      06-17-2022, 10:55 PM   #89
nikko747
Drives: 2022 BMW M3
Tint all around and windshield protection film.
Originally Posted by Limegrntaln View Post
Did you get your tint done the same time as your radar detector install? My 21 Accord had a radar cruise control fault, after getting my windshield tinted.
      06-17-2022, 11:06 PM   #90
Limegrntaln
Limegrntaln's Avatar
That's when all of my electronics started acting up, when I was leaving the tint shop. So, it may not have been the radar detector install. Everything is fine, now, but it was messed up for a few days.
I do know you cannot hardwire a radar detector to a C8 Corvette mirror, thats giving people all kinds of problems, so, its possible.
YT: G Dubyou
      06-17-2022, 11:22 PM   #91
nikko747
Drives: 2022 BMW M3
Interesting…I read up on the C8 issues and talked to Blendmount about it when I was asking about my situation. They said it was due to incorrect wire placement causing the issue.
      06-17-2022, 11:29 PM   #92
Limegrntaln
OK, that makes sense. Which also brings up the question, what wires did they tap? Usually shops that install their own stuff, they don't go looking for youtube videos on how to wire a radar detector, they get in there with a voltmeter and find a 12v wire. I'm willing to bet they tapped the wrong wires.
YT: G Dubyou
      06-18-2022, 09:18 AM   #93
bmw noob
bmw noob's Avatar
Drives: 2022 G80 Comp x-drive
I believe that was one of the errors I had as well…I’m not going to bother for now. I’ve got to have BMW look at an uneven trunk lid for now. For some reason one side is sitting almost a quarter inch higher.
So i checked my settings...i changed Blindspot monitoring to "early" before a long drive today. About halfway through the drive (50 miles or so) all of sudden both monitors started working flawlessly.
Maybe they had to calibrate after pickup? Maybe it was set to low and wasn't picking up cars?
Gone: 2020 M340i; 2017 F30 340i; 2008 e92 335
      06-18-2022, 10:41 PM   #94
nikko747
Drives: 2022 BMW M3
He said he followed the instructions from this thread, but you never really know.
Limegrntaln13477.50
      06-18-2022, 10:43 PM   #95
Limegrntaln
The only way to know is to take it back apart to see if its hooked up, correctly, if it's still causing problems.
YT: G Dubyou
      09-25-2022, 01:18 PM   #96
BMWRacer523
BMWRacer523's Avatar
2519
Drives: G80 M3 Competition xDrive
Finally spent some time to get the trim off and do the mirrortap. Wasn't as straightforward as in the video but removed them without damage with some patience and trim tools. Thanks to Limegrntaln for the idea to use the needle nose, I was able to use them to remove the plug and tap the leads without issue.
HTTP 4102141.50
      09-25-2022, 07:42 PM   #97
Limegrntaln
Hell yeah!
I'm glad it worked for someone else, besides me.
YT: G Dubyou
      09-27-2022, 12:37 AM   #98
Mashour
Mashour's Avatar
Drives: G80 M3
Does anybody have a link to the blend mount please? I have the escort max 360c. I'm also hearing that the blend mount does rattle. Is it worth spending over $100 for this piece?
G80 ///M3 XDRIVE
      09-27-2022, 04:22 AM   #99
Limegrntaln
I have the Blendmount for my Uniden R7, and it doesn't rattle. I'm also on my 5th blendmount. I've had them on the past 5 cars. They're well worth the money.
You have to go to their website and put in your make and model, to determine which rear view mirror you have. They list 3 different options, depending on what packages you have ordered with your car.
https://blendmount.com/radar-detecto...RoCIl8QAvD_BwE
YT: G Dubyou
Mashour754.50
      09-27-2022, 05:22 AM   #100
Mashour
Mashour's Avatar
Drives: G80 M3
Thank you!
G80 ///M3 XDRIVE
Limegrntaln13477.50
      09-27-2022, 02:22 PM   #101
m4ml
Drives: 2022 M4CX BSM (Xpel Stealth)
Mine does rattle, but only at around 2k RPMs with the drone of my exhaust. If I had a stock exhaust I don't think it would rattle.
Edit: Also, it's not the mount to the mirror that's rattling, it's the connection to the R8. All I have to do is barely touch the R8 and the rattle goes away.
Susp: Turner Skid Plate/Strut Brace, KW v4, F-L Monoball, MS: Camber Plates, Spacers, SPL Rear
Cosmetic: MPerf: Splitter, Side Vents, Sill Plates, Door Projectors; IND CF Roundels/Float Center Caps, Vorsteiner Grill, Xpel: Stealth PPF, Fusion Plus Ceramic, XR Plus 5/20/70
Mashour754.50
      09-30-2022, 02:58 PM   #102
DennisLiu9797
Drives: BMW M3(in transit)
so, is it common for people to have error messages after mirror tap? Is it okay if I mirror tap my dash cam?
      10-01-2022, 05:21 PM   #103
BMWRacer523
2519
No errors here. I don't believe it is common.
      10-01-2022, 06:27 PM   #104
BLKSAPPE92
BLKSAPPE92's Avatar
Drives: 22 G80 Sao Paulo Yellow
2022 BMW M3  [0.00]
2022 BMW M3  [0.00]
2022 BMW M3  [0.00]
2022 BMW M3  [0.00]
Originally Posted by Saturatedfat View Post
Anyone know which wire to tap for switched power (off when car is off). I tapped the red/black wire but it looks like the radar detector is still on after the car turns off.
Update: Never mind, apparently it turns off after a few minutes.
On the big connect it's the left most (brwn/blk for ground and right most reddish/pink for 12v). All the trim pieces pull of relatively easy.
Maybe because you live in Miami and part outside 😂
      10-08-2022, 11:59 AM   #105
jummo
Drives: 2022 M3CX 2023 x1
Thanks so much for this thread! I am all installed. Looks good, works great.
The hardest part was splitting the plastic cover. Well, that and making my size 11 hands fit in a tight place.
Very helpful and highly recommend installing your radar detector with blend mount.
      10-18-2022, 11:55 PM   #106
Limegrntaln
Double sided sticky tape help?
YT: G Dubyou
m4ml1834.00
      10-19-2022, 07:40 PM   #107
csayad
csayad's Avatar
Drives: BMW M3 xDrive
2023 BMW M3 Competi ...  [8.57]
  [0.00]
If I do a mirror tap is it removable/reversible? I have a 23 coming in soon but would like to do this. Thoughts?
Limegrntaln13477.50
      10-20-2022, 01:49 AM   #108
m4ml
You're literally sliding a connector into the stock harness by pushing it in. You don't disconnect anything, you just push the connector in.
It's hard to articulate, but it couldn't be more reversible
      10-20-2022, 07:45 PM   #109
Limegrntaln
Just throwing caution to the wind. But since the center screen has been updated in the 2023, there may be other electronics that have been updated, as well. Just keep that in mind when you're using the same wiring that worked in the 2021-2022 models.
Worst case scenario, you just won't get power. It's not going to mess anything up, unless you completely ground something out. I would say if the wiring color is the same, it's probably a safe bet, that nothing has changed.
YT: G Dubyou
csayad419.50
m4ml1834.00
      11-01-2022, 07:38 PM   #110
emargul
emargul's Avatar
Drives: M3
So has anyone done the mirror tap on the 2023? I am having the issue of no power at the red and blue wire; however I get 13 volts on the small connector with the red and green wire. I've been at this for 2 hours now. Super frustrating! Thanks in advance for any advice.
Limegrntaln13477.50
