04-11-2024, 04:17 PM | #1 |
Rep 3,024
Drives: 2019 M2 Competition
Heat exchanger upgrade - full walk through DIY
All right yall, if you are going to upgrade your charge air cooling system, then you need to upgrade the heat exchanger as well! I saw many S55s (previous M motor) cars with JUST the charge cooler upgraded. While it was a visual upgrade, you weren't getting the full effect without the matching radiator to go with it.
The S58 is no different, that you should upgrade the radiator (heat exchanger) as well, and this might be a hint for the next upcoming project as well. Check out the excellent CSF Radiators heat exchanger from Kies Motorsports and let me walk you through the whole upgrade so you can do it too.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
