      03-27-2024, 05:08 PM   #1
Likeanowl
Likeanowl's Avatar
Drives: BMW F80 M3/ Yas Marina Blue
Rogue “coolant low” error?
Just got in my car to get a sudden “low coolant” error. Shut car off, looked to see I do have coolant, turned it back on, error went away. Drove home at very moderate speed and watched engine temp and it never went above normal nor did error come back.
Anybody have any ideas? Worry about it? Take it in?
      03-27-2024, 05:42 PM   #2
forcefed
forcefed's Avatar
Drives: .
When the car cools down check both of the coolant bottles.
      03-27-2024, 05:46 PM   #3
Likeanowl
Likeanowl's Avatar
Ahh you are right I forgot there are 2 different coolant reservoirs. Shit I hope I didn’t just destroy my engine
      03-27-2024, 06:04 PM   #4
zambarossa
Vault Dweller
zambarossa's Avatar
Drives: 2021 M3 6MT (Dravit/KO/ZPP)
Happened once with me, had to top it off a bit. Dropped by the dealer and they took care of it promptly without an appointment.
Current (delivered 20/10/21): 2021 G80 M3 6MT; Dravit/KO/ZPP; 826M; Sunroof (yes no CF)
(More Pictures)
Previous: 2018 340ix 6MT Msport(Dec 17-Sep 21); 2013 335ix 6MT Msport (Nov 13-17); 2011 328i 6MT ZSP (Aug 10-Nov 13); 07 323i 6MT ZSP (May 07-Aug 10); 97 318ti MT ZSP (Feb 97-May 07)
      03-27-2024, 06:11 PM   #5
xXMPowerXx
xXMPowerXx's Avatar
955
Drives: Ford, Lexi, Lambo's
I got the same random message. I checked the upper bottle on the passenger side and it was below the minimum level.
Where is the other bottle?!
      03-27-2024, 06:13 PM   #6
milehighguy
Drives: 2024 M3 Comp- On order
Just had this happen with my F90 M5 last week. Took it in and they determined it was a bad sensor in the coolant expansion tank. I was pretty concerned too but it was covered under warranty.
      03-27-2024, 06:14 PM   #7
Likeanowl
Likeanowl's Avatar
Just checked… bad news is it looks like there is almost none in there. No spots under the car and nothing appears to be leaking?
      03-27-2024, 06:17 PM   #8
Likeanowl
Likeanowl's Avatar
Which coolant can I pickup from autozone to get me to the dealership tomorrow?
      03-27-2024, 06:18 PM   #9
N1rve
Racecar Driver
N1rve's Avatar
Drives: BMW M4
2019 BMW M4  [9.63]
Might be leaking into the engine. The F8X had a problem with TMIC leaking into the engine.
https://f80.bimmerpost.com/forums/sh....php?t=1761517
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension
      03-27-2024, 06:18 PM   #10
xXMPowerXx
xXMPowerXx's Avatar
955
NVM, found it.
      03-27-2024, 06:22 PM   #11
Likeanowl
Likeanowl's Avatar
Car appears to have green coolant but according to autozone I should be using blue? But here the green coolant is listed for “Asian vehicles”?
      03-27-2024, 06:36 PM   #12
Likeanowl
Likeanowl's Avatar
So dude at autozone swears I should be using the blue and even looked it up… but I am positive I see green in both. The green coolant here specifically lists Hyundai, Toyota, Honda, etc. anybody help? If I buy the wrong stuff I’m really in trouble.
      03-27-2024, 06:39 PM   #13
xXMPowerXx
xXMPowerXx's Avatar
955
You will get plenty of warning if your car is getting hot.
Swing by the BMW dealership and get their stuff.
And, yes, you and your car will be fine if you have to do it tomorrow.
      03-27-2024, 06:41 PM   #14
Likeanowl
Likeanowl's Avatar
That makes sense but if the coolant really is that low is there any chance of damage before the car throws a warning?
      03-27-2024, 07:55 PM   #15
mrrm3
Drives: 2022 M4
Just add distilled water to get it up to the proper level. Buy a jug of coolant at the dealer. Don't buy the stuff at an auto parts store unless absolutely necessary.
forcefed2567.00
      03-27-2024, 08:05 PM   #16
Drives: S4
Which reservoir was empty? If it was the one on the passenger side above the turbos that’s for the engine. If it was the one on the drivers side by the oil filter that’s for the I/C heat exchanger loop.
      03-27-2024, 08:38 PM   #17
forcefed
forcefed's Avatar
Drives: .
Don't get car advice from autozone, please. Just go to the dealer for a bottle of coolant.
      03-27-2024, 10:29 PM   #18
2011ninja
2011ninja's Avatar
Jamaica
3399
Drives: 2022 G80 6MT
Let me add this to my note pad.
Tire advice from Cosco ✅
G80 M3 maintenance Auto Zone✅
Roll race Turn off traction control ✅
Summer tires in winter drive slow ✅
Cross shop 911 and M3 family of 4 ✅
forcefed2567.00
      03-28-2024, 01:11 PM   #19
Likeanowl
Likeanowl's Avatar
Reason I went there was because #1 it was walking distance from my house and #2 dealership was closed and I didn’t want to risk driving it on low coolant.
Brought it to dealership today and they said it’s normal apparently? But I made them give me a bottle of it to go to keep in my car just in case. And I will be monitoring it closely the next few weeks.
For reference, it was the engine coolant, not the heat exchanger coolant.
2011ninja3399.00
      03-28-2024, 02:15 PM   #20
forcefed
forcefed's Avatar
Drives: .
It shouldn't be normal but mine was topped up recently too, both were low.
