03-20-2024, 08:20 PM | #2 | |
Rep 2,614
I think 99% of people would say no. I optioned it though, mostly because I was checking every option (except CCBs and buckets). Last edited by Berzerker; 03-20-2024 at 08:45 PM.. |
mjj163.00 |
03-20-2024, 08:36 PM | #3 |
Rep 6,961
Its a liiiitle higher than 169, but, yes, they have an M Drivers Track day on the track calendar. Its more like a half a day. You can put it toward an upgrade for a higher package at the track. And the speed limiter bump, said to be at 184. I almost got there, but, I ran out of runway. Also, keep in mind, over 150mph, the car wont shift into 8th gear, by design.
YT: G Dubyou |
03-20-2024, 08:37 PM | #4 |
Rep 726
I'm going to second this, but at the same time say it was worth it to me.
You're basically paying $750 to increase the speed limiter. The other $1750 pays for the 1-day M School. With that said, there are only two ways to increase the speed limiter above 155: M Driver's Package or unlock the ECU and get a tune. Why was it worth it to me? Because if you do not get the M Driver's Package there is absolutely no way to retrofit it. Of course, in hindsight I shouldn't have done it because I ended up tuning my car anyway, but at the time I didn't think that I was going to do that. TL;DR - If you plan on unlocking and tuning the ECU you absolutely SHOULD NOT get the M Driver's Package. If you do not plan on unlocking and tuning the ECU, it is the only way to increase the speed limiter.
mjj163.00 |
03-20-2024, 08:45 PM | #5 | |
Rep 2,614
Limegrntaln13469.00 |
03-20-2024, 08:47 PM | #6 |
Rep 6,961
In BMWs format, “I believe” it’s written as 296kmh.
YT: G Dubyou |
Berzerker2883.50 |
03-20-2024, 08:47 PM | #7 |
Rep 96
Thanks all for the feedback. I expect I will have the car tuned at some point like I have on 3 previous vehicles.
03-21-2024, 11:02 AM | #8 |
Rep 4,109
Drives: BMW M3
I didn't option this because I don't plan to take the car over 155mph. I've done the BMW M track days and they are awesome. I sign up for one when I want to flog a car.
Charles
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
Limegrntaln13469.00 T0RM3NT3640.50 |
03-21-2024, 11:42 AM | #9 |
Rep 6,961
You need to send the ECU out to be flashed. A JB4 or Racechip won’t remove the limiter.
YT: G Dubyou |
T0RM3NT3640.50 |
03-21-2024, 12:10 PM | #10 |
Rep 589
Sounds like you can save yourself some money that can be put towards a tune.
03-21-2024, 01:56 PM | #11 |
Rep 123
To verify, I've reached the restricted top speed of my car on track which on the car speedo read at 255 KPH, about 158 MPH.
However, the reading from my Racebox indicated 250 KPH on the dot, which is 155 MPH. |
