07-20-2023, 10:08 AM | #1 |
Rep 10,878
IND | A Fascia Only A Mother Could Love: G8X Grille Comparison
Featured on BIMMERPOST.com The G8X M3 / M4 styling discussion has already been done... extensively. While the front fascia looks are still a bit polarizing, the overall consensus has become overwhelmingly positive; aided in large part by the many aftermarket grille options now available. At IND, we wanted to offer a comprehensive look and comparison of all the options so customers can make an informed decision on the direction that best suits their individual styling goals. Unlike the many houses of Westeros battling for the Iron Throne, hopefully we can help make your choice of front grille just a bit easier. FIRST OF THEIR NAME: Vorsteiner Aero Front Grilles Vorsteiner was the first company to offer an aftermarket grille solution that was based on BMW's own M4 GT3 front grille. They offer both a carbon as well as a gloss black variant; the only difference being that the carbon version uses 2-piece construction while the gloss black unit is a single piece like BMW's CSL grille. The GT3 style grille keeps things simple by fitting models both with and without active cruise control. The one-piece grille is easier to install utilizing the OEM tabs while the 2-piece will likely give you a bit of extra leeway to make sure each side fits as well as possible. Both versions include an emblem mounting plaque, but only for the standard emblems. There is not enough space for the "Competition" moniker. Though an added benefit that Vorsteiner offers is the option of including mesh inserts to help protect against rocks and small animals. THE MANY-FACED GOD: AutoTecknic's Many Options You can almost consider AutoTecknic to be the savior of the G8X's front-end all on their own. They took all the available grille style combinations and made an option for just about everybody. From the GT3 and GT4 to the CSL and everything in between; they produced every kind of option one could want. ATK V1 GRILLES: MOTORSPORT AND PODIUM AutoTecknic's Motorsport V1 grille is available in 2x2 carbon weave and was their original take on the GT3 style front grille. Even though it utilizes 2-peice construction, the grille included unique mounting tabs not seen in the Vorsteiner piece that aimed to make installation easier. Compatible with models with and without Adaptive Cruise and with space on the emblem plaque for both the model and "Competition" moniker, these were a solid first attempt. The Podium V1 grille was essentially identical to the Motorsport V1 grille with the exception of allowing owners that don't have Adaptive Cruise to have an extra style element in the form of a cross bar in the lower portion of the grille to match the upper portion. This was a good solution for owners wanting a more uniform look. MOTORSPORT V2 AutoTecknic was very straight forward in their execution of the Motorsport V2 grille. They took their most popular grille, the GT3-styled Motorsport V1 and revised it to produce a single piece grille insert that mounted with the OEM tab setup. Just like the V1, the grille fits models regardless of their Adaptive Cruise feature and included an emblem provision for the "Competition" badge. THE CSL STYLE OPTIONS The Carbon Competizione Sport grille was a complete CSL style grille, but in carbon construction. While early production included an emblem plaque meant for the CSL badge, the grille is now produced with the full size emblem plaque so the Competition emblems can be fitted. Like all grilles using complete CSL style elements, it cannot be fit to models equipped with Adaptive Cruise Control. The Competizione Sport grille was also made available in a gloss black plastic construction if the carbon wasn't to your liking. The only difference being the it only fit the standard, non-competition emblem. AutoTecknic also produced their gloss black CSL grille in a Redline Competition Sport variant that added the same red outline that was present on the OE M4 CSL and M3 CS grilles; the only difference being that AutoTecknic's Redline grille was professionally painted instead of going the red vinyl route that BMW settled on. AUTOTECKNIC'S UNIQUE GT4 OPTION One issue with all the CSL-styled grilles is that the M4 CSL was not fitted with Adaptive Cruise Control by BMW and therefore, any owner that ticked that option on their G8x build wasn't able to install a CSL-styled grille, no matter how much they may have wanted to emulate it. That changed with AutoTecknic's introduction of their carbon Competizione GT4 front grille that incorporated the upper grille Y-bars, but left the lower grille openings free from any elements that would interfere with the Adaptive Cruise Control radar housing. Unlike their early units, the GT4 grille incorporates an emblem mounting plaque that will fit the full Competition model emblems. THE ONE TRUE KING: OE M4 CSL There's a lot to like about the OE CSL Grille. It's the one factory part on this list so it installs and fits like a factory part. Interestingly, it's also actually the most affordable G8x grille solution and is the only grille that includes a front grille emblem; however, most purchasers will choose to include an IND painted grille emblem with whichever grille they choose. Unfortunately there are some downsides. It comes with a red striped-surround that will look out of place on most cars that don't carry the theme throughout the car like the CSL does. Luckily it's just red vinyl and can be removed. While it includes an emblem, it's the OE M4 CSL emblem and unfortunately the M3 CS grille with corresponding emblem isn't yet available from BMW. So an M4 CSL emblem certainly won't work for M3 owners. And should you choose to remove the 'CSL' moniker, the emblem plaque will be significantly wider than your emblem and doesn't include enough height for the Competition moniker. The CSL grille will also not fit models with Active Cruise Control. HONORABLE MENTION: Stradale Design The Stradale Design GT3 Front Grill was developed to enhance the cooling efficiency of the G8x platform. Starting with inspiration from the M4 GT3 race car's front grill inlet, Stradale refined the surfaces to better suit the street car while also incorporating their patented "Vortex Generators" on the middle grille bar directing the air more efficiently to the radiators further cooling the water temperatures during high performance driving. We were big fans of this GT3-style grille that incorporated several design enhancements when compared to the other GT3 grilles on the market. Unfortunately, while the design was top notch and our favorite of all, the fitment just wasn't quite up to par. While we were eventually able to get the grilles to fit properly, the amount of effort required was deemed to be too much and we no longer offer this product to our customers.
60
T0RM3NT3642.00 Needsdecaf6606.00 Forzanerazzurri6918.00 EatThatLunchBaby386.50 M Division1197.50 kingmatt9284.50 Palomequet158.50 An20Olives80.00 cfm56d7b5886.00 provenflipper105.50 DNYC1919478.00 peelerec987.50 TheProdigy1042.50 Usef_Afande120.50 M3ANSPEC393.00 ///M TOWN16584.00 Galandel193.00 docjavier1108.00 M3 boi3211.00 Chapter2099846.00 r33_RGSport12972.00 Cos270608.50 jas1651448.00 Elijaih17.00 Caladin254.50 ando2002.00 JSP///M4C103.00 WadeM115.50 MaC-N54-E82464.00 dezzracer1182.50 holmar888289.00 playswcars3633.50 xeroneone76.00 vmoney89109.50 YXEM5185.00 all_my_rides288.50 1JB0.00 Game7408.50 |
07-20-2023, 11:31 AM | #3 |
Rep 6,701
Great comparison.
Still like stock best, TBH. |
12
gnolivos319.00 JordW13.00 M3 boi3211.00 AG23253.00 mirob3042.50 Davciedi1.50 ArnoPCB118.50 astris616.50 Llarry16040.50 Forzanerazzurri6918.00 Autoaddict303.50 calbearz2434.00 |
07-20-2023, 11:38 AM | #4 |
Rep 5,316
Drives: G80 M3 6MT
Great write up! I want the Competizione Sport grill in plastic/gloss black, but I just can't justify $700 for a well molded plastic grill. I'm sure I'll give in, in the meantime, seeing this post reminded me that I need some painted reflectors and black emblems!
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
Autoaddict303.50 Blau366.50 |
07-20-2023, 12:07 PM | #5 |
Rep 520
OE CSL is the choice for me, but the Autotecknic GT4 is an interesting option for those with ACC, shame it isn't offered in gloss black as personally the carbon grilles are a bit too OTT
Interestingly the M3 CS grille is exactly the same as the CSL but with the badge centred to accommodate for the missing 'L'. Not an issue but annoying once you see it! |
Alexvier35.00 |
07-20-2023, 12:33 PM | #6 |
Rep 234
Patiently waiting for the OE M3 CS grill
2023 G80 MT / AW / Fjord Blue/Black | KW HAS | Apex VS5RS F:20x10+8 285/30-20 R:20x11+18 305/30-20 | Maxton Street Pro Splitter | OEM M3CS Grille | SST Valve Controller | CS Style Yellow DRL | MAD Non-Res Single Midpipe
Past: 2018 X3 M40i | 2016 M-Sport X1 | 2013 MT M-Sport 328i | 2021 Audi A6 Allroad |
07-20-2023, 12:59 PM | #7 |
Rep 308
Drives: ‘23 M3 Comp xDrive
Really great write up and helped remind me that I need to purchase a grill soon. I’ll definitely be coming back to this post in the future when I look over options!
07-20-2023, 04:04 PM | #8 |
Rep 2,442
Drives: 2022 M3 6MT
This was great.
I did the Autotec option, CSL with red. It was important to me that the badge size was accurate as well.
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
9
Usef_Afande120.50 ///M TOWN16584.00 M3 boi3211.00 JTO245276.00 blackops23486.00 kiw1617.00 GAMA946.50 mmmhmm51.50 Sonic RR118.50 |
07-20-2023, 04:08 PM | #9 |
Rep 2,312
Drives: 2016 LB M2 / 2020 X5 40i
Yeah after all these years, i’m still not a fan of the grill, I don’t hate it, but I definitely do not like it. It definitely looks aggressive, but in an ugly way
22
chicagob5256.50 lucas535d27.00 cedchung63.50 Teutonic2709.00 AlpineBoost3927.50 M3 boi3211.00 Swappy531.50 Blau366.50 JayPalafox3.00 dezzracer1182.50 Blindside_1376709.50 2SNAILS2085.50 Redgoat10.50 TimmyM56241.50 Peertwelve781.00 floridaorange10173.00 VR1638.00 cobra2814112.00 HotRodM4687.00 DO4441410.50 blue dragon1191.50 IM2C2066.50 |
07-20-2023, 04:12 PM | #10 |
Rep 279
Drives: G80 M3 Comp xDrive
Great write up IND-Distribution! Any chance you can detail which grills don’t require cutting into the crash foam? From what I’ve heard, the vorsteiner grills require cutting a considerable amount. While I want the looks, I don’t want to sacrifice safety - so any info would be much appreciated!
07-20-2023, 04:18 PM | #11 |
Rep 1,354
Drives: 2022 X5 m50i
CSL with red stripes is the best option.
2022 BMW X5 m50i
2024 MB S63 on order '18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3 |
07-20-2023, 04:25 PM | #13 |
Rep 155
I admit I am a hater turned admirer. I hated the G80 initially. I have owned an E46, E92 and still an F80. It was the first time I didn't immediately lust over the newest M3. But as time has gone on, as much as I hate to admit it, I have started to love it. Part of the reason being because of these after market grill options.
Thanks for posting the comparisons. I'm sure it will come in handy when I inevitably bite the bullet and purchase one of these ugly ducklings. |
MdMcoupe39.50 |
07-20-2023, 04:30 PM | #14 |
Rep 124
Drives: BMW | B58 F22 || Audi B9 S4
Great write up, love the options out there. Still think something better can be made to fit that space, thats my 2 🪙 🪙
07-20-2023, 04:31 PM | #15 |
Rep 1
I respect the g8x cars for their performance but a front end shot still makes my stomach turn, especially compared to the front end of the f80 it’s just jarring and not in a good way
18
cedchung63.50 Teutonic2709.00 M3 boi3211.00 Swappy531.50 Elijaih17.00 JayPalafox3.00 icebiker505.50 DocOfTheDead407.50 dezzracer1182.50 Blindside_1376709.50 SoCali E361000.00 TimmyM56241.50 Peertwelve781.00 Joachim328.00 sq86363.00 HotRodM4687.00 blue dragon1191.50 IM2C2066.50 |
07-20-2023, 04:31 PM | #16 |
Rep 138
I have the autotecknic csl with red on my dravit comp
14
MachinesWithSouls4835.50 Vervain397.50 M3 boi3211.00 nosbocaj695.00 dezzracer1182.50 YXEM5185.00 TurboSid1112.00 JDUNITNOW3529.50 Redgoat10.50 Limegrntaln13475.00 GAMA946.50 blue dragon1191.50 bri10425941.50 CNK_80Q3_G820.00 |
07-20-2023, 04:38 PM | #17 |
Rep 407
You're absolutely right. It's shameful how ugly they made that front end.
12
tfunk88192.00 Elijaih17.00 JayPalafox3.00 DocOfTheDead407.50 SoCali E361000.00 2SNAILS2085.50 TimmyM56241.50 floridaorange10173.00 HotRodM4687.00 DO4441410.50 blue dragon1191.50 IM2C2066.50 |
07-20-2023, 05:14 PM | #19 | |
16584
Rep 8,427
Huge improvement
MachinesWithSouls4835.50 |
07-20-2023, 05:26 PM | #20 |
Rep 178
Drives: 2020 M2C, 2018 X3M40i, 765RS
It’s really surprising no one makes a M340i style grille. That would be the only thing that put me in one but haven’t seen it done.
07-20-2023, 05:38 PM | #21 |
Rep 9
I think this might be because anyone who dared to say anything negative was instantly banned by the g80 admins....
18
Teutonic2709.00 Jockey3451.00 M3 boi3211.00 Swappy531.50 Elijaih17.00 JayPalafox3.00 icebiker505.50 ///M TOWN16584.00 Th3DarkSide368.50 Maverik2594140.00 ra2289305.50 TimmyM56241.50 F32Fleet3587.00 Peertwelve781.00 sq86363.00 DO4441410.50 IM2C2066.50 yeetyeet391.50 |
07-20-2023, 05:50 PM | #22 |
Rep 139
IND-Distribution do you have a photo of the updated Autotecknic Competizione Sport with the badge provision for the full Competition emblem?
