05-03-2023, 08:51 PM | #1 |
Rep 94
Wheel Spacer recommendation?
Could anyone recommend the best or most preferred wheel spacers for a 2023 M3 xDrive Competiton? I am running P4S tires and would like to run 15mm in the front and 12mm in the rear.
05-04-2023, 03:09 AM | #3 |
Rep 94
Either way however which brand would be best. I was considering Dinan spacers however can't really find any reviews about them.
How about Future Classic? |
05-04-2023, 09:44 AM | #4 | |
Rep 190,952
I've used BMS and MAD and never encountered any issues with either brand.
05-04-2023, 10:00 AM | #6 |
Rep 94
I am going to go with 15mm in the front and 12 in the rear just to be safe.
I would like to get KW HAS springs and lower the car a tad bit to give it a nice stance and avoid rubbing. |
05-04-2023, 10:05 AM | #7 |
Rep 165
I didn't answer your brand question. I'm using the BMS spacers and they look/fit great.
05-05-2023, 11:41 AM | #9 |
Rep 190,952
I'm using 15mm spacers and have my car lowered with H&R VTF, which looks fantastic. However, I needed the RKP fender clearance in the front to prevent any rubbing issues.
05-05-2023, 12:50 PM | #11 |
Rep 223
05-05-2023, 08:07 PM | #12 |
Rep 1,661
I just mounted 15mm front / 12mm rear (following IND recommendation from old thread) with PS4S. I get minor rubbing in front at certain steering angles when in reverse (at <5 mph) into parking spaces. More specifically, it seems left front only with steering turned to the right about halfway between straight-ahead and full lock.
05-05-2023, 08:11 PM | #13 | |
Rep 94
05-05-2023, 08:19 PM | #14 | |
Rep 264
I would recommend 15mm front 12mm rear, BMS, H&R, and MAD are all good options. Search for IND’s thread that shows the visual differences between the different width spacers to get a better idea of what it will look like. To prevent rubbing when the car is lowered with a 15mm spacer in front, you can shave the vent blades in the front of the wheel area. |
05-06-2023, 02:28 AM | #15 | |
Rep 94
What if I went with 12 mm all around and lowered? Would it rub? |
05-06-2023, 02:44 PM | #17 | |
Rep 94
thompsac25711.00 |
05-07-2023, 05:32 PM | #19 |
Rep 1,661
Stock suspension. Rubbing is against the vent blades, as noted above. If too bothersome, I'll shave them or remove the spacers. Given the range of roads I drive daily, I don't want to lower the suspension.
05-07-2023, 05:40 PM | #20 |
Rep 94
Same here man. I'm in Canada and the roads here are crap. Lowering too much would not be fun.
05-14-2023, 08:02 PM | #21 |
Rep 475
Watched a few video's on spacers for g82's - most have smaller spacers up front and larger in the rear (10/12f and 15r). I see a lot of guys putting larger ones up front...?? better handling??
(on this site, that is..) |
05-14-2023, 08:45 PM | #22 |
Rep 1,931
No one puts spacers on for handling, just for looks and what works for you without rubbing.
