      11-06-2022, 03:54 PM   #1
Chris_DUS
Drives: 2012 E92 M3
iDrive 8 Screen rattle
Hi!
Just got my G80 on friday and have been busy putting miles on. I noticed a rattle coming from the lower far right edge of the screen that disappears when pushed behind on the back cover.
Anybody experienced the same/ has a fix?
Thanks
Chris
      11-07-2022, 11:32 AM   #2
M3X_TB2
M3X_TB2's Avatar
284
Drives: BMW M3CX 2023
I'm having the same issue but on the Driver side left of the ID8 screen so nearest to the driver window.
It stops when I apply light pressure on it in any direction.
I'm hoping a small felt "shim" behind it will resolve it if not I might have to make BMW hunt down the rattle.
      11-07-2022, 11:43 AM   #3
aridtare
Drives: 2023 BMW M3
Same issue for me. I picked up my car on 10/27 and everything was nice and quiet. Starting hearing the rattling a couple days ago (tends to only happen on rougher roads at speed).
I’m able to stop the noise by applying downward pressure on the top of the screen. I’ll probably ask the dealership to take a look when I bring it in for the break-in service soon.
      11-07-2022, 11:52 AM   #4
Chris_DUS
Drives: 2012 E92 M3
Thanks guys so I am not the only one, thought it would be in my head. I stacked a bunch of small felt pads together (like 4mm diameter) and squeezed it behind the sreen. I wont see it and passenger likely wont either. I will bring it up when I go for the break in service, I wonder how they would fix it though as it seems to be the screen housing thats not assembled properly
M3X_TB2284.00
      11-07-2022, 12:28 PM   #5
Technic
Technic's Avatar
2295
Drives: 2021 i3S, 2024 i4 M50
Rattle may be coming from the center speaker grill, known issue.
      11-10-2022, 08:52 PM   #6
Chris_DUS
Drives: 2012 E92 M3
As an update, the fix seems to have worked. Been on terrible roads in WA and OR today and the screen was quiet. What wasnt quiet though was the camera housing on the windscreen...
      11-15-2022, 05:25 PM   #7
SunshineSail
Drives: 2011 335i
agreed. I did this over the weekend and it worked.
https://g20.bimmerpost.com/forums/sh....php?t=1652142
Chris_DUS209.00
      11-16-2022, 01:15 PM   #8
Chris_DUS
Drives: 2012 E92 M3
Thanks for the link! I will swap my speakers anyway so good idea to fix that when the cover is out, even just preemptive.
My screen rattle is gone though, only thing remaining is the camera housing. The rattle stops when I push it so fairly certain its the plastic housing around the camera
      11-16-2022, 02:21 PM   #9
SunshineSail
Drives: 2011 335i
Which camera? Is there one there? Maybe for gestures?
      11-16-2022, 04:49 PM   #10
Chris_DUS
Drives: 2012 E92 M3
Up there is the camera for the speed sign recognition, it has a connected drive label
      11-18-2022, 02:38 PM   #11
DennisLiu9797
Drives: BMW M3(in transit)
Hi! I have the same issue on my 2023 g80.
I found that the rattle comes from the plastic cover of the triangle bracket.
      03-08-2024, 03:54 PM   #12
aznxfrost
Drives: G80 M3 2023
Same issue
Sorry for reviving this thread but it has been a disappointing day for me.
I recently got my hand on a 23' G80, its a dealer demo car with just 3000 km.
During the first day of my ownership, rattling noise starts coming out from left side of the screen as soon as the car reaches 30km/h. The noise was so loud and as other members have mentioned, applying light pressure on the screen make the noise disappear.
Heres my current solution...
      03-11-2024, 02:33 PM   #13
Berzerker
Dealer will fix it. I had the same issue, took it in, they put in some felt tape and it solved it.
      03-15-2024, 05:34 PM   #14
bmw345
Drives: m340
Hi, I have the similar issue. Took it in to the dealership twice. However, the first time they claimed that they couldn't hear any noise. And second time they said it is normal.
I wonder how you convinced them about the noise? And for the fix, where did they put the felt tape? Wonder if I can just do that myself.
Appreciate your help~
      03-16-2024, 08:01 PM   #15
Berzerker
I had a video of the screen rattle happening and it stopping when I pushed slightly on the top left corner of the iDrive screen. That was enough to convince them.
They just put some between the dash and the back of the screen down in the crevice.
If you want, you can put some of this collapsible weather stripping there as a temp fix, that was good enough for me until I took it into the dealer.
