      10-08-2023, 04:32 PM   #1
Donatello.
How's My Driving?
Donatello.'s Avatar
1114
Drives: Hellcat & Miata
Question Mini LED 7444/7443 amber bulbs?
Been trying to find a LED amber 7444 or 7443 bulb that has a built in resistor for no hyper flash vs add an external myself, but every one I've tried is too tall for the housing or does not have a built in resistor.
Are there any "mini" bulb options that meet my criteria? This is for a 2009 Mazda6 FYI
2018 Charger Hellcat
2019 Miata 30th Anniversary
2021 CX-5 Signature
2009 Mazda6
      11-27-2023, 05:20 PM   #2
Donatello.
How's My Driving?
Donatello.'s Avatar
1114
No one?
2021 CX-5 Signature
2009 Mazda6
      11-27-2023, 11:03 PM   #3
Sedoy
Drives: F10
Morimoto XB LED BULBS are pretty good quality and do not require a resistor, but they are pricy. I'm sure if you search and try you might find a cheaper option but if you are in a rush those are premium bulbs:
https://www.headlightrevolution.com/...ree?quantity=1
      11-28-2023, 09:02 AM   #4
Donatello.
How's My Driving?
Donatello.'s Avatar
1114
THanks, but too tall
2021 CX-5 Signature
2009 Mazda6
      12-08-2023, 09:26 AM   #5
Sedoy
Drives: F10
Yeah, thanks for using ChatGPT, half of those bulbs are either BS or don't exist. For example, send me the link for "Hikari 7443 Amber LED Bulbs with Built-in Decoder Chip"? The only legit ones are Auxbeam but it's 7443 (but it's pretty massive, not mini) and Lasfit.
Originally Posted by MajaswiEmmar View Post
Yes, there are a few "mini" LED amber 7444 or 7443 bulbs that have a built-in resistor for no hyper flash. Here are a few options:
Auxbeam 9003 Amber LED Bulbs with Built-in Resistor: These bulbs are small and compact, making them a good option for tight spaces. They also have a built-in resistor, so you won't need to add one yourself.
Truck-Lite LED Amber Turn Signal Bulbs with Built-in Resistor: These bulbs are also small and compact, and they have a wide beam pattern for better visibility. They also have a built-in resistor, so you won't need to add one yourself.
Lasfit 7443 Amber LED Bulbs with Built-in Canbus Resistor: These bulbs are designed to work with CANBUS systems, which can sometimes cause hyperflash with LED bulbs. They have a built-in resistor that helps to prevent this issue.
Hikari 7443 Amber LED Bulbs with Built-in Decoder Chip: These bulbs have a built-in decoder chip that helps to prevent hyperflash and other issues. They are also compatible with most vehicles.
All of these bulbs are designed to work with a 2009 Mazda6, and they should help to eliminate hyperflash.
Donatello.1113.50
      12-08-2023, 09:26 AM   #6
Donatello.
How's My Driving?
Donatello.'s Avatar
1114
Appreciate the post. Truck-lite seems to just make complete housings. Found no 7443 from Hikari & the others are too tall
2021 CX-5 Signature
2009 Mazda6
