09-23-2020, 12:44 PM | #1 |
Rep 2,362
Drives: G87 M2; E92M3 MT&DCT; M3 euro
Why not raise the redline to 7200 RPM for the 6MT?
We know the ZF torque converter is the reason for the maximum 7200 RPM due to gearbox oil cavitation.
Why can't the 6MT spin faster, such as 7600 RPM like the S55?
Pass me if you can.
09-23-2020, 12:47 PM | #2 |
Moderator
7512
Rep 19,368
Because everything comes at a cost, and the product planners concluded that the product would be less successful if the price tag were raised commensurately in accordance with the cost associated of developing a special version of the engine for the manual transmission.
BMoney48.00 |
09-24-2020, 02:53 AM | #3 |
Rep 2,499
I've been theorizing that they would release a higher revving version with the manual version. I guess I was wrong. I don't think it'd require a new version of the engine. It would likely just be an engine tune since I know this engine has a horsepower rating of 473hp @ 5600-7300rpm.
M-terkait209.00 |
09-24-2020, 05:01 AM | #4 |
Rep 1,252
same reason they detune manual -100Nm. I do not understand.
Anyways I'm in for the new experience, I had damaged my N55 in a single trackday and had to go for a used bottom end. this time I'm going for a manual drive as this won't be my daily anyway. I want something more pleasant than every PDK 911 on the road. If I ever need more torque, A tune will probably be done on my car. and also remove the speedlimiter so won't bother with MDrivers Package.
Docrace 6266
09-24-2020, 08:09 AM | #5 |
Rep 2,067
If you look at the s58 technical documents that came out with the x3m, it specifically states that's redline for auto is 7200 and for manual is 7500.
I'm thinking the published 7200 rpm redline for 6mt m3/4 is an error and it's really 7500. Pull up the s58 technical documents and you'll see it says 7500 for 6mt
2020 X3MC
2009 135i: AW/CR Aluminum Trim, 6 speed, M-Sport, Premium, Heated Seats, Ipod, BMW Performance Pedals, BMW Performance SSK, BMW Performance Exhaust, BMW Performance Grills E93 M3 FSB |
09-24-2020, 08:14 AM | #6 | |
Moderator
7512
Rep 19,368
Also, it can't be said with any certainty that the internal components have been spec'd to handle 7600RPM. While it's not likely that the small increase would cause any harm to the engine (for example, if done via an aftermarket tune), it may still be out-of-spec for some rotating assembly or valve train parts. |
09-24-2020, 06:45 PM | #7 | |
Rep 2,362
Pass me if you can.
09-24-2020, 06:53 PM | #8 |
Moderator
7512
Rep 19,368
Compete nonsense. They spent the money to develop the MT car in the first place while their main competitors quit. That's the exact opposite of cost cutting.
Additional note: Sometimes there’s more going on than meets the eye, and this thread was originally locked for a good reason (after removing blatant bashing in order to address the underlying question). Unfortunately, some individuals who have no intention of purchasing the vehicle are taking any opportunity to incessantly troll and disparage it. |
09-24-2020, 06:54 PM | #9 |
Rep 636
Drives: f32 430ix & 982 GT4 PDK
Best buy a Porsche if you really want a high revving manual
09-25-2020, 05:27 PM | #10 | |
Rep 4,254
///M Power
09-25-2020, 07:49 PM | #11 |
Rep 2,362
We'll see if the 6MT is completely "redeveloped" or they are simply reusing what was available in F8x/F1x era. Maximum torque rating (406 ft lbs) is identical, though it makes max power at higher rpm range (1800-5500 vs 2650-6130rpm), so on paper it just appears to be an engine tweak with some hybrid-prep gimmicks.
Pass me if you can.
09-25-2020, 09:43 PM | #12 |
Rep 2,349
They could have kept 550nm all the way to 6500rpm to have the manual make 375kw from 6500rpm to 7200rpm like the 8AT, that would have been a lot of fun I think. What is also interesting is the power drop off showing on the 6MT once you get to 7000rpm whereas the 8AT holds power to 7200rpm (which makes NO sense)
Details in the specs page, the M3 power and torque curve is for the 6MT, the M4 is the 8AT https://www.press.bmwgroup.com/globa...ion-coup%C3%A9
09-25-2020, 10:00 PM | #13 |
Rep 1,759
They need the 6MT for the G87 series so really it’s a cost sharing exercise to have the 6MT in the G80/82.
Without the 6MT in the G87 or the G80/82, bean counters may not approve the business case for a 6MT model. |
Avaley731.00 |
09-26-2020, 01:07 AM | #14 |
I want to drive a Zamboni
1131
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
I disagreed it's all about profit and BMW don't want to spend money on R&D for new MT, still stuck at 6MT where Porsche already moved to 7MT on new 992.There is no MT offer on G series at all, Is BMW heading to the right direction?
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
09-30-2020, 01:20 PM | #15 |
Rep 804
You can get several G series with 6MT including the G20, just not in the US, cause BMW only mates them to the lower tiers (the highest power non-M G series 6MT is the Z4 20i I think).
09-30-2020, 01:34 PM | #16 | |
///M Powered for Life
11480
Rep 10,328
Porsche puts their 6 speeds in their GT cars, no 7 speeds there. There is no 7 speed in cars that brings the driving experience forward. The one in the C7 Vette is also garbage I'm happy BMW has stuck with the 6MT that works well and not plagued us with a shifter where you mistake 5th for 7th like other cases
09-30-2020, 04:17 PM | #17 | |
Gone Fishin’
7318
Rep 12,125
Better consumption is the compelling reason for the extra gear. |
09-30-2020, 04:20 PM | #18 |
11480
Rep 10,328
I prefer a proven 6MT than a 7MT that does not function correctly. One of the worst things you can have in transmissions is two gears that get confused between themselves as that is the path to a money shift.
09-30-2020, 08:52 PM | #19 |
Rep 1,366
Drives: 2020 X3MC
The F80 6MT is not very good. Rubbery is the term that comes to mind when I think about it. Porsche manual transmissions on the other hand. Drool.
09-30-2020, 11:26 PM | #20 |
Rep 1,759
Given a similar size gearbox a 6MT would be stronger than a 7MT because the gears on a 6MT are physically thicker. The extra set of gears on a 7MT robs space so generally the gear sets are physically thinner. I remembered back in Group N rallying and drags people op for 5MT on the Evos and STis because they ate physically stronger (running thicker gears) than the 6MT
SYT_Shadow11479.50 |
10-01-2020, 08:11 AM | #21 | |
11480
Rep 10,328
I've driven the 6MT in Porsche, the 997.2 GT3 and the 991.2 GT3. It is nice. I don't recall comparing them in my post at any time. |
10-01-2020, 08:31 AM | #22 | |
Rep 4,709
