      03-03-2024, 11:06 AM   #815
jimbethesda
jimbethesda's Avatar
Drives: M3 (F80)
Originally Posted by ipilcher View Post
Trying to figure out how badly I've fscked myself.
I used BimmerCode to disable the ASD earlier today, and I was prompted to save the FSC code to Google Drive. I thought that I had done so, but hours later I just noticed that Google Drive is showing that the FSC file is still "Waiting to upload."
I do see a 316 byte
Code:
FSC_...
file in my Google Drive that seemlingly got uploaded today, but I also see references on the interwebs saying that it should be 319 bytes.
Am I hosed? (I.e. will I be able to restore the ASD functionality if I were, for some odd reason, to want to?)
Next time you update your car’s software it will zap all coding.
2001 330Ci (sold)
2007 335i (sold)
2008 E90 M3 (sold)
2015 M3 (sold)
2022 G83
      03-04-2024, 08:53 PM   #816
Asmedbeats
Drives: 2023 M3 Comp Xdrive
  [0.00]
2023 M3 Comp Xdrive  [0.00]
The ASD coding is the only thing that doesn’t reset. I think I lost the file too…
      03-04-2024, 09:46 PM   #817
Berzerker
Someone mentioned you can just put in the code manually, I don't remember exactly what it was, and I can't find the post anymore now...
      03-04-2024, 11:28 PM   #818
G30M
G30M's Avatar
3811
Drives: BMW M550i; Kia EV6 GT
i have the FSC file but i lost ASD after playing around with Bimmercode and have not been able to get it back.
Bimmercode says everything is there FSC ASD is activated
      03-15-2024, 06:23 AM   #819
Callann
Drives: BMW M3 G80
Hoping someone can assist a new BMW owner. I'm also a Bimmercode virgin.
Connected my Enet cable today and successfully coded the start/stop.
The next feature I was hoping to adjust was the threshold speed for retracting the side mirror. Factory default is 20 kph. Wanting to bump it up to 50.
Do I need new glasses or is the option not available for G80 with ID8?
      03-15-2024, 09:12 AM   #820
gnolivos
Drives: Various BMW
It's there and it's a standard feature. Not sure you can go that high though.
Bimmercode best coding options (Basic and Advanced):
https://g20.bimmerpost.com/forums/sh...5#post29807925
      03-15-2024, 09:18 AM   #821
gnolivos
Drives: Various BMW
Here is where I see it
      03-15-2024, 08:28 PM   #822
Callann
Drives: BMW M3 G80
Thanks for the reply gnolivos.
I'll report back in a couple of days when my new specs arrive.
      03-18-2024, 11:43 PM   #823
Callann
Drives: BMW M3 G80
There's something funky going on with my setup it seems.
Running on Samsung S24. I have no FEM Module. I have no Expert Mode. App is flakey, often not being able to read the modules.
It could be my ethernet to USB adapter. I'll get another one to try.
      03-19-2024, 11:13 AM   #824
Berzerker
I don't remember the FEM being available for FA coding but it's been a while since I've been in BC.
Expert modes are available within each module, not just overall in the main menu.
      03-19-2024, 05:22 PM   #825
Callann
Drives: BMW M3 G80
Checking the Bimmercode website it appears mirror threshold speed coding is not an option on the G80.
      03-19-2024, 08:07 PM   #826
gnolivos
Drives: Various BMW
You need a proper module. That one likely doesn't support the modules or expert mode. I had this issue.
      04-01-2024, 04:02 PM   #827
waiting
Drives: 2024 M3 CX
Hi all,
Thanks for all of your posts. I coded the warning at start-up off and ASD off today. Sounds much better on the inside.
I was playing around with the ambient light setting and adjusting colors, but I think that's the wrong module. Initially, I received Day Light Running and Light Bend error codes. After power down and restart I decided to revert to a back up code in bimmercode. No errors now; however, I have one question, when daytime running lights are on, besides the halos, are the little LED slits supposed to be on too? I can't remember them being on during the day.
Thanks in advance.
2024 M3CX BRG/KO
      04-01-2024, 05:48 PM   #828
thatguyM4
Drives: 2021 M4
Originally Posted by waiting View Post
Hi all,
Thanks in advance.
yes they stay on
waiting120.50
      04-11-2024, 10:25 AM   #829
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Anyone else having issue connecting via e-net cable on IOS 17.4.1? I. It’s unable to recognize the vehicle.
      04-11-2024, 10:48 PM   #830
waiting
Drives: 2024 M3 CX
yes, I have to press connect 2 or 3 times, then it works.
      04-12-2024, 08:59 AM   #831
Berzerker
It takes a while, once you plug it into the phone, for the ethernet adapter to time out DHCP and give itself a private address. Go into your settings and under "Ethernet" (when the device is connected) wait for it to get a 169.254.xx.xx address and then it should connect immediately.
m20e30871150.00
      04-12-2024, 10:43 AM   #832
thatguyM4
Drives: 2021 M4
I used a Samsung Fold 5 and the way I connect with Bimmercode or Bimmer utility is with an enet cable from Amazon and a USB to C adapter which i got from Samsung with my Fold 5 - Connecting to my Car :
Open the App _ Put it in Airplane Mode - Go into connections - search ethernet teethering and turn on then go to the app and connect 100X faster then Bluetooth
      04-13-2024, 11:45 AM   #833
waiting
Drives: 2024 M3 CX
Thanks Berzerker! Do you know if I can use the same phone to code my wife’s X3 as well? Love not having the warning messages on the M3.
      04-13-2024, 05:25 PM   #834
Berzerker
Yes you can
      04-15-2024, 12:44 PM   #835
tm811
Drives: 2024 m4 comp xdrive
Anyone when they coded activate the hazard lights on emergency braking get a daytime/parking lamp malfunction?
      04-15-2024, 01:02 PM   #836
gnolivos
Drives: Various BMW
Many times you will get malfunction warnings Immediately after coding. This is actually pretty normal. You can shut down the engine and start again and notice it will all be cleared out.
