Classifieds Sponsors Classifieds Engine / Drivetrain / Exhaust / Bolt-ons
      10-17-2022, 06:44 PM   #1
StudioRSR
Drives: AW G82 RSR "TD4"
\\\ StudioRSR - CSF G8x Heat Exchanger //
Managing IAT's (intake air temperatures) is the key to making consistent power in any driving environment, and StudioRSR was proud to Test & Co-Develop the
CSF G8x M3/M4 Heat Exchanger on their own G80 M3 Track build.
StudioRSR is CSF's Preferred Dealer & Installer for all G8x M3/M4 Cooling upgrades.
Purchase your CSF Heat Exchanger on StudioRSR's webstore by clicking the link below:
https://studiorsr.com/collections/g8...heat-exchanger
Please contact StudioRSR by phone or email for more information or to place your order.
p: 1-844-991-5582 | e: info@studiorsr.com
The more power you make, the more heat is produced...and this is where the CSF G8x M3/M4 Heat Exchanger feeds your S58 with more efficiently cooled charge air temperatures. The cooling system of the S58 is reliant on the efficiency of the front mount heat exchanger. This is where upgrading to CSF's heat exchanger becomes a huge advantage!
  • 2-Row, 42mm Ultra-High-Performance Core
  • Significantly Reduces Intake Air Temperatures (IATs) for Maximum Performance (with Faster Heat Soak Recovery)
  • Improves Air Flow to the Rest of the Cooling System for Lower Engine Coolant and Engine Oil Temperatures
  • 6.5mm Tall Multi-Louvered Fin with CSF’s Exclusive B-Tube Technology
  • CNC Machined Mounting Brackets and OEM Style “Quick Connect” Inlet/Outlet
  • 100% All Aluminum TIG-Welded Construction
  • Includes Black Rock Guards (upper and lower) & Transmission Cooler Mounting Kit
  • Upper and Lower Rock Guards for Manual Transmission
  • Upper Rock Guard and Transmission Cooler Mounting Kit for ZF8 Auto
  • True Plug-and-Play “Drop-in Fit” Installation Requires Absolutely No Modifications
  • 2-Year Limited Warranty
  • 1-Hour “Mirror Finish” Hand Polish
  • Tested and Proven by CSF’s Global Network of R&D Partners, Including Leading Time Attack Teams, Tuners, and Turbo Kit Manufacturers
Proudly tested and co-developed with CSF at StudioRSR
Rhythm | Speed | Racing
www.studiorsr.com | email: info@studiorsr.com | call: 1-844-991-5582| Instagram: @studiorsr| StudioRSR G8x M3/M4 YouTube videos
For updates on your order, please email updates@studiorsr.com
Tags
cooling, csf heat exchanger, csf radiators, intercooler, radiator
