      07-30-2023, 10:14 PM   #1
GT_Juls
GT_Juls's Avatar
Drives: G82 M4
Hey guys,
I just completed my install and my god what a difference. Car looks 1000000x better.
There wasnt too much information on this and thought I post some info if anyone wants to do this in the future.
Step 1: The hardest part. Finding a set of laser lights.
I searched on ebay for about a month. Checking daily and happen to cross a local selling it.
- Make sure if you are sourcing one to get tons of pics from the seller
-Inspect for corrosion in case it came off a flood vehicle
-Try to find completed sets. Many sellers tend to just rip out the module and keep it separate.
-Look for US specs. You could do Euro versions but some say that it will revert back to being inoperable once a software update is completed. Didnt want to deal with that so went for US spec only.
Step 2: Buy an e-net cable and have a laptop with windows ready
-This is needed for the coder to get it up and running
Step 3: Buy the coding session and book a seasion.
kubax86 Will take care of you fast. Did it in 5 minutes !
Official Bimmer Post Vendor as well!
Step 4: Install headlights (important)
- These headlights are plug and play but will not turn on until you get them coded.
- Make sure you coordinate with the shop you are using to then get it coded ( I did the install myself to skip this step)
Step 5: Get it coded!
Kuba will code it and verify for you and then you can now enjoy your massive upgrade!
If you require more info my IG: GT_juls
Did plenty of stories to document this journey. Hope this helps!
//M is awesome
Appreciate 9
JDUNITNOW3529.50
BTC Maxi416.00
Rodizzle397.00
GregM41317.00
snyder268149.50
Bur4k52.00
      07-30-2023, 10:50 PM   #2
BTC Maxi
BTC Maxi's Avatar
Drives: Bmw M3
Amazing write up 👏
GT_Juls251.50
      07-31-2023, 08:03 AM   #3
Unimatrix0
Unimatrix0's Avatar
74
Drives: 2022 M4 Comp
Cool, Glad it worked out for you!
Now turn those puppies "Lemon Yellow"!
GT_Juls251.50
      07-31-2023, 10:20 AM   #4
GT_Juls
GT_Juls's Avatar
Drives: G82 M4
Thats the plan!
//M is awesome
      07-31-2023, 11:01 AM   #5
BzsBimmer
BzsBimmer's Avatar
3278
Drives: '23 G80 FO M3, M3 & MY Tezzy's
Hats off to you. What would the typical person looking to do this, expect to spend?
      07-31-2023, 12:19 PM   #6
Needsdecaf
Needsdecaf's Avatar
6606
Drives: 2024 G80 Comp xDrive
Originally Posted by Gseries92 View Post
Thats the plan!
Why not do it as you installed the lights then?
Also, your front end ducts. Which ones are those?
      07-31-2023, 12:25 PM   #7
GT_Juls
GT_Juls's Avatar
Drives: G82 M4
Got too excited and want them on asap.
Front ducts are oem
carbon package ones.
//M is awesome
Needsdecaf6606.00
      07-31-2023, 12:26 PM   #8
GT_Juls
GT_Juls's Avatar
Drives: G82 M4
Thank you! Total I spent $2500.
2400 for the lights and 100 to code. Definitely a good deal in my opinion as I saw one side being $2000 with no modules!
//M is awesome
BzsBimmer3277.50
ny2nj189.50
      08-01-2023, 06:31 PM   #9
GT_Juls
GT_Juls's Avatar
Drives: G82 M4
https://www.ebay.com/itm/36432412521...mis&media=COPY
Right side $999.
Says DRL issue but im 90% sure it had a RGB chip installed previously. Just buy the yellow drl chips and enjoy. Pretty sick deal if anyone wants to retro fit.
//M is awesome
      08-05-2023, 05:40 PM   #10
Fabroh
Drives: M3
My dude I knew it was you! Great post!
      08-05-2023, 07:47 PM   #11
GT_Juls
GT_Juls's Avatar
Drives: G82 M4
Thank you! Trying to help others 🫡
//M is awesome
      10-01-2023, 02:12 PM   #12
Sam_MTL
Drives: M3 G80
Do you absolutely have to remove the front bumper to install the lights ?
Thanks for the info.
      10-01-2023, 02:56 PM   #13
GT_Juls
GT_Juls's Avatar
Drives: G82 M4
Yes there are three total bolts and the last one is behind the light and you need clearance to make sure you can remove and install properly.
//M is awesome
      10-07-2023, 04:03 PM   #14
Sam_MTL
Drives: M3 G80
This post helped me through the process of retrofitting the laser lights on my G80. Here are some pics that could be helpful … there is a screw behind each light that was tricky to get to … otherwise not too complicated. I did it all myself with the help of a youtube video on how to remove front bumper.
I drove the car in the rain yesterday and got some condensation that dried overnight … I read the other posts on that subject and I’m hoping it will go away with time.
Many thanks to kubax86 from bimmer remote for the coding and Julian for the post 😇
GT_Juls251.50
Bur4k52.00
      10-07-2023, 04:50 PM   #15
GT_Juls
GT_Juls's Avatar
Drives: G82 M4
Love it!!! Glad I was able to help. Cars looking mean now 🔥🔥🔥
//M is awesome
Sam_MTL295.50
      11-22-2023, 09:02 PM   #16
914914
914914's Avatar
Drives: 2022 M3
2022 BMW M3  [0.00]
How hard was it to remove and reinstall the bumper?
      11-26-2023, 03:53 AM   #17
GT_Juls
GT_Juls's Avatar
Drives: G82 M4
Not hard at all.
Best tip is to remove both front wheels and remove the fender liner enough where the front portions are hanging. Makes it so much easier than trying to shimmy your hands in there trying to remove the 10mm
//M is awesome
      12-01-2023, 08:28 PM   #18
wavyyyy
Drives: M2C
2023 bmw m3 6mt  [0.00]
I think removing the bumper absolutely sucks on our cars. Congrats on the lasers though!
GT_Juls251.50
      12-30-2023, 09:00 PM   #19
AmazinRayzin
AmazinRayzin's Avatar
Drives: BMW M3
I'm looking at doing the same thing. Do you have to recode every time there is a software update?
      12-30-2023, 09:37 PM   #20
GT_Juls
GT_Juls's Avatar
Drives: G82 M4
Nope! Code once and you are set
//M is awesome
      12-31-2023, 01:28 AM   #21
Berzerker
Is it just VO coding the option in or does it require recoding anything in the modules?
      12-31-2023, 02:46 AM   #22
TheNine90
578
Drives: bmw
You only need edit fa, remove existing light option and add 5AZ then vo code the BDC and FLM
Berzerker2889.50
