07-21-2022, 06:10 PM | #1 |
Daniel
346
Rep 263
Drives: 2023 330eX
Has anyone had an issue with your car starting slow? I picked up my g83 on 7/14. Drove it back from PCD. I've put about 100 miles on it in the last week. In that time there have been 3 instances where the car seemed to turn over two or 3 times before actually starting rather than starting right away. Any idea what may be causing it? I have total of 700 miles on the car and I have not been able to determine a pattern.
Update 10/14: BMW did a software update. Made issue worse. They are now replacing the IBM integrated supply Module. Update 10/18: BMW replacing spark plugs and fuel injectors. Update 10/20: BMW replaced spark plugs, fuel injectors, and did an oil change. Picking her up today. Edit: link to video of the 2 slow starts. https://www.icloud.com/sharedalbum/#B0NGdFryYGqLg3x |
07-21-2022, 07:21 PM | #2 |
Rep 1,931
Battery terminals on tight?
Limegrntaln13521.00 |
07-22-2022, 01:18 AM | #3 |
Rep 6,991
Have you installed anything like a radar detector, or something that's possibly not installed, correctly, draining the battery?
YT: G Dubyou |
07-22-2022, 05:34 AM | #4 |
Daniel
346
Rep 263
Drives: 2023 330eX
07-22-2022, 05:59 AM | #5 |
Rep 6,991
I would take it to the dealer and have them run a battery load test on it. Determine of the battery is healthy. The car is under full warranty, no reason not to take it in.
YT: G Dubyou |
figuec56346.00 |
07-22-2022, 07:25 PM | #6 |
Rep 366
Drives: 2022 M4 Convertible
OP, I have same model, in fact you replied to a post of mine a month back. My start is very quick. I would take her in as well if I was in your shoes.
figuec56346.00 Limegrntaln13521.00 |
08-24-2022, 05:25 PM | #7 |
Daniel
346
Rep 263
Drives: 2023 330eX
Got tge car back from the Dealership today. They can't figure out why it's slow starting. As normal, it did not happen while it was with them. They SA , who I trust, said they are going to BMW engineering. But so far do not have a resolution. Currently occurred about 12 time since 7/14. Trying to record the next time it does it. BMW said battery was tested and fine.
M4ord791.50 |
08-24-2022, 08:43 PM | #8 |
Rep 366
Thanks for update. Sorry you having this issue. Hope it gets resolved quickly for you.
08-28-2022, 12:12 PM | #9 |
Daniel
346
Rep 263
Drives: 2023 330eX
Attached is one the slow starts I get where the car stumbles during start. Last time it did this the car stalled. The stumble has happened 3 time and I'm at about 1500 miles. The other slow start is more common, and it is higher pitched and sounds like that starter is working too hard. Still trying get a video of that. I sent the video to SA at the dealership, but any ideas?
08-28-2022, 03:25 PM | #10 |
Rep 366
I have never heard that on a start. I am no mechanic but the fact you say it stalls would indicate either a fuel problem or spark problem. I think a spark problem would be evident the entire time the engine is on. It’s likely some sort of fuel problem maybe a pump that’s close to failure since it’s hard to find a pattern to it. I would think this video to SA would be enough for a mechanic to start to diagnose it though.
08-31-2022, 07:26 PM | #11 |
Daniel
346
Rep 263
Drives: 2023 330eX
Dealership can't find anything. Even with video. BMW engineer happened to be there though. SA said he downloaded data from car and took videos. Engineer said bmw has not had this issue with an m4 currently.
Had 2 more slow starts. See the videos. Anyone have any ideas? Am I able to go directly to BMW? https://www.icloud.com/sharedalbum/#B0NGdFryYGqLg3x |
09-20-2022, 12:22 PM | #13 |
Rep 469
Hmmm, I have to admit it sounds pretty normal.
Sometimes engines start slightly faster than other times due to ambient temp, temp of the engine, how long ago was the last start, etc... The longest time from crank to start I saw was about 2 seconds, which sounds pretty reasonable. |
09-20-2022, 12:50 PM | #14 | |
Daniel
346
Rep 263
Drives: 2023 330eX
I have an appointment October 4th with dealer. I just want a confident answer one way or the other with a logical explanation. |
M4ord791.50 |
10-01-2022, 04:22 PM | #15 |
///M-Thusiast
3647
Rep 941
Drives: '23 X5 M50i
@figuec56
I actually noticed the same thing you're describing on my G80 that I picked up yesterday. I'll keep an eye on things, but it's a little disconcerting, as the car hiccups on some starts.
Current: 2023 G05 X5 M50i xDrive
Soon: 2024 G87 M2 Past: G80 M3x, G80 M3, G05 X5, F82 M4, F87 M2C, F20 M140i |
figuec56346.00 |
10-01-2022, 08:08 PM | #16 | |
Daniel
346
Rep 263
Drives: 2023 330eX
I'm guessing, but I think as heats dissipates It messes with fuel in one of the lines. May vaporizing a small amount in the line. |
10-01-2022, 09:28 PM | #17 |
Rep 118
What is the ambient temp? Def don't think that is normal...Praying for a quick and easy resolution! I am sure that BMW will find something and may be simple and all will be resolved.
10-01-2022, 10:58 PM | #18 |
Daniel
346
Rep 263
Drives: 2023 330eX
I though that may have had something to do with but after Friday I don't think so. Over Labor Day car was cooling in the sun and ambient tripartite was in the 90s. However Friday was 70 and raining and still did a slow start after about 4 hours sitting.
10-06-2022, 03:30 PM | #19 |
Daniel
346
Rep 263
Drives: 2023 330eX
My dealership isn't quite sure what issue is. They think it may be the fuel pump. Though they have not been able to replicate in shop. They submitted the videos to BMW engineering and are waiting to hear back before replacing the fuel pump.
10-14-2022, 03:32 AM | #20 |
Save the Manuals
1714
Rep 2,937
Interesting
There is another thread about a potential fuel pump issue Hmmmmm 🤔🤔
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
10-14-2022, 04:22 PM | #21 | |
Daniel
346
Rep 263
Drives: 2023 330eX
So my dealership opened up a "Sara" case with BMW and the dealership and BMW have been troubleshooting since the Oct 4th. BMW did a software update. This made slow start problem much more consistent. As result, BMW, is replacing "IBM integrated supply module". Part was actually at a dealer in PA. So should be replace on Monday or Tuesday. |
playswcars3647.00 |
10-15-2022, 03:55 PM | #22 |
///M-Thusiast
3647
Rep 941
Drives: '23 X5 M50i
Interesting, I've been experiencing the issue less in the past few days, being more of a slight „hiccup" when starting, rather than a slow start. Looking forward to your update OP!
Might have to take mine in too.
