04-06-2023, 04:24 PM | #1 |
Rep 7,300
BMWPartsPros.com l G8x OEM CARBON CERAMIC BRAKE RETROFIT KIT
Created for extreme high-performance driving demands, such as on the track, the M Carbon Ceramic brake system is made of advanced materials that withstand significantly higher temperatures. Large 16-inch front rotors provide outstanding stopping capabilities while shaving 42 lbs. of unsprung rotational mass from the vehicle. Compared to conventional brake systems, its long-life design includes brake pads expected to last 2-3 times longer and rotors expected to last 3-4 times longer. Important:Dependent on conditions and usage, features specific to the materials used can lead to operational noises particularly in wet conditions just before the vehicle comes to a halt. The impact of moisture and road salt can cause the braking action to be equivalent to a conventional brake system. This can for a short time be experienced as a reduction in braking action and can be balanced out by greater pressure on the pedal where necessary. LINK: https://www.bmwpartspros.com/oem-par...bC12OC1nYXM%3D Last edited by PARTS@STBMW; 07-06-2023 at 05:20 PM.. |
05-23-2023, 09:04 PM | #2 |
Rep 289
Do you think you will be having some good sales on this setup?
Limegrntaln13475.00 |
05-24-2023, 12:50 AM | #3 |
Rep 6,962
$14,000 is already about $8,000 cheaper than these cost, at the parts counter. Although, the link directs us to a 2014 550i GT CCB set.
YT: G Dubyou |
PARTS@STBMW2701.50 |
05-24-2023, 10:33 AM | #4 | |
Rep 7,300
The link is to the G8x platform models that this is compatible with, please scroll down to see the models it fits. -Brit |
