03-19-2024, 08:04 PM | #1 |
Rep 7
Just got my G80 xdrive back, 770hp tune on e85. Did 1.8 60ft, 6.79 1/8 mile at the drag strip which I think its terrible. 1st gear launch, R888Rs in the back, stock tires in the front. Looking for advice on how to improve my launch skills!
03-19-2024, 08:27 PM | #2 |
Rep 532
Either terrible track prep, or you just simply overpowered the tires! That's a lot of power to ask a road racing tire to hook, especially on a less than stellar prepped track surface. R888R's HAVE to be hot to hook. I'd either try to make sure you have heat in the tires, or try a set of drag radials. BTW... What was your mph in the 1/8th?
Ulises0.00 |
03-20-2024, 08:18 AM | #7 |
Rep 989
Drives: 2024 M4 Comp X-Drive
With your power you might actually go faster brake torquing the car and launching in second gear with DSC full off and car in 4WD.
It should save some wheel spin and you won’t have that tenth delay on the 1-2 shift. Something to try next time.
03-20-2024, 08:35 AM | #9 |
Rep 7
Gotta give it a try. Thanks man!
03-20-2024, 08:37 AM | #10 |
Rep 7
At what rpm you suggest considering power
03-20-2024, 11:18 AM | #11 |
Rep 989
Whatever amount of throttle that will prevent you from pushing through the brakes.
If you go S3 on transmission settings you will have to shift it on your own as I don’t believe launch control will engage on a second gear start and trans won’t shift itself on S3. (Depending own your tune you might have second gear LC enabled though)
Ulises0.00 |
03-20-2024, 12:48 PM | #12 | |
Rep 532
03-20-2024, 12:52 PM | #13 |
Rep 589
Another tip I've seen is to set the suspension in comfort to allow for more squat and weight transfer on launch.
03-20-2024, 01:09 PM | #16 |
Rep 989
Yup that helps for sure. I went a 1.6 sixty (stock ‘24 X-Drive) on a moderately prepped track with the suspension in comfort. It still spun several feet but it definitely was better in comfort suspension versus the other modes.
03-20-2024, 07:15 PM | #17 | |
salty cowboys fan
6158
Rep 3,407
ChrisM41623.00 |
03-21-2024, 10:38 AM | #19 |
Rep 2,614
You typically want 1st on xDrive, RWD launches by default in 2nd, afaik.
03-21-2024, 10:50 AM | #20 |
Rep 989
At stock power levels yup but over 700hp you can sometimes go faster with a 2nd gear start due to better traction and time saved from the 1-2 shift.
Ulises0.00 |
03-22-2024, 08:20 AM | #21 |
Rep 1,286
I’m confused, I thought S3 is required for LC to engage and it would shift on its own
03-22-2024, 08:37 AM | #22 |
Rep 652
You should definitely do a burnout to warm up the tires and get all the crap off that’s stuck to them.
If you’re using LC you may want to trying getting off the brake before you reach full boost/RPM to manage the power/wheel spin. A bit more. |
