01-17-2023, 10:18 PM | #25 |
Rep 262
I’m all for the positive criticism comments with pointers and tips, but I just don’t understand or care for the dismissive and rude comments/thoughts. You went outside the box and attempted a custom mod which is cool in itself (apply pat on back now).
Can you clean it up once it’s actually on the car… yeah (let’s give you the time to at least get it on the car and tweak what you can). Do you have clean it up... well no because it’s your car. You paid/financed a lot of money for this car and you want to customize it your way so have fun with it. Hell, you may end up hating it and ripping it off and buying something different and this debate of worthiness is pointless. My only suggestion would be to search around for a 3D printer that can make it a single solid piece to fit those dimensions and clean up that portion of the mod for you. Thanks for sharing and keep doing you regardless of what others say!
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
01-18-2023, 09:05 AM | #26 |
Rep 698
Nice work. It's a helpful write up and lets people know what they are getting into.
I don't know if there is a good way to make the M3 or M4 Competition badge look factory without body filler, shaping and repainting the whole thing. The Competition is too small for the opening. Filling and matching the upper radius so just the bottom is flat would be ideal. The companies making replicas could easily modify the mold to make an awesome alternative. Not slamming the OP's install. As he mentioned it needs a little tweaking to be perfect. I think the badge opening is too big to ever be perfect. It looks like Twenty Two Tuning is making a black CSL grill without any recess at all. I would be happier not having one more M4Competition badge than the work involved to do this mod in a way I'd be happy. I emailed TTT for more pictures. |
01-18-2023, 03:56 PM | #27 |
Cailín gan eagla.
71541
Rep 1,007
01-20-2023, 04:50 PM | #28 |
Rep 444
Love the effort! I'm sure it'll come out just fine.
I don't care if the OP hung a set of hairy testes from the bottom of that grille. The critical issue here is that he has that grille. The CSL style grille is the most important cosmetic mod in the history of car modding. No other mod does to a car what the CSL grille does to these G80s. |
01-21-2023, 02:15 PM | #30 |
2147
Rep 1,838
Drives: Many, BMW.
02-18-2023, 08:59 PM | #31 |
2023 Fire Orange M3 Jahre
266
Rep 78
*** UPDATE ***
OEM M4 CSL grill, and lower M Performance carbon inlets installed. MAN....this was one of those modifications that COMPLETLY transformed the car. It looks amazing, even better in person. The mix of CF, and gloss black really compliments the mix on the rest of the car. As far as the badge dilemma, I had a friend 3D print me an insert with his filament based 50 micron printer. I'm also having a dentist buddy of mine print me one with his resin based, 30 micron printer using ABS resin. I will use which ever one looks best, and post updated pics once the badges go on. Stoked is an understatement. |
spridge647.50 chicagofan0019233.00 playswcars3657.50 dieter09116.50 IND-Distribution9597.50 PabstBleuRibbon487.50 |
07-17-2023, 06:15 PM | #32 |
Rep 64
Can anyone share a link to a M4 Competition badge that is small enough to fit into the space for the badge on the CSL grille? I ordered one from eBay which ended up being the trunk badge which is far too large. thanks
07-17-2023, 06:24 PM | #33 |
Rep 1,282
You can buy an oem side breather for $30 and take the badge off of that, it’s the same one that comes on the oem grille which isn’t sold separately. P/n 51-13-8-074-919
04-05-2024, 01:35 AM | #34 |
DHS
213
Rep 4,026
Drives: 2023 M4, 2020 Land Rover
04-05-2024, 01:36 AM | #35 | |
DHS
213
Rep 4,026
04-05-2024, 01:39 AM | #36 |
DHS
213
Rep 4,026
04-09-2024, 11:59 AM | #37 |
266
Rep 78
Forgot about this thread! Sold my car recently. But the final product came out AMAZING. 3D printed a piece that fit perfectly into the badge area. Sanded, primed, painted, cleared, polished and PPFed the piece. Applied it with 3M double sided tape. Attached OEM badge to it. Looked killer. Wish I took better pics of it.
Appreciate all the the suggestions in this thread—helped me arrive at a high quality, OEM+, durable final product. |
MaC-N54-E82488.00 somer972.00 |
