10-20-2023, 08:36 PM | #199 |
Rep 2,380
When you say negative effect, do you think it will damage anything. I noticed my car was making a funny vibration with valves closed until car warmed up going through neighborhood so I started leaving valves opened. I did a few hard pulls with valves closed but won't do it anymore.
Formerly Wyndi335I
10-20-2023, 08:50 PM | #200 | |
Rep 1,291
10-26-2023, 10:33 AM | #201 | |
Rep 191,145
i never heard of any issues with going WOT on closed valves, but why do it if lowers performance and puts more stress on the engine/turbo.
10-26-2023, 05:23 PM | #202 |
Rep 164
Drives: 2023 G80 M3 Competition Xdrive
I installed the valve controller for this reason. My local track has a 95db limit so open valves in sport would put me over that. Hoping the half open position will pass tech.
Instagram- @G80M3dia
Current: '23 G80 M3 Comp - BG over FR Past: '16 Mineral Grey M235i, '03 e46 330i |
10-27-2023, 11:19 AM | #203 | |
Rep 269
I drilled through the solid plugged holes in the trunk that conveniently others already have a grommet for. I did not yet install a grommet but may in the future. Need to remove the car battery in order to fit a regular size drill in this space. The sound difference is night and day, combined with a midpipe. I think the controller is a must for everyone, but I do wish I had the grommets in the first place.... |
10-27-2023, 11:26 AM | #204 |
Rep 91
They aren’t tho. My sst is set to remember the last operation so if I don’t remember to close the valves when I park, the next cold start has the valves open
10-27-2023, 12:21 PM | #205 |
Rep 1,938
Then set it to always start in the oem position, which is closed.
10-28-2023, 11:55 AM | #206 |
Rep 191,145
+1
10-29-2023, 05:27 PM | #207 |
Rep 1,665
Do any valve controllers work with the OEM cabin exhaust button or do they all need a separate remote?
18' F80 6MT, 991.1s cab PDK, F83 6mt, 996 C4S cab 6mt, F30 328iM 6mt
E60 M5 SMG, E39 M5, E46 M3 cab 6mt, E36 M3 5mt |
10-29-2023, 07:12 PM | #208 |
Not my first rodeo
810
Rep 481
10-29-2023, 07:22 PM | #209 |
Rep 1,291
There is also a less expensive Chinese product that works with the oem button, and actually has a better install than the Awron. Haven’t seen anyone try it yet though.
https://www.aliexpress.com/item/1005005821116284.html |
NicolasB809.50 |
10-29-2023, 07:26 PM | #210 |
Rep 1,665
Thanks. I’ll check it out. First I need my car delivered, then a mid pipe and some other mods before I consider a valve controller.
NicolasB809.50 |
10-30-2023, 07:50 AM | #212 | |
Not my first rodeo
810
Rep 481
10-30-2023, 11:10 AM | #213 | |
Rep 191,145
With SST you can force the valves open, close, stock (which uses the exhaust button), or at 50%. You can also use the mirror buttons to control the valves. I don't feel that with all these features, the exhaust button is worth it
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 10-30-2023 at 11:33 AM.. |
NicolasB809.50 |
11-02-2023, 12:27 PM | #214 |
Rep 236
I went back and forth between the Dahler and SST but ultimately went with the latter given the price and what appears to be an easier install via the trunk since I don’t have access to a jack or lift. Thank you to mike@x-ph.com for the hookup; looking forward to installing and hearing the difference
11-02-2023, 01:58 PM | #215 | |
Rep 191,145
11-05-2023, 06:29 AM | #216 |
Rep 344
Just got my sst controller from Mike. Shipped out the next day and I had it 3 days. Top notch service from Mike.
11-06-2023, 03:23 PM | #217 |
Rep 191,145
Thank you
11-06-2023, 06:16 PM | #218 |
Rep 236
What size nut/screw did you use to remove the cover? I’m a total novice when it comes to tools and I accidentally pushed the grommets into the cover wells
11-07-2023, 07:35 AM | #219 |
Not my first rodeo
810
Rep 481
11-07-2023, 09:07 AM | #220 |
Rep 186
Drives: F90, G80
