      03-21-2021, 08:48 PM   #45
duercos
duercos's Avatar
201
Drives: F36>F16>G30
Best color to make the grills look good IMHO
      03-21-2021, 09:17 PM   #46
Montaver
Montaver's Avatar
Drives: G87 M2 & M340i LCI
Originally Posted by 440xiGCMSport2 View Post
Originally Posted by frankiebones View Post
Originally Posted by Teutonic View Post
why people will do that is out of my understanding. Looks out of place, not to mention how the heck you will clean all the residuals, sand, mud and everything that will retain moisture if you do that?
I have a hard time cleaning it as is...
Lowering? Well it does have performance benefits even if you don't like the aesthetics.
Can you tell me of the performance benefits of just adding lowering springs?
There are zero performance benefits to lowering springs. All it does is reduce suspension travel, which means the dampers engage the bump stops earlier reducing the cars ability to absorb energy through the suspension i.e reduces grip. Lowering springs are garbage, and in this case aesthetically it doesn't even look good. Always amazes me people drop $80k on a car then cripple it's handling with cheap springs. It's effectively throwing away thousands of hours M division engineering on suspension and kinematics for nothing.
Appreciate 16
WWM3968.00
Teutonic2709.00
THEROK1267.50
Davil6524.50
Scorp!on1511.50
thurston215.00
m20e30871150.00
Bon F80127.00
naywa01280.50
FrozenGT1116.50
safridi66.00
DaFish157.50
      03-21-2021, 09:46 PM   #47
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
2 things...
1. In my experience with lowering springs on bmw's (E46, E92, F30, F87) the passenger rear (LHD) tends to sit a little higher (maybe 1/4-1/2 inch) than the driver rear for whatever reason, so it's important to get either adjustable springs, or to have non-adjustables that account for this. Whether or not this applies to the G80 is unknown, but I think you guys should have measured all 4 corners to see the final height, not just two corners to see the amount of drop.
2. The fronts are definitely sitting higher than the rears and need more of a drop than the rears. I'd say 1.25-1.5 front and .75-1.0 rear would be perfect.
      03-21-2021, 09:58 PM   #48
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11490
Drives: E90M/E92M/M4GTS/M4GT4/X5M
Literally exactly how I feel
Montaver2182.00
naywa01280.50
DaFish157.50
      03-21-2021, 10:02 PM   #49
GFK007
Drives: 2014 m235i
Is there a drop that's less aggressive than this? The wheel gap on the rear wheels (with stock suspension), is optimal. Really just want to replicate that in the front.
MG on CR M235i, mods to come...
(gone but not forgotten) 2011 e90 M Sport - M-Tech Carbon Diffuser, OEM Carbon Trunk Spoiler, 20% tint, black reflectors, black OEM grille, LUX white Angel Eyes.
      03-21-2021, 10:16 PM   #50
Teutonic
Teutonic's Avatar
No, it doesnt. You don’t push that car to the limits where you will benefit from that difference of that center of gravity.
Secondly, it comes with some negatives and punishment for the chassis and the comfort.
Forget about being unable to wash it under and put high pressure wash in there to prevent future rust and clean the wheel well.
It looks out of place as the wheel arch of the car is not in sync with the wheel anymore; looks like is broken, and has no benefits for a normal user.
      03-21-2021, 10:24 PM   #51
OSee
Drives: M2 Sold
The car in your avatar is dropped within an inch of its life.
      03-21-2021, 10:25 PM   #52
OSee
Drives: M2 Sold
Seems like almost everyone in here is in agreement that the rear is too aggressive. Borderline slammed.
      03-21-2021, 11:16 PM   #53
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25117
Wow! Such angst over springs.
JTO245276.00
      03-22-2021, 12:01 AM   #54
Teutonic
Teutonic's Avatar
Right. Except that M GT race car was made for that and the whole body was build for that. Secondly, the springs were ENGINEERED BY M FOR THAT.
Not last, the body is still beautiful and takes care of the aesthetics too - very important for the whole image -, as the wheel arch still follows the wheel which obviously is not “sinked” like the car is broken...
Plus, that car is “naked” with no carpet wheel well liner and looked after in a rigorous way, not to mention the weels are swapped daily so it can be cleaned properly...
Anyway, that car has a purpose and is engineered for that purpose, not a wanna be.
I respect however someone’s opinion about this or his option to do it.
I just expressed my opinion as I do not like it at all, plus is detrimental to this car from comfort to maintenance. And if you run a RFT on that car and for some reason you get a a flat with a shredding tire, you can kiss godbye that fender...
      03-22-2021, 01:31 AM   #55
440xiGCMSport2
Drives: EB440xiGC
Ok wasn't wrong thinking bunch of people just want to undo what M spent a lot of time on. From my experience the only thing that helped performance was a very good set of properly done coilovers with parts to adjust for lowered stance, an not just any cheap Coilovers.
Just thought the other guy knew something I didn't know or he needed to be informed.
Montaver2182.00
      03-22-2021, 01:38 AM   #56
440xiGCMSport2
Drives: EB440xiGC
Lower center of gravity.
Lower center of gravity doesn't mean anything though if your suspension travels is all out of sorts and the suspension geometry is also out of whack due to the lowered stance. Correct me if I am wrong, but this is from my experience when I tried just springs, then added shocks with springs than eventually to real good set of coilovers.
      03-22-2021, 01:44 AM   #57
Davil
Davil's Avatar
Australia
6525
Drives: M2 CS, 18 Vantage AMR, 00 WRX
Exactly this. This car will handle like a turd. However, the type of audience this type of mod attracts are unlikely to notice and will be completely happy with it.
Such a shame as the car handles brilliantly.
To me, it's (yet) another case of this.
      03-22-2021, 03:08 AM   #58
Scorp!on
Switzerland
1512
Drives: BMW M3 G80 MT BSM
Well BMW still offers the MP-HAS and I think this one will be tested by the engineers there to have a perfect fit, functionality and plus I can go 10mm lower (that's all I want).
I for myself find it rubbish when it's too low (take a look at the F80/F30 board, jesus some cars there scratch the floor thats just not good looking at all when the weel goes IN the fender).
A small drop with a official BMW piece.
done.
      03-22-2021, 05:10 AM   #59
BimmerFix
BimmerFix's Avatar
Drives: 24' M3 Competition RWD
MP-HAS or nothing for me.
It's perfect and engineered by M division.
I went through the trials & tribulations on my F82.
Everything is a compromise, unless you go full blown Coilovers or MP-HAS
///M3 2024 G80 Competition - Starting Lineup
///M4 2019 F82 Competition , 2019 G30 540i , 2008 E92 335i - Retired
Scorp!on1511.50
      03-22-2021, 05:19 AM   #60
frankiebones
frankiebones's Avatar
5299
Drives: Fire Orange G80 6MT
No, it doesnt. You don't push that car to the limits where you will benefit from that difference of that center of gravity.
I do push cars to the limit (not on the street). I did find my F80 handled noticeably better after lowering springs were installed.
You're making a subjective statement about the appearance of a lowered car and for the most part I agree with you. I'm not a fan of the "slammed" look. I do feel a modest drop and spacers helps any car look better and I say that as a 39 year old Executive and not a "boy racer."
SMB M3 CS (gone)
YMB F80 6MT (gone)
Sedan_Clan25116.50
      03-22-2021, 05:22 AM   #61
frankiebones
5299
I am doing M performance springs at the recommended height (.4" drop in front if I recall correctly). I am not lowering 2.9999" to create a slammed look. I am not adding spacers to throw off overall suspension geometry. There is a difference but please correct me if I'm wrong.
SMB M3 CS (gone)
YMB F80 6MT (gone)
      03-22-2021, 06:27 AM   #62
Scorp!on
Switzerland
1512
Well there is a difference if you buy a full KW tested suspension or the MP-HAS or you just smack some cheap coilovers to get the car lover.
KW and MP-HAS are adapted for the car (at least for sure MP-HAS, not so much into KW to be honest).
But what I at least see a lot is that car's are just put insanely low to look aggressive but can't even drive properly because they touch everywhere.
this is ridicolous.
Either you let it original or you get it done properly and this costs money (not the 300$ crap coilovers).
If I get it correctly you got the MP-HAS, then for sure it has better handling.
      03-22-2021, 08:39 AM   #63
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
After test driving the G80, it's MP-HAS or nothing. Stock is extremely good IMO, unless your going proper CO, I would stick with MP or maybe KW since they are the ones making the MP.
      03-22-2021, 08:53 AM   #64
naywa01
naywa01's Avatar
United Kingdom
281
Drives: BMW M4 DCT Coupe
[QUOTE=frankiebones;27376187]
Did it make a difference in lap time though, I mean if you're talking about hard track use and (very incrementally) lowering the centre of gravity, that's what really counts right?
Otherwise it's really just aesthetics, as the car is never going to get to that extreme edge of the performance envelope where a millimetre or two of CoG height (not ride height) will make the difference on the road...
Personally I'm more of a 'drive it stock' guy, I don't buy into modding cars the instant I buy it and if it's really that bad in the first place, why buy it? Each to their own I guess.
Anyway just saying as a 40-something guy
      03-22-2021, 09:03 AM   #65
lixiang7349
lixiang7349's Avatar
Drives: customE50Tune
Originally Posted by Driver_X View Post
Originally Posted by lixiang7349 View Post
Arent those stock wheels
Yes they are. I suppose the aftermarket wheels are in the shots of the rolling car
Lol 😂
      03-22-2021, 09:03 AM   #66
fl1by
Drives: G80, Raptor, STI and C8
Thumbs up
On a very smooth track (autocrossing) they might be a benefit, or on poorly sorted out suspension, but otherwise I completely agree
Tags
ast suspension, g80, g80 lowered, g80 m3, isle of man, titan7
