      08-02-2022, 12:05 AM   #67
svrds
Drives: ‘22 BMW M4C xDrive
Originally Posted by MinMax View Post
Hey guys, I just got the Blackvue 750X. Can I leave it plugged into the 12V slot in my trunk? Will it drain my battery or does it shut off itself after I turn my engine off?
You can but it'll shutoff when you power off the car. I use a 124x battery pack add on which gives me 24 hours of juice for when it's parked. Works good for me but isn't cheap. That's plugged into my trunk port
MinMax228.00
      08-02-2022, 12:32 PM   #68
nearwater4me
Drives: '22 G82 Base
It'll power off after a few minutes.
I'm also guessing the Blackvue unit has the function that detects voltage drop and consequently powers itself off... have you checked the manual to see if it does?
      08-02-2022, 12:58 PM   #69
MinMax
MinMax's Avatar
228
Drives: G80
I didnt see anything mentioned voltage in the manual. I'm tempting to get the blackvue battery but it's sooooooo expensive.
      08-02-2022, 06:07 PM   #70
iviegatron
iviegatron's Avatar
Drives: G80 M3
It does, it let's you set the voltage from the pre-configured values. I've had the camera shutoff on me couple of times, which is weird since the camera is set to shutoff if it drops below 12.5 volts. My car was reading 13.2 volts. Guessing some bug. But the option is there.
      08-03-2022, 11:21 AM   #71
s58
DROP TABLE EVs;
s58's Avatar
544
Drives: 2023 m3 6MT, 2015 Lexus GX460
Great write up, thank you for the details on the fuse tapping.
One thing I would caution against is running a wire along the roof line above the doors. There's a curtain airbag that could easily catch that cable and hit a passenger in the event of an airbag deployment. When I did this install on my f30 years ago I ran the wires at the base of the doors to reach the back of the car to avoid going near any airbags.
@g80mt on Instagram - 2023 BMW M3 6MT in Individual San Marino Blue / Tartufo
Past BMWs: 2013 BMW 128i 6MT M-Sport Slicktop, 2016 BMW 340i 6MT M-Sport
Join BMWCCA today and become eligible for members only events, discounts, and the new car rebate of up to $1000! Feel free to use me as a referral (with member #553730) which enters me for a performance school day (I should probably be better at driving, anyway).
      08-29-2022, 03:10 AM   #72
top-down
top-down's Avatar
117
Drives: 22 M3 MT, 22 X5 45e
  [0.00]
In case anyone else is doing this, make sure you remove the A-pillar trim piece enough to run the wires behind the airbags. The original post shows the wires just crossing the a-pillar, and that would definitely interfere with airbag deployment. Why take chances.
It's very simple to pop off the little plastic "airbag" emblem to reveal a torx screw that holds the trim down.
Also - for the fuse taps, just use 3A fuses for both the acc and batt, you should definitely not use 20A fuses in the new circuit of the fuse tap. Most guidelines say not to use more than 5A protection anyway on the new side.
s58544.00
      05-18-2023, 10:58 PM   #73
JustinHEMI
Not great. Not terrible
JustinHEMI's Avatar
7445
Drives: 2024 BMW X3 M40i
The beauty of a common platform is not reinventing the wheel. This tutorial worked perfectly for my G87! Thank you!
Current: 2024 BMW X3 M40i.
iviegatron2542.00
Ravenseal2755.00
      06-04-2023, 02:25 PM   #74
BzsBimmer
BzsBimmer's Avatar
3278
Drives: '23 G80 FO M3, M3 & MY Tezzy's
Just going to add, that there is a wrong way and right way to orient an Add-A-Fuse
I know the original DIY said “fuses” are non-directional which is true, but there is a right and wrong way to add the circuit.
More info found here
https://www.124spider.org/threads/ad...se-them.33420/
This is a valuable thread as I’ll be planning to go through this soon with a R8 and Blackvue
iviegatron2542.00
      07-03-2023, 05:57 PM   #75
OtoPA
Drives: 22 F150, 23 M4, JD3038E
Thank You Iviegatron for your great write-up. I installed the Blackvue 970 2 channel today. works great. I was expecting the fuses to be mounted vertically on the sidewall...surprise! Borrowed the wife's makeup mirror to see as older eyes needed some distance.Name:  IMG_1201.jpg
iviegatron2542.00
      07-03-2023, 06:09 PM   #76
iviegatron
iviegatron's Avatar
Drives: G80 M3
Originally Posted by OtoPA View Post
Thank You Iviegatron for your great write-up. I installed the Blackvue 970 2 channel today. works great. I was expecting the fuses to be mounted vertically on the sidewall...surprise! Borrowed the wife's makeup mirror to see as older eyes needed some distance.Attachment 3220104
Attachment 3220105
Looking good.
Just a suggestion, your camera is upside down. You should flip it 180⁰ where the connections are facing the passenger side. It'll be easier to remove the SD Card when needed.
      07-03-2023, 07:07 PM   #77
OtoPA
Originally Posted by iviegatron View Post
Looking good.
I tried it many locations and orientations. As it sits, I don't see it at all when driving. . As we're able to flip the image via software, I opted for less cable show. I suggested to Blackvue that they print a overlay for those of us too OC to deal with upside-down labeling...LOL. Even with the closeness, I can still get the card when needed, (hopefully never) it has a 256 card as does my F150 and I've not had to pull a card for a year.
      07-03-2023, 08:19 PM   #78
Th3DarkSide
Th3DarkSide's Avatar
369
Drives: 2020 M4
Can someone explain the point of having these Cameras when my car already has this feature for accidents etc etc….? I briefly looked into this unit and the fitcamx and don’t understand the need unless you tap into the fuse box and record while the car is off.
      07-03-2023, 08:59 PM   #79
iviegatron
iviegatron's Avatar
Drives: G80 M3
There has been instances where people complained the built in camera never recorded in the event of an accident. The aftermarket dashcams are recording all the time. Even when parked you can leave it to record. Plus they come in handy when you're racing someone lol.
      07-03-2023, 09:06 PM   #80
Th3DarkSide
369
Drives: 2020 M4
Haha. Interesting. So the built in cameras suck. Got it. Why the Blackvue vs the Fitcamx? The Fitcamx looks to be way better integrated and almost unnoticeable
      07-03-2023, 09:10 PM   #81
iviegatron
iviegatron's Avatar
Drives: G80 M3
Personal preference. I don't have much experience with fitcamx but from a quick Google search it looks like it only records the front. Blackvue records both front and back.
      07-03-2023, 09:18 PM   #82
Th3DarkSide
369
Drives: 2020 M4
Gotcha. I think they both can do front and rear. Thanks
      09-29-2023, 07:13 PM   #83
ap2x
ap2x's Avatar
Drives: '23 M240xi
Did you also tap into fuses 29 and 70? I have an m240 so our fuse box looks a bit different, not sure if that changes anything
      09-30-2023, 09:05 AM   #84
JustinHEMI
JustinHEMI's Avatar
7445
I can't remember which ones exactly, but if that's what that tutorial said, then yes, I used the same fuses.
ap2x21.00
      10-02-2023, 06:50 AM   #85
Mike02z
Mike02z's Avatar
Drives: 2024 BMW M4 Base
2024 BMW M4  [10.00]
2024 BMW M4  [0.00]
The Fitcamx does not fit my 24 G82. I sent them all the pictures they asked for and they said I needed model “C”. It was not even close to fitting. There are two stantions that hit the mirror attachment point. I got it to work but the halves would not fully seat which drove my OCD crazy. I returned it. Don’t bother with their customer support. It’s horrific. In addition, the internals of the Fitcamx kept falling out. Not even a dab of hot glue to hold the camera in. Very cheaply made IMO.
I had a Fitcamx in my 22 X3 MC and it worked perfectly but for the G82, not so much.
I decided to bite the bullet and go with the Blackvue. I hope it arrives so I can do this next weekend.
Thanks OP. This looks easier than I thought. Bookmarking this thread.
      10-07-2023, 08:59 AM   #86
Mike02z
Mike02z's Avatar
2024 BMW M4  [10.00]
2024 BMW M4  [0.00]
I’m about to takle this today. My only concern is the 20 Amp fuse. With the size of the wires I would think they would melt before tripping a 20A fuse. Can I just use a 5 A fuse in the top slot?
***45 minutes in and the rear camera is on as is the front. Rear camera plugged into main camera and hardwire kit all the way to the fuse box. All wires are hidden****
      10-07-2023, 11:03 AM   #87
Berzerker
The connection to the camera itself shouldn't be any more than 3 or 5A fuse. If you're talking about tapping it into a 20A fuse circuit, that should be left at 20A because it's other things on the circuit that *can* short past 20A.
      10-07-2023, 11:10 AM   #88
Mike02z
Mike02z's Avatar
2024 BMW M4  [10.00]
2024 BMW M4  [0.00]
Thanks. That’s what I thought. Leave the 20A in the bottom of the tap and I’ll use a 5A fuse for hot to the camera.
