04-26-2024, 12:30 PM | #1 |
Rep 343
Strut brace part no help
I’m an idiot and I stripped the stud and nut on my strut tower brace. Anyone know the part numbers? I can’t seem to find them.
04-26-2024, 12:54 PM | #2 |
Rep 872
I believe you have to get the entire assembly. P/N should be 51618076674.
Speed & Tech Motoring
23585 Overland Drive, Unit 178 Sterling, VA 20166 (Headquarters) 23541 Pebble Run Place, Unit 140 Sterling, VA 20166 (Satellite shop) |
04-26-2024, 01:00 PM | #3 |
Rep 343
Damm 80 bucks just to replace a stud
04-26-2024, 01:04 PM | #4 |
Mr. Irrelevant
3699
Rep 597
Sucks...but relatively cheap lesson. I've had much worse (costly) mistakes.
Past results aren't a guarantee of future performance.
kgelfen3602247.00 |
04-26-2024, 01:10 PM | #5 |
Rep 936
You could always tap and die that back, as long as it’s not really bad.
Piece of advice. Put things in by and and start nuts and bolts like that. Stop using power tools to zip shit on from the get go. Pretty had to strip stuff by hand. |
T0RM3NT3699.00 |
04-26-2024, 02:15 PM | #7 |
Rep 936
Make sure you know how to use it and you measure the threads correctly with the gauges in the set or you will make things worse.
You’re lucky that stud is in a removable bracket and not part of the strut tower itself or you’d be much worse off if the threads were really screwed. |
04-26-2024, 04:42 PM | #10 |
Rep 343
