10-16-2023, 12:16 PM | #1 |
Rep 8
BMW G80 M3 Wheel Spacers
Hello everyone,
I'm looking to improve the stance of my G80 M3 with spacers. I came across these lightweight spacers that seem very good quality. https://oemplusmods.com/products/lig...w-m2-m3-m4-g8x Any recommendation what size to get? I'm also looking to lower the car with springs. Thanks! Last edited by g80rocco; 11-22-2023 at 03:15 PM.. |
10-16-2023, 12:23 PM | #2 |
Rep 14,115
Drives: G82 M4C X-Drive
I don't know anything about that brand, but you do want to get longer bolts to pair with the spacers. I've been using Macht Schnell for my past 2 M cars, all tracked, no weird wobbles, no problems.
https://europeanautosource.com/produ...-bmw-g-chassis I use 15mm all around to keep the front to back "offsets" the same, but I have an M4, so I'm not sure if that will rub for the M3. EDIT: This is on Michelin PS4S BMW*
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 Last edited by jmg; 10-16-2023 at 03:03 PM.. |
10-16-2023, 01:14 PM | #4 | |
Rep 2,622
Just be aware if you have Pirellis, 12mm in the front *will* rub. You can either cut some of the grill fins on the plastic liner or just use 10mm. 12mm will work with Michelins. |
10-16-2023, 01:48 PM | #5 |
Rep 8
[/QUOTE]
Wow I love the stance of your car! I think the M3 needs different sizing , so I will see if anyone has an M3 here with spacers. As far as the bolts there's an option for extended bolts on the website which I will absolutely get for safety. |
10-16-2023, 01:49 PM | #6 |
Rep 8
10-16-2023, 01:52 PM | #7 |
Riding the knock sensor
2371
Rep 1,593
Drives: 21 X5MC | 23 M4CSL
https://g80.bimmerpost.com/forums/sh....php?t=1808816
M4 in the link, but you can search the forums for M3 pics - tons of threads on the topic. Not a huge difference in the technical specs but there are subtle visual differences between the 2 and 4 door that may matter to you.
g80rocco3.00 |
10-16-2023, 02:04 PM | #8 | |
Rep 18,833
We've been using the Macht Schnell line for the past 15 years with all our street and track clients - and only proven with time.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 10-16-2023 at 03:46 PM.. |
10-16-2023, 03:43 PM | #10 | |
Rep 2,622
10-16-2023, 03:47 PM | #11 |
Rep 18,833
Thanks for the heads up, been back and forth on F8x and G8x forums today.
10-17-2023, 12:26 PM | #12 | |
Rep 8
tom @ eas8237.50 |
10-17-2023, 12:28 PM | #13 | |
Rep 8
10-17-2023, 03:20 PM | #14 |
Rep 399
I’ve had 12mm front and 10mm rear Bimmec spacers on my G82 M4 for about 18 months, with longer wheel nuts obvs
The car looks so much better with this setup, however the front right tyre (Pirelli P Zeros) rubs on 3/4 lock (reversing left down) every time, even though my front tyres have now done 20k+ miles so are getting worn down It’s not a big issue but quite annoying as I reverse out and to the left every time I take my car out, so it’s a regular noise - worth it though for the better stance |
10-17-2023, 04:06 PM | #15 |
Rep 238
Drives: 2022 X3 M40i/2023 M3CX
Future classic 15mm front and 12mm rear with hr sport springs. Front treated with heat gun trick, if not full lock backup and uphill, no rubbing. Rear is tricky, may rubb on bumpy roads running high speed. I have pirelli.
g80rocco3.00 |
10-17-2023, 06:16 PM | #17 |
Rep 2,622
mathys202.50 kgelfen3602218.50 |
10-17-2023, 06:51 PM | #18 |
Rep 165
I have 15 mm spacers front and back with pirelli tires lowered on Eibach front springs with 20mm drop. I used a heat gun on the front liners and no rubbing at all.
10-18-2023, 01:51 AM | #19 |
Rep 341
Don't believe the wheel gap changes too much, at least for me visually. The poke, especially in the rear, when you get to 10mm+ without a drop and stock camber makes it look like a bit cartoonish. The front is a bit easier to get away with. Just my pov.
10-18-2023, 02:00 AM | #20 |
Rep 131
I have 12mm spacers all around with Pirellis. It’s also lowered on H&R sport springs. I hate wheel gaps but I’m also not a fan of the slammed look. As always, to each his own.
NicolasB808.00 MaC-N54-E82470.00 |
10-18-2023, 02:44 PM | #21 | |
Rep 37
Got 400miles left of break-in. After that 1st dealer visit, gonna install everything. |
AWDSOME629.50 |
10-18-2023, 03:04 PM | #22 |
Rep 336
What size spacers would be recommended if I go with Continental DWS all seasons?
