03-14-2024, 12:55 PM | #1 |
Rep 212
Drives: 2024 M3 Comp xDrive
iDrive always tells me my tires are low...very annoying
Hello,
What temperatures do you all keep your tires at? I keep mine at about 36psi rear, and 33psi front. The door placard says "32psi front and 35psi rear", but the car ALWAYS tells me to "check my tire pressures" every time I get in... It's really annoying. Maybe the door placard is wrong. FYI: 2024 M3 Comp xDrive. Thanks guys! |
03-14-2024, 01:07 PM | #2 |
Rep 2,610
Did you swap to All Seasons or winters?
I had to set mine to <100mph, then it went away. |
m2for2227.00 Limegrntaln13477.50 |
03-16-2024, 01:15 AM | #3 | |
Rep 212
So the same thing happened to you? Do you think there is any downside to having the setting set to <100mph...? Perhaps the car will limit speed or power? |
03-16-2024, 05:51 AM | #4 | |
Rep 320
In uk we just have one pressure- well two … loaded and unloaded. |
03-20-2024, 08:02 PM | #5 |
Rep 29
I have a square set of conti dws 06 plus and everything was fine at 35 lbs all around until it started to warm up and now it wants 38. I have other winter tires selected in idrive
03-20-2024, 08:10 PM | #6 |
Rep 1,929
Set the speed to below 100mph...
Limegrntaln13477.50 Needsdecaf6607.50 |
03-21-2024, 01:21 AM | #8 | |
Rep 212
That's my door sill. Thoughts...? Super odd, those numbers seem way too low tbh. |
03-21-2024, 06:38 AM | #10 |
Rep 1,929
Just follow those pressures, you'll be fine.
03-21-2024, 10:07 AM | #11 |
Rep 858
Ironically I had this same discussion with a friend yesterday that’s got an S Plaid with huge ass aftermarket wheels running some rubberband 30 and 25 sidewall tires and he was goofy running 32 in all of them. Here’s the thing. For anyone who’s running good summer grippy/sporty tires, STOP running the bullshit 32 PSI old school standard of pressures when balancing a tire. If you got a comfy ass non-performance car and want to run 32, fine… run 32. If you’ve got what you guys on this forum have, then go up to at minimum 36 or 38. Generally it’s user preference based on driving style and also what you observe in term of tire wear, sidewall rollover wear when pushing the car, etc. With any pressure you run, if you drive normal, you’re looking at maybe 2-3 PSI pressure increase from cold to hot on the street. So, my suggestion would be put in 36 both front and back and see how the comfort and handling is after you’re warmed up. You’ll probably see the pressure go to up maybe 38. For 35 and 30 sidewall tires, you need to be at slightly higher pressure than bullshit all season 50 sidewall ratio 32PSI pressures. Tire wear will also be somewhat improved as long as you’re not overinflated and that won’t happen unless you push mid-high 40’s. As I said, take it out at 36 and test it and take some corners and then check your rollover. If you’re seeing any wear at the outer edge of your tread pattern, bump them up 2PSI and go with that. You bought a performance sports car… if you’re lowering pressures on your tires to gain comfort on the road, your priorities are off. I dunno what to tell you then… 🤷*♂️
m2for2227.00 |
03-21-2024, 12:01 PM | #12 | |
Rep 212
When I do launch control (I have AWD btw) it felt like the tires couldn't grip... I figured they may have been overinflated as I was running them all around 40PSI. Also, when I would turn into a 90degree corner sharply, it felt like the tires were skidding along the pavement instead of really gripping it. This made me feel as if the tires were over inflated and not able to conform to the road in order to provide optimal grip. |
03-21-2024, 12:49 PM | #13 | |
Rep 858
03-21-2024, 01:48 PM | #14 |
You got my money?
3159
Rep 4,646
Drives: Ice Cream Truck
38PSI cold is like rolling on concret wheels. NO thank you.
Needsdecaf6607.50 marashka223.00 |
