03-15-2024, 10:02 AM | #23 |
Rep 5,046
50% valve might not create enough pressure to force the air through the oem muffler. Bmw chose that 30-40% valve angle for a reason.
03-15-2024, 10:49 AM | #24 | |
Rep 191,281
I recommend you get a single midpipe instead for a cleaner sound with a deep mid-range tone. you want a more aggressive sound but with minimum rasp and noise.
03-15-2024, 01:23 PM | #25 | |
Rep 357
Ive been running mine at 50% to keep the drone to a minimal. Its still pretty loud though. Will running the car at 50% hurt the motor? |
03-15-2024, 01:42 PM | #26 | |
Rep 5,046
A 50% percent open valve is likely to flow almost all gases through the straight pipe. The only concern I would have is locking the valve completely shut in a high temp situation like a track day. As you can see the stock muffler piping diameter is much smaller and this will likely cause more back pressure, heat build up and less hp. We use a slightly larger muffler piping diameter on our axle back but I still wouldn't suggest 100% closure in the above situation. Hope that helps
03-15-2024, 04:22 PM | #27 | |
Rep 2,713
IMO 50 and 100% are more for if you want it louder all the time/at lower RPMs. |
03-15-2024, 06:49 PM | #28 |
Rep 191,281
as long as you do not have the valves fully closed and you are pushing the car on a track, you will be fine
Jax327475.00 |
03-18-2024, 09:09 PM | #29 |
Rep 273
Drives: 2024 BMW M4 Competition xDrive
03-19-2024, 09:07 AM | #30 | |
Rep 2,387
Formerly Wyndi335I
03-19-2024, 11:08 AM | #31 |
Rep 2,713
Burbles are "real" controlled by the computer, as long as the middle exhaust button is on, it'll burble. A midpipe swap will make the car actually physically audible, and it's advisable to disable ASD to not mix real with fake sounds.
JDUNITNOW3580.50 |
03-19-2024, 11:13 AM | #32 |
Rep 191,281
the burbles are the same
The sound of the exhaust is lower inside the cabin but that's because you are hearing what you sound like and not the fake sound. I'm shocked that customers haven't pushed back against manufacturers for using fake sounds in cars. It's like purchasing a sports car with a 0-60 mph acceleration time of 6 seconds, but the dashboard shows you a time of 2.5 seconds, and no one is bothered by it.
03-19-2024, 11:15 AM | #33 | |
Rep 2,713
03-19-2024, 11:18 AM | #34 | |
Rep 191,281
if your car is quiet and you don't care about that, that's 100% fine. but pushing a fake sound from your speakers is the part that bothers me
03-19-2024, 11:29 AM | #35 |
Bmw340i Mppsk, bm3 tune,vrsf downpipe dinan intake
100
Rep 189
Mike do you have a link for resonated downpipes and good brand etc or example?
|340i mppsk dinan intake vrsf catted downpipe|
|full alcantera carbon fiber interior| |bootmod 91, 93 and full e85 tune stage 2 agg| |firehawk tires and hawk perfomance brake pads | |bimmer code, | upgraded spark plugs full carbon exterior |
03-19-2024, 11:57 AM | #36 | |
Rep 191,281
We offer MAD & Active Autowerke resonated midpipes. both are excellent with spot-on fitment and high-quality finish.
03-19-2024, 12:05 PM | #37 |
100
Rep 189
by resonated do you mean catted downpipes?
03-19-2024, 01:14 PM | #38 |
Rep 5,046
A Resonator not to be confused with a catalytic converter is basically a fully straight through tube with sound deadening material around the outside that helps reduce higher frequency sounds such as rasp. You can see it on the pipe below.
Good illustration https://www.cjponyparts.com/media/im...or-diagram.gif
03-19-2024, 01:30 PM | #39 |
Rep 191,281
resonated and catted are different. some manufacturers offer catted midpipes, i prefer the resonated option
03-19-2024, 06:10 PM | #40 | |
Rep 2,387
Formerly Wyndi335I
03-20-2024, 11:06 AM | #42 |
Rep 191,281
Dinan uses an X-pipe design, which leads to a high-pitched sound. It's closer to the exotic car sound but has a lot of raspiness. The Dinan is an excellent option if that is the sound you are after.
