bit annoying but I do it all the time in my X5. I want to select gears myself |
10-08-2020, 01:24 PM | #18 |
Rep 7,037
This was the main issue with our only ZF 8 AT BMW to date, that it upshifted way to early, often two gears to high at city speeds making the car on the border to stutter. It was easy to get around though by driving it in S mode. Our Cayenne with the Asin/Toyota AT has none of that, it’s perfect in normal mode. I’m more curious than concerned to see if BMW allow an M car to behave like that in any mode, especially when the low rpm TQ is non existent... Not really concerned since I’m confident there will be a mode to avoid it but I am curious. This car will be shared between my wife and I much more than the F80 so it will see a lot of auto mode time.
10-21-2020, 07:54 PM | #19 | |
Rep 85
Drives: '18 M2 LBB 6MT| '06 911 C2 6MT
solstice5456.50 |
