11-25-2022, 03:54 PM | #1 |
Rep 426
Downpipes install DIY
Hey all.
Having recently installed 200 cells by a shop, I am planning to revert to oem Downpipes myself. For some crazy reason, I think the car sounded better with the restrictive Downpipes. Now I have seen many install videos but they don’t emphasise the difficult aspects, where newbies like me are likely to get stuck. I especially am not looking forward to unplugging the o2 sensors and I dread the v-bands. Are there any tips for my first foray into this territory? I will using a proper lift for 4 hours. Any special tools for the v bands? How do I ensure install is perfect? I will be only my own and can’t enlist any help. Do I need a long wrench for the O2 sensor. I just want to ensure I have the correct ammunition. I don’t want to pay a shop to do it for me again. |
11-25-2022, 04:10 PM | #2 | |
Rep 1,447
Fugazii234.50 |
11-25-2022, 04:31 PM | #3 |
Rep 426
There is no fun in that, mate. I just want to be prepared and want to ensure i have all the tools for the job. I am usually very slow first time and want to complete the swap within 4 hours. I know I could get a shop to do it but after watching a few videos, I think i can do it. I have done most of the catback work on my car myself, including installing the MPE and I think downpipes are doable as well.
EatThatLunchBaby388.00 TopJimmy5474.00 |
11-25-2022, 04:40 PM | #4 | |
Rep 426
11-25-2022, 05:41 PM | #5 | |
Rep 1,447
madmedman276.50 |
01-18-2023, 05:11 AM | #8 |
Rep 426
Hello mate. I held it off for a bit. But was just thinking of doing it again. Where i hit a snag was that I couldn't identify all the O2 sensor connections. And also, need access to a levelled driveway where I can get the car up on all fours.
Would you or anyone have any idea if i am correct in thinking that there are three O2 sensor connections in the engine bay and 1 underneath the car? Please see pics attached. |
01-18-2023, 05:52 AM | #9 |
Rep 430
My plan is to just follow the oxygen sensor cables from the stock downpipes to wherever they are plugged in on the engine. I assume it will be apparent once you’re looking at it from the bottom. I’m going to find a wiring diagram before I attempt the work.
2022 M3 xDrive - BSM/Tartufo
madmedman276.50 |
01-18-2023, 06:11 AM | #10 |
Rep 426
I think I have to just follow the sensors as well. Might need a bit of in and out of the underside of the car. I did search for a wiring diagram but couldnt find one. I am planning to take some pictures when I attempt it and will post here. But its so damn cold these days that its almost impossible to get any work done on the car.
01-18-2023, 07:51 AM | #11 | |
Rep 570
Drives: '19 GLA45AMG(his) / '21 X3M40i
Say, just put the car on the lift for like an hour, pull out the cover, and familiarize yourself with what you're going to be up against. I use this technique for scenarios like the one you described, where you're not 100% sure of what you're doing. The only time I paid for an aftermarket install was when I found out that many people where breaking the 'stud bolts', 10 of them I believe, on a down pipe swap job for a GTR. I got lucky when the dealer mis-quoted me $300 for the job. When in fact, it was more like $700. By the time they where done with it, it took 3 days and 4 broken stud extractions. But boy, I'm telling you, no matter what you do to a GTR, the sound is just Caviar and Don P., for the ears Best of luck, and hopefully you'll get some DIY instruction with pictures for the rest of us.
Currently: '19 GLA45AMG grey (his) & '21 X3M40i DGM (hers) w/ JB4@Map1
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior 2014 BE GTR FBO/e85 |
01-18-2023, 08:05 AM | #12 |
Rep 430
This is a good idea. I’ll do that soon and post some pictures. I’ll tackle the project this weekend, hopefully.
01-18-2023, 09:09 AM | #13 | |
Rep 426
Another thing is that my driveway is at an incline, so raising the car is not possible there. I have used a lift in the past but the entrance to that is unusable as I always scrape my splitter lip everytime I use it. And for the downpipes, I need a whole day or more to do it slowly and take my time. But its inevitable, I have to do it the weekend after. |
01-18-2023, 09:11 AM | #14 |
Rep 426
Thanks mate. Will appreciate pictures. I dont think there is a good diy for G8x as most videos done show the connectors locations. Any tips will be appreciated. I also think an electric ratchet would be great to have and will cut the time down.
01-18-2023, 09:23 AM | #15 |
Rep 430
01-18-2023, 10:04 AM | #16 |
Rep 34
Drives: 2019 BMW M850i (Sold) 2022 BMW
I was in the same boat as you. Originally, I planned on installing them myself but there just isn't enough clearance on ramps. The job is 1000 times easier on a proper lift. My car is at the shop now getting Evolution Racewerks catless. I didn't want to cough up the extra $, but it is what it is.
madmedman276.50 |
01-18-2023, 10:11 AM | #17 | |
Rep 426
Thank you again for you help mate. |
01-18-2023, 10:14 AM | #18 |
Rep 570
I don't know if it's already mentioned, but don't forget to get an O2 sensor socket. It came very handy when I did my kid's O2 replacement on his Focus ST.
madmedman276.50 |
01-18-2023, 10:28 AM | #19 | |
Rep 426
Cheers. |
GixY2K517.00 |
01-18-2023, 11:36 AM | #20 | |
Rep 430
Then you move them over to the new DP’s. I know the instruction say to remove while still on the car, but that seems like more work.
GixY2K517.00 |
01-18-2023, 11:37 AM | #21 | |
Rep 430
Also, you would twist the wire if it’s still plugged in and you unscrew the oxygen sensor.
01-18-2023, 02:12 PM | #22 | |
Rep 426
I am very tempted to take the short cut and do akrapovic way so I don't have to unplug and worry about fishing them back up. But will obviously change tactics if the wires get twisted too much. |
