      03-16-2024, 11:32 AM   #45
Crogalin
Crogalin's Avatar
Drives: 2022 BMW M4C
When you all changing the pads, are you just swapping the pads? Is there anything that needs to be done with the rotors?
      03-16-2024, 12:29 PM   #46
mike@x-ph.com
mike@x-ph.com's Avatar
if the rotors are still in good condition you don't need to anything with it
https://x-ph.com/sale/
Phone number 702-494-9435
      03-16-2024, 09:26 PM   #47
Drives: S4
Check surface for even/flat wear and make sure the outer edge doesn’t have an excessive amount of lip edge to it. If that’s all good, you can run another set of pads usually.
      03-30-2024, 03:36 PM   #48
White340XDriveInCt
Drives: 2023 Tanz M3 Comp
Originally Posted by cozye View Post
Worse than the squealing is the red brake dust. isweep 1500 pads solves both problems. I can drive hundreds of miles now and my wheels still look clean.
Heading in for an aftermarket wheel swap in a few weeks and considering these isweep pads...car has 10k miles on it (and otherwise perfect) so these new pads can just be installed on existing rotors, no prob? (Just noticed others had answered this up above...thanks!)
r33_RGSport13051.50
cozye347.50
      04-05-2024, 12:31 AM   #49
M4XC-MT
M4XC-MT's Avatar
Drives: BMW G82 M4, F82 M4, E46 M3
[QUOTE=M4CXG82;30966966]I am curious how many miles has everyone gone without hearing the screeching on their new brake pads.
Please state the brand of the brake pad as well, Thank you
I'm on the stock pads. did two days at Willowsprings raceway last October in my 23 M4XC with carbotect endurance pads, put the street pad back on and the brakes haven't squealed since.
      04-05-2024, 01:38 AM   #50
davidmct-M3
Drives: BMW 440i with MPSSK
Standard brakes. No issues. I do clean them with iron remover every few weeks a did the recommended multiple high speed stop to break in. Very occasionally after rain I get a slight noise on stopping but goes away after some reasonable stops.
      04-11-2024, 07:07 AM   #51
ipilcher
ipilcher's Avatar
450
Drives: 2024 M3 Compensation
Originally Posted by Needsdecaf View Post
Did the dealer have a mask on and a gun pointed at your face when they tried to rob you like that? LOL.
Regarding the hard driving....you only need to do that once in a while to keep the pads well bedded. And keep them clean. Make sure you do a good job cleaning the calipers out with a pressure washer when you wash the car. That will help alleviate a lot of the squealing.
How much pressure can the wheels & brakes take?
I use an SPX3000 with a 40° tip to rinse the car. Is is safe to use the 25° tip on the wheels?
