Classifieds Sponsors Classifieds Suspension / Brakes / Chassis / Spacers
      08-14-2023, 04:46 PM   #1
IND-Distribution
IND-Distribution's Avatar
9588
Drives: G82 M4 / G87 M2
IND | KW G8X M2 / M3 / M4 RWD Coilover with EDC Cancellation Kit - V4 Clubsport 3-Way
KW V4 Clubsport: 3-way damping adjustable coilovers
The technology of the 24-hour race winner.
Using the Nordschleife as it's testing grounds and the 7-post rig, KW developed it's KW V4 Clubsport coilover kit. Wheel loads, vehicle weight and chassis reinforcements (for increased body stiffness) can all be taken into consideration with adjustment capabilities of the KW V4 Clubsport. Similar to KW V4 Racing 3-way damping adjustable coilovers, low-speed and high-speed compression adjustment is done via KW's patented two-valve control on the valve manifold.
By hand, you can tune the low-speed compression damping with six precise clicks on the purple adjustment dial. The gold adjustment dial allows the user to change the high-speed compression damping with 14 precise clicks. Rebound adjustment is provided with 16 clicks, each providing a noticeable change. A reduction in rebound forces provides a more comfortable ride quality suitable for highway driving.
Product Details:
  • Fits G87 M2, G80 M3 RWD, G82 M4 RWD models
  • 16 precise clicks in rebound adjustment dampening
  • Adjustable compression damping with 6 clicks in low-speed range and 14 precise clicks in the high-speed range
  • Seamlessly adjustable lowering
  • TÜV-tested adjustment range
  • High-quality components for long-term durability
  • Independent damping force adjustability with aluminum spherical bearing top mounts available
The KW G8X M2 / M3 / M4 RWD Coilover with EDC Cancellation Kit - V4 Clubsport 3-Way may be viewed at the following links to our online store:
https://ind-distribution.com/product...lubsport-3-way
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAM • YOUTUBE • FACEBOOK • FLICKR
