      04-25-2022, 07:47 PM   #45
Mcc420
Mcc420's Avatar
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
Anyone know which blend mount we need for the g80. I'm looking for the one just for the camera.
G80 Comp, Hcp custom e50, 9.69@141
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53
F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml.
Ig @mcc420
      04-25-2022, 08:23 PM   #46
iviegatron
iviegatron's Avatar
Drives: G80 M3
Go to their website and go through the fitment guide. You'll have to match your rear view mirror from the pics on their website to make sure you order the correct one.
      04-25-2022, 09:14 PM   #47
MunkyTool
MunkyTool's Avatar
Drives: 2023 G80 Comp X-Drive
Originally Posted by Roger83 View Post
So, anyone had any issues after hardwiring the camera? I hardwired the camera as described in the first post. However, the car gives a fault when it's all wired up.
High beam left is faulty according to the car, but it works. If I remove the fuse taps, the error resets.
Curious… Did you get this figured out?
      05-26-2022, 12:30 PM   #48
bmw noob
bmw noob's Avatar
Drives: 2022 G80 Comp x-drive
Originally Posted by bmw noob View Post
Anyone know if using the same fuses as this install would be appropriate for a thinkvue u1000 2ch setup? I don’t want to fry it by sending too much juice.
In case anyone is wondering, blackboxmycar said the same fuses can be used for both, but recommended using a fuse rated to 10-30A for both ACC and BATT.
I will try to find a 10A to replace the 5A used on this install.
Gone: 2020 M340i; 2017 F30 340i; 2008 e92 335
      07-05-2022, 02:44 PM   #49
bmw noob
bmw noob's Avatar
iviegatron how did you get the cables behind the panels over the door and above the a pillar? Just keep pushing them in?
I'm afraid to pull too hard on the trim pieces in case they don't go back in properly. I also don't want to push to hard on the cable with a pry tool in case the cable inside breaks.
      07-05-2022, 02:53 PM   #50
iviegatron
iviegatron's Avatar
Drives: G80 M3
You can try to shove the cable in along the yellow path from my original post or you can slightly pry the panels using the trim tool and then shove the cable in. Not much force is required.
      07-10-2022, 11:20 AM   #51
Indo Rider
Drives: 135
Originally Posted by iviegatron View Post
I used to have this issue but I installed a kill switch so I can turn off the camera whenever I want, especially when parked in my garage overnight. If the car is anywhere but home I leave it on.
You get that error because the car is detecting something is drawing power. When I got that error first thing I checked was the voltage level and my car read 13.12 volts which is above the tolerance level. As long as you have set the cut off voltage on Blackvue it should never dip below it and you should be good. Take that error message as a false positive.
Hey, I'm about to install and I'm interested to know more about your kill switch. I'm guessing you installed a mechanical switch to interrupt power to the camera? That sounds super convenient, but I'd prefer not to slice into the cords if possible. I got the blackvue battery and planning to power from cigarette port in truck. Can you not just turn the camera off easily to achieve the same effect? Thanks.
Edit: yeah, no way to turn the camera off easily... Maybe a conveniently placed rocker switch is in my future. Can't believe blackvue doesn't have an easy way to power off the camera as people have been asking for it for years based on my googling today.
      07-11-2022, 12:02 AM   #52
iviegatron
iviegatron's Avatar
Drives: G80 M3
I haven't dealt with the blackbue battery, but the camera power wire has three connections, ACC, BATT, and GND. I basically took a switch and connected the BATT cable to one terminal and the other terminal went where the BATT connection would go. I hid the switch in the glove compartment at the very top where it's not visible. Since the switch is flat I used a 3M tape to hold it in place.
If you need more clarification feel free to reach out.
12 Pcs SPST Snap-in ON-OFF 2 Pin Snap Rocker Boat Switch Black AC 250V 15A 125V 20A For Car Auto Boat Household Appliances By MXRS https://a.co/d/i20XoRF
      07-13-2022, 11:10 AM   #53
Mashour
Mashour's Avatar
Drives: G80 M3
I have my setup sitting in the trunk waiting to get installed. I'm most likely going to go with the cable plugged in the trunk to avoid issues with the cars battery. I do have the extra portable battery box to continue record while the car is off. My question is how do I get the dash cam to record like normal during its parking mode? It seems it's on a fast lapse and will only do a normal recording if there was an impact detected. My intentions are to get security footage around the car. Anyone know how to make it continue recording like normal and not fast forward? Yes I'm aware I will need a bigger SD card already got that sorted out haha
G80 ///M3 XDRIVE
      07-13-2022, 11:13 AM   #54
iviegatron
iviegatron's Avatar
Drives: G80 M3
Originally Posted by Mashour View Post
I have my setup sitting in the trunk waiting to get installed. I'm most likely going to go with the cable plugged in the trunk to avoid issues with the cars battery. I do have the extra portable battery back to continue record while the car is off. My question is how do I get the dash cam to record like normal during its parking mode? It seems it's on a fast lapse and will only do a normal recording if there was an impact detected. My intentions are to get security footage around the car. Anyone know how to make it continue recording like normal and not fast forward? Yes I'm aware I will need a bigger SD card already got that sorted out haha
There is an option in the settings to change it to normal mode at all times.
Mashour754.50
      07-13-2022, 11:14 AM   #55
Mashour
Mashour's Avatar
Drives: G80 M3
Excellent. Will give it a shot later on this week and report back. Thank you for the detailed tutorial
G80 ///M3 XDRIVE
iviegatron2542.00
      07-13-2022, 10:43 PM   #56
Indo Rider
Drives: 135
Hey, so just a heads up in case it helps anyone... If you want to use the "battery protection" features for parking mode (time based shut off or voltage based shut off) you have to have use the 3-wire (batt+, ground, and accessory) power cable from camera. And the cable that has the cigarette lighter adapter shorts the batt+ and accessory wires together inside the cigarette port plug so those features wont work if you use that cable plugged into the blackvue battery via the short cig lighter receptacle adapter cable.
Since I had already routed that cable under the trim to the trunk, I ended up cutting the cigarette lighter plug off the end of the cable so I could connect all 3 wires to the blackvue battery output via a 3-wire cable that comes with the blackvue battery. Battery protection features work properly now.
None of the other 3-wire cables that came with the camera or blackvue battery would have been long enough to reach the trunk tho, so kinda jacked up that none of the blackvue documentation mentions this and you have to cut and splice cables together to get it to work. Google searching landed me on dashcam forum to figure this out.
At least it works tho, and I think I'm OK without a kill switch since I rarely need parking mode to run for more than say 3 hours since my work and home parking is secure.
      07-18-2022, 08:58 AM   #57
Mashour
Mashour's Avatar
Drives: G80 M3
Any idea on how to clean this up a bit? Wire is hidden until getting towards the rear seats through the trunk.
G80 ///M3 XDRIVE
      07-18-2022, 09:33 AM   #58
nearwater4me
Drives: '22 G82 Base
Replied to your post on the other thread.
Route the wires behind the trunk liner and directly to the passenger's side cubby.
Probably about 15 min. more to remove the liners.
      07-18-2022, 07:39 PM   #59
Indo Rider
Drives: 135
Yeah, this. I had my wife use her tiny hand to reach through the access panel and grab the wire so didn't even have to remove the liner!
      07-19-2022, 01:58 PM   #60
kiw1
kiw1's Avatar
Drives: 2022 M3 Comp xDrive
Noooo!!!! Not what I was wanting to hear. A company that specializes in making mounts you would think they would have something available. I may have to fabricate something.
Ugh same. I was excited to see that there maybe a solution, but doesn't look like it's possible to have my R8 and a Blackvue mounted using my existing blendmount.
I'm sure like some of you I have been the victim of parking car damage and I'd like to be covered.
2022 M3 Comp xDrive - Frozen White
2024 X5 40i xDrive - Black Sapphire Metallic
2021 X5 40i xDrive - Black Sapphire Metallic - SOLD
2012 Audi A4 Avant - SOLD
Insta: mtn_m3cx
      07-19-2022, 02:01 PM   #61
Mashour
Mashour's Avatar
Drives: G80 M3
Not sure what you mean by this. Can you further explain? Maybe highlight my picture please
G80 ///M3 XDRIVE
      07-19-2022, 02:05 PM   #62
Mashour
Mashour's Avatar
Drives: G80 M3
Trunk liner would be the flat part no? The wire would still be seen going into the side compartment
G80 ///M3 XDRIVE
      07-19-2022, 02:56 PM   #63
nearwater4me
What I meant was that once you remove the whole liner (highlighted), you can route the wire directly to the cubby area on the bottom.
The cubby piece is separate from the liner.
Mashour754.50
      07-19-2022, 02:58 PM   #64
Mashour
Mashour's Avatar
Drives: G80 M3
Makes sense! Wow I didn't know that was removable. I'll give it a shot! Is this what you ended up doing as well?
G80 ///M3 XDRIVE
      07-20-2022, 09:35 AM   #65
nearwater4me
I didn't install a dashcam on my car, but I removed the trunk liners to install aftermarket audio equipment.
      08-01-2022, 10:55 PM   #66
MinMax
MinMax's Avatar
228
Drives: G80
Hey guys, I just got the Blackvue 750X. Can I leave it plugged into the 12V slot in my trunk? Will it drain my battery or does it shut off itself after I turn my engine off?
