04-10-2024, 11:47 PM | #1 |
Rep 1,286
BMW M3 CS | Nordschleife HOT LAP 7.27,19 min | sport auto
Driver: sport auto's Test Driver Christian Gebhardt Tyre: Michelin Pilot Sport Cup 2 Only 1 sec faster than M4CX (7.28,57 min) on same tires.
F82G82AND149.50 Limegrntaln13521.00 BEAR-AvHistory-2302.50 Hedoniste3837.00 pc9343.50 stormlv932.00 Ezra168219.00 |
04-11-2024, 10:00 AM | #2 |
Rep 6,991
Nice, 184.54mph (297kmh) blinked up on the long strait.
YT: G Dubyou |
04-11-2024, 10:14 AM | #3 |
Όλα ρόδες
760
Rep 560
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
The relevant publication data.
04-11-2024, 10:36 AM | #4 |
Rep 901
Now imagine how much time you can make up by doing just a simple Stage 1 flash to it to get a little more power or even one with Stage 2. That low 7 can easily be hit, maybe even knock on 6.
04-11-2024, 11:36 AM | #5 |
Rep 1,286
Interesting….a bit more significant difference on Hockenheim…compared to marginally better on the ‘Ring
04-14-2024, 02:59 PM | #6 |
Rep 407
I'm a bit confused by this 'ring result for the CS. Specifically, with the same driver, the M3 CS (with Cup 2 tires) was only 2 seconds faster than a regular M4 Comp xDrive with street tires (PS4S presumably). Assuming the Cup 2 tires are good for at least a second or 2 on the 'ring, why would a regular M4 xDrive have the same performance as the M3 CS which is both lighter and has at least 20 more HP?
This is in rather stark contrast to the performance of the M4 CSL which is a full 10 seconds fast than the M3 CS (and in this case, both cars were using Cup 2 tires). Of course, the M4 CSL is a few hundred pounds lighter, but has the same HP. Any thoughts? |
04-14-2024, 03:36 PM | #7 |
Όλα ρόδες
760
Rep 560
Print says that the M4 Comp drive was on Cup 2s as well.
You do have a point though. |
04-14-2024, 03:38 PM | #8 |
Rep 3,416
Trevorr88.50 Needsdecaf6643.50 |
04-15-2024, 01:40 AM | #10 |
Rep 399
[QUOTE=irablumberg;31072605]I'm a bit confused by this 'ring result for the CS. Specifically, with the same driver, the M3 CS (with Cup 2 tires) was only 2 seconds faster than a regular M4 Comp xDrive with street tires (PS4S presumably). Assuming the Cup 2 tires are good for at least a second or 2 on the 'ring, why would a regular M4 xDrive have the same performance as the M3 CS which is both lighter and has at least 20 more HP?
This is in rather stark contrast to the performance of the M4 CSL which is a full 10 seconds fast than the M3 CS (and in this case, both cars were using Cup 2 tires). Of course, the M4 CSL is a few hundred pounds lighter, but has the same HP. Any thoughts? I’ve just traded in a 2022 G82 M4CX thati owned for 2+ years for a G80 M3 CS and I can confirm the the CS is way quicker than the M4CX - no doubt about that - so a second doesn’t seem enough of a difference to me |
04-15-2024, 01:46 AM | #11 | |
Rep 309
bwoodahl235.00 |
04-15-2024, 07:20 AM | #12 |
Rep 407
Thank you for that clarification. I don't have access to the magazine, so I just assumed that they tested with the factory equipment. At least in the US, I don't think Cup 2 tires are a factory option for the M4 Cx.
04-15-2024, 07:23 AM | #13 | |
Rep 407
[QUOTE=RichardGM4;31073560]
04-15-2024, 07:39 AM | #14 |
Rep 901
They’re not that much different on the suspension side of things. Front knuckles change the camber out a bit more and that’s about it. I know the CSL doesn’t have a ton of differences vs the M4 setup.
04-15-2024, 11:32 AM | #15 | |
Rep 1,286
If lap times are now not a good indication of performance, but then I don’t know what is
HudsonHornett1258.00 |
04-15-2024, 02:00 PM | #16 |
Rep 407
Then quite surprising that the M4 CSL was 10 seconds faster than the M3 CS and 12 seconds faster than the M4 Cx.
04-15-2024, 02:57 PM | #17 |
Rep 83
Few seconds here and there on 26km or 15 mile track is nothing. It could be weather, it could be temperature. It is a 15 mile track guys, may be a bit of exaggerating but you can probably have 4 seasons in 1 single lap 😀. On 2 mile track like nelson ledges in ohio 2 secs is huge. On a 4 mile track like road America 2 sec gap is not that much at all. We are talking about 15plus mile track here... think about it. Lap times can vary significantly interms of seconds but percentage wise not that much. Unless same driver takes the 2 cars out on a same day on same tires etc all these lap time stuff is nothing more than confusing the enthusiasts.
04-15-2024, 11:47 PM | #18 |
Rep 901
04-16-2024, 09:57 AM | #19 |
Rep 210
Well it's essentially the same car, with the same engine. The weight difference is fairly trivial, and so is the extra power (which is only available high up in the rev range). It's not surprising that the lap times are close.
04-16-2024, 10:10 AM | #20 |
Rep 210
04-16-2024, 10:11 AM | #21 | |
Rep 71
Nurburgring is a highly technical track. A power bump would probably add like 2-3 seconds. Would only help in that long straight. |
04-16-2024, 12:00 PM | #22 |
Rep 309
The Ring is a great place for manufacturers to test their cars during development, but it's overrated as a benchmark for claiming one car is better or faster than another (unless the difference in times is huge). I never hear pro drivers make such comparisons, when they race at the Ring their laptimes often vary by multiple seconds. Any car's ring time could be improved by renting out the track for a week and using pro drivers to constantly run laps and burn through tires until the track conditions are perfect and the driver has a mostly error free lap so they get a phenomenal laptime.
