03-15-2024, 01:00 AM | #1 |
Rep 192
Hey everyone, I'm seeking some assistance and guidance. My M4 is scheduled for its break-in service on Tuesday, and I'd like them to address a few concerns:
1. There's a persistent whistling noise coming from the passenger side at speeds over 50mph. I suspect it might be related to the passenger mirror based on some online posts. Has anyone else experienced this, and if so, how was it resolved? 2. For fellow manual transmission drivers: I've noticed a peculiar behavior when driving under 30 mph and coming to a stop while depressing the clutch. Before reaching a complete stop, while brakes are pressed and clutch is pressed in, the engine's RPM drops rapidly and seems like it might stall before quickly recovering. This occurs regardless of whether the A/C is on or off. Interestingly, if I depress the clutch before braking, this issue doesn't occur. I've driven manual cars all my life and never encountered this before. While Shaneartistry provided some helpful insights, I'm curious if others with manual transmissions have experienced this as well. Could it be related to throttle control, sensor inputs, or software calibration, as Chat GTP suggested? 3. On a lighter note, can anyone else relate to the frustration of having the steering volume controls located on the right side? It feels awkward to operate them while driving manual, with my right hand on the gear stick and left hand on the steering wheel. 4. Also , may just be being an enneagram 1 perfectionist, but is seems my steering wheel is slightly malaligned and drive me crazy, or it the curve new screen making it look off. I greatly appreciate your time and any help or advice! 🫡🙏 |
03-15-2024, 01:23 AM | #2 |
Rep 154
#2 how low are the rpms when you are coming to a stop while still in gear?
#3 there was a day when we drove manuals without steering wheel controls.
2024 M3CX BRG/KO
03-15-2024, 01:28 AM | #3 |
6918
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
1. Whilsling from the mirrors seems to be pretty common although it's odd you're hearing it on the passenger side. Most people report it on the drivers (myself included). Have never seen a solution for it.
2. I don't have a manual but I would assume chatgpt knows even less about your car than the average Sales Associate at a BMW Dealership. 3. Are you really adjusting your volume that often? Do you rest your hand on your shifter the whole time while your drive? You shouldn't do that. Even so, there isn't much you can do about the placement of volume controls on your steering wheel. 4. Every BMW I've ever had has had a misaligned wheel to some degree. A couple recent threads on this as well if bugs you enough to want to fix. Good luck and enjoy the car. |
Ezra168214.50 |
03-15-2024, 06:28 AM | #4 |
Rep 273
Have a manual, I don't experience question 2. It could come down to driving style. If I'm braking from 30ish MPH, I'll downshift to 2nd gear 95% of the time. Shift to second, revs go up as expected and then drop while slowing down and eventually throwing it into neutral.
Sounds different than your process maybe? |
03-15-2024, 06:57 AM | #5 |
Rep 3,291
I haven't experienced your question 2 in the three years I've had this car but, like elkid, I'm generally not still in 3rd gear at the stop.
I haven't noticed that my steering wheel is misaligned, so either it isn't or I just haven't noticed. I went from no steering wheel volume control ever to BMWs, so I'd find it annoying to have it on the left. Probably. |
03-15-2024, 08:25 AM | #6 | |
Rep 192
Steering wheel control…well let’s be honest the whole car itself and this forum are defnitely first world problem I agree 😊 |
03-15-2024, 08:33 AM | #7 | |
Rep 192
Have you ever driven a manual? I don’t necessarily have my hand on the shifter at all times but most of the time I do until I’m at whatever speed I’d like to cruise at, or even at a stop light, definitely when I’m racing or having a spirited drive, so there’s often times I’d like to bump the volume a few notches. I can’t see a benefit to having cruise control on left verse right so seems at least for those of us with manual better for cruise control on right and volume on left …but again I realize it a first world problem. |
03-15-2024, 08:42 AM | #8 | |
Rep 192
03-15-2024, 08:47 AM | #9 | |
Rep 273
Idk, I'm by no means an expert manual driver, but I am experienced. Certainly interested to hear what other folks have to say |
03-15-2024, 11:26 AM | #10 |
Rep 752
Re the MT, I haven’t noticed this and with the foot+ of snow here, won’t be able to drive the car for a few days.
But that doesn’t sound normal. I suspect that the dealer will only be able to verify that all of the operating parameters are within spec and, if so, call it normal vehicle operation. |
03-15-2024, 12:44 PM | #11 | |
Rep 154
2024 M3CX BRG/KO
03-15-2024, 03:20 PM | #12 |
Rep 273
03-15-2024, 03:31 PM | #13 |
Rep 192
Perhaps I’m not being clear…this is happening when the clutch is pressed in. It is causing the RPMs to drop that low. They aren’t that low before the clutch is depressed. As long as the clutch is pressed in, a manual car shouldn’t stall….
03-15-2024, 03:32 PM | #14 |
Rep 672
1) I have a 2023 manual with the same whistling sound coming from the passenger side. I’ll be taking my car in for service Monday and will report back with what bmw says.
3) the volume controls being on the right side of the steering wheel drives me crazy, because if this I never use them. Never had this issue before, only bmw. |
Ezra168214.50 |
03-15-2024, 05:08 PM | #15 | |
Rep 192
Glad I’m not the only one who thinks control should be on other side 😊 |
FrankieNuo1219.00 |
03-15-2024, 09:52 PM | #16 | |
Rep 17
Forzanerazzurri6918.00 Hydrostream4.50 |
03-15-2024, 10:30 PM | #17 | |
Rep 154
Are you planning to take it in?
2024 M3CX BRG/KO
03-15-2024, 11:56 PM | #18 | |
Rep 851
elkid23265.00 |
03-16-2024, 01:36 AM | #20 |
6918
Rep 3,277
spammysammich1583.50 Hydrostream4.50 |
03-16-2024, 07:33 AM | #21 | |
Rep 735
And remember when volume wasn't on the steering wheel? Were people reaching across with their left hand to fiddle the volume while shifting with their right? 🤯 |
03-16-2024, 07:38 AM | #22 | |
Rep 3,291
