      04-24-2021, 05:30 AM   #1
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
BimmerCode
Is BimmerCode working for our G8x? I can't seem to connect to the car for some reason.
      04-25-2021, 11:35 AM   #2
rak299
Drives: 2021 M3 6MT
I contacted them and it isn't working yet. No ETA.
      04-25-2021, 12:43 PM   #3
chris3g
Drives: 2023 M3 xdrive
maybe not officially supported but it works, i coded a few minor things with it yesterday. detected car as an x3m.
      04-25-2021, 01:33 PM   #4
Murf
Drives: 2021 G80 M3C - Dravit Grey
I actually reached out to Bimmercode and they told me the internal systems are the same as the G20 and we should be able to code the same list of things.
https://bimmercode.app/cars/g20/
M4Tejas788.00
      04-26-2021, 03:28 PM   #5
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Great! Any option for ASD off?
      04-28-2021, 07:41 AM   #6
moproblems
Beware of cheap bait!
moproblems's Avatar
709
Yep, easy as pie.
      04-28-2021, 06:17 PM   #7
F85MTuNED
IG: @88jae88
F85MTuNED's Avatar
1621
Drives: ///Ⓜ️
Correct Bimmer code Recognize the G80/82 as a G20 but now I'm thinking about seeing if it recognizes it as the X3M as well because there could be some hidden gems 👀 lol
IM POOR..
      04-29-2021, 12:42 AM   #8
snareman
snareman's Avatar
Drives: ///M8 & X3 ///M40
What all have you all been able to code so far with it? Is there a chance that if it's recognizing it as a different car that you could screw something up and brick the car?
Retired:
2021 Enzian Blue ///M4 ||| 2018 ///M4 ||| 2017 ///M4 ||| 2014 435i ||| 2009 335i Coupe ||| 2007 335i Coupe
      05-01-2021, 12:33 AM   #9
moproblems
moproblems's Avatar
709
Most if not all G20 coding I have tried have worked flawlessly. Comfort closing, ASD off, hazards on emergency braking, closing trunk with key (exec pack). Somebody will need to be a Guinea pig for the laser coding however.
      05-01-2021, 10:13 AM   #10
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Which section is for ASD off?
      05-01-2021, 10:54 PM   #11
warcity
warcity's Avatar
Drives: 2021 G82 Manual
Yes it's working. I did a bunch in my G82.
Thanks.
Ario
      05-04-2021, 06:07 PM   #12
warcity
warcity's Avatar
GX - BimmerCode
I've been fiddling with bimmer code and haven't yet been able to figure this out:
- I want the M sport display in my cluster "without" actually being in M sports. I don't want to lose my driver assistance - just want the display
- Lighted M Badge in the seats - I want to keep them on at night (i.e. come in with headlights)
If anyone figures these two out pls let me know.
Everything else works just fine.
Cheers.
Thanks.
Ario
      05-05-2021, 12:53 PM   #13
Der_Wolf
Der_Wolf's Avatar
Drives: 2021 G82 Comp
Does the G8x have default option to fold mirrors when locking? I had to code it in my F80, but briskly going over the G20 options, I don't see it available. This leads me to believe that it is possible without coding.
DCT OFF61.50
M4Tejas788.00
      05-05-2021, 02:49 PM   #14
modat
Drives: 2022 IOMG M3 Xdrive
Thats a standard option in Idrive
M4Tejas788.00
      05-05-2021, 04:07 PM   #15
warcity
warcity's Avatar
Yeah BMW finally figured they should just make it default- everyone codes it anyways. Automatic window roll up and down via FOB is now default. No coding needed.
Thanks.
Ario
JTO245276.00
      05-11-2021, 12:02 PM   #16
warcity
warcity's Avatar
Cheers.
+1
Thanks.
Ario
LivinLrge201.00
      05-11-2021, 09:23 PM   #17
barryc365
Drives: BMWM3
What are you guys using to connect to the OBDii
I saw some blue tooth devices on Amazon for $30. Do they do the job or do you recommend something else to connect to BimmerCode?
      05-11-2021, 09:48 PM   #18
warcity
warcity's Avatar
I'm using this.
OHP ENET OBD Interface Cable for... https://www.amazon.ca/dp/B07V3C47YD?...p_mob_ap_share
No issues at all.
Thanks.
Ario
      05-12-2021, 10:33 AM   #19
barryc365
Drives: BMWM3
I'm using this.
No issues at all.
That's using your laptop I assume?
I think I'm going to go for the Bluetooth version and just use my phone and leave the OBDii adaptor in the glove box.
      05-12-2021, 01:04 PM   #20
warcity
warcity's Avatar
I'm using this.
No issues at all.
I use it with my iPad and iPhone (or Android) you will will need an Ethernet to lightning adaptor.
Thanks.
Ario
      05-13-2021, 09:30 AM   #21
Der_Wolf
Der_Wolf's Avatar
This is the exact same setup I use as well. Never had any issues with it on my F80. I just keep the enet and iPhone ethernet adapter in my trunk and can code/decode whenever I please.
|2021 M4 Competition| |2018 M3 Competition| |1994 525i|
///M
Needsdecaf6606.00
      05-14-2021, 06:12 AM   #22
LuvMyE92
Occasionally frequent poster
LuvMyE92's Avatar
3000
Drives: CT5V-Blackwing
Hopefully when someone notices that support for the G8x platform is available, they will update this thread.
BTW, FWIW, I use a BT ODBC connector for BimmerCode and it works fine.
Current inventory:
F22 & G05
Cadillac CT5-V Blackwing w/3 pedals
Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2)
