      01-10-2022, 11:25 AM   #23
HTTP 410
HTTP 410's Avatar
2142
Drives: 2022 M3 Competition
Originally Posted by mzcp View Post
Good find. That means you can hardwire either the dash cam or radar detector with the mirror tap but not both
I'm going to keep the mirror tap for my R7 and the separate battery power for the dashcam.
2022 M3 Comp BGM/Fiona Red, Executive, Drivers Assistant Pro, Parking Assist, 826M black wheels
(SOLD) 2018 M2 BSM LCI, DCT, Executive, Drivers Assist, CarPlay
      01-10-2022, 11:26 AM   #24
dimmy
Drives: 2022 M3 Comp AWD IOMG
Apologies if this has already been asked but.. why are so many people installing dash cams? Doesn't the BMW already have a drive recorder? Or is this for folk without the parking assist package?
      01-10-2022, 11:55 AM   #25
forza1976
forza1976's Avatar
2022 BMW M3X  [10.00]
Drive recorder and a dashcam are very different things. Parking assist package has nothing to do with the desire to have "record" of any incidents that happen to your car parked or driving on the road. Also, drive recorder will not continually record on the open road like a dashcam.
      01-10-2022, 12:31 PM   #26
BMWRacer523
BMWRacer523's Avatar
2519
Drives: G80 M3 Competition xDrive
I would mirror tap the radar and hardwire dashcam to the fuse panel anyway as I would want parking mode.
mzcp2690.50
      01-10-2022, 01:10 PM   #27
HTTP 410
HTTP 410's Avatar
2142
Here's the final answer from Blendmount support:
"Hi,
Unfortunately we do not have a way to connect a BlackView to another Blendmount.
The only cameras that can attach to one of our Blendmounts are the Escort M1 and M2.
Then all you would need is the BM1-UP1 screw kit."
mzcp2690.50
iviegatron2542.00
      01-10-2022, 02:53 PM   #28
iviegatron
iviegatron's Avatar
Drives: G80 M3
"Hi,
Noooo!!!! Not what I was wanting to hear. A company that specializes in making mounts you would think they would have something available. I may have to fabricate something.
HTTP 4102141.50
      01-11-2022, 07:00 AM   #29
HTTP 410
HTTP 410's Avatar
2142
Is there any concern with installing this on glass that's already been tinted? Will it stay attached with the adhesive tape?
      01-11-2022, 08:24 AM   #30
iviegatron
iviegatron's Avatar
Drives: G80 M3
It'll attach perfectly fine. The 3M tape it comes with is plenty strong.
My issue was, my windshield is tinted and I asked my detailer (he installed my tint) if it's safe to attach the dashcam to tinted windows and he said yes. I was worried if I ever remove the camera I'll rip the tint out.
mzcp2690.50
HTTP 4102141.50
      01-11-2022, 09:39 AM   #31
HTTP 410
HTTP 410's Avatar
2142
Thanks. I was concerned about the rear.
      01-11-2022, 10:56 AM   #32
mzcp
Drives: BMW M
My experience with tinted windows and dashcams is that it won't rip the tint but leave residue from the 3M tape. You should be fine
HTTP 4102141.50
      01-11-2022, 01:55 PM   #33
nearwater4me
Drives: '22 G82 Base
Thanks for the DIY writeup, Megatron.
This will come really handy when I decide to install one.
How does that tamper proof casing work, btw?
Is there a key to remove that cover, or is it just a plastic cap that's a PITA to remove?
      01-11-2022, 02:37 PM   #34
iviegatron
iviegatron's Avatar
Drives: G80 M3
You're welcome.
The temper proof case comes with its own mount that you attach the camera to. There are a total of three allen/hex screws. Two screws are for the cover to prevent unplugging of the cables and removal of the SD card. The third screw holds the camera in place securely, so it can't be removed.
HTTP 4102141.50
      01-12-2022, 12:09 AM   #35
nearwater4me
You're welcome.
Ah I see. That makes sense.
It sounds like a good deterrence measure to avoid dealer techs from unplugging the power cable.
Again, thanks for the feedback. I need to get me one of these… lots of crazy drivers in ATL.
      03-15-2022, 10:00 AM   #36
Roger83
Drives: ‘23 BMW X5 50e San Marino Blue
So, anyone had any issues after hardwiring the camera? I hardwired the camera as described in the first post. However, the car gives a fault when it's all wired up.
High beam left is faulty according to the car, but it works. If I remove the fuse taps, the error resets.
MunkyTool547.50
      03-18-2022, 08:12 PM   #37
HTTP 410
HTTP 410's Avatar
2142
Are you using the fusebox behind the glovebox? Mine is using the one in the trunk with no issues.
      03-21-2022, 02:08 PM   #38
Roger83
Is it better to use the fusebox in the back instead of the front?
      03-21-2022, 02:09 PM   #39
iviegatron
iviegatron's Avatar
Drives: G80 M3
I would prefer the front. Less wire to run.
      04-08-2022, 03:31 AM   #40
NightWriter
NightWriter's Avatar
4844
Drives: G80 M3 Pure
Great write up here, thanks. I'm curious whether people who are also adding R7/V1 detectors to their fuse panels (I prefer that over the mirror tap) to have enough room/amperage to drive both? Which fuses are you using for the radar?
      04-08-2022, 03:47 AM   #41
418BUC
418BUC's Avatar
United Kingdom
535
Drives: M4 Coupe G82
Really appreciate this! I'm going to order this today. During my research, it looks like the DR900X-2CH Plus has parking mode built in OOTB along with low voltage battery protection (not sure why the offer Power Magic Pro as an option because that's what it does).
Is there any reason to get an add-on battery pack?
BTW - for those ordering directly from Blackvue, it looks like you can use coupon code "VortexRadar" to get 10% off.
As regards add-on battery it depends how long you are likely to leave the car standing. Once the cars battery drops to 12v it will switch off, but as an idea my car hasn't moved for 2 days and still in park mode/ recording
HTTP 4102141.50
      04-11-2022, 10:13 AM   #42
jkovac1
Drives: 2022 M3 Competition xDrive
Great guide. I wish I had this a few months ago.
Maybe it's the way I installed it, but does anyone get the battery message after leaving the car overnight with the blackvue recording? It happens each time I start my car in the morning. I have never had an issue for over 6 months now, but could this be a problem?
For reference:
2022 BMW M3 Competition xDrive (Toronto Red)
2015 Audi S3
      04-11-2022, 11:41 AM   #43
iviegatron
iviegatron's Avatar
Drives: G80 M3
I used to have this issue but I installed a kill switch so I can turn off the camera whenever I want, especially when parked in my garage overnight. If the car is anywhere but home I leave it on.
You get that error because the car is detecting something is drawing power. When I got that error first thing I checked was the voltage level and my car read 13.12 volts which is above the tolerance level. As long as you have set the cut off voltage on Blackvue it should never dip below it and you should be good. Take that error message as a false positive.
jkovac116.00
      04-11-2022, 02:05 PM   #44
forza1976
forza1976's Avatar
For reference:
Attachment 2856998
Time to get some Blackvue batteries:
https://g80.bimmerpost.com/forums/sh....php?t=1890781
HTTP 4102141.50
