      12-01-2022, 10:35 PM   #67
PARTS@STBMW
PARTS@STBMW's Avatar
2702
Originally Posted by theone210 View Post
Where can I find the m4 version. Any help is appreciated.
I have these available as well!
DM for a link.
-Brit
      12-02-2022, 02:34 AM   #68
forumlurker
forumlurker's Avatar
780
Drives: almost every day
Found this vinyl version
https://www.etsy.com/listing/1234160...ler-vinyl-skin
Limegrntaln13473.50
      12-02-2022, 08:42 AM   #69
Vinnrox250
Vinnrox250's Avatar
Drives: 23 M3Cx
Mine gets here today from Brit at bmwpartspros.
Let's hope my install will be easy. Lol.
Limegrntaln13473.50
      12-02-2022, 06:00 PM   #70
tkblingx2
Drives: 2023 M3CX
Ok spent 10mins just now and got it installed. Required a good amount of force which was scary but didn't leave any marks.
How I was able to get mine off:
1. Mask off the top right and bottom sides with painters tape.
2. Start by prying the top side. A wide pry tool with a 90 degree bend worked best for me so I get enough leverage since the dial gets in the way.
3. Once the top pops out keep that pry tool in place so it doesn't pop back in. Use another pry tool on the right side and work your way from the top corner down to the bend until the right side lifts then you can pull it out by hand.
For me I couldn't get enough of the pry tool in on the bottom side so I started on the top where the buttons give you the necessary wiggle room.
Hope this helps. Also saw iND has these on their site now.
Edit: For some reason the 2nd and 3rd pics uploaded in the wrong order from my phone lol
Appreciate 9
MunkyTool547.50
Vinnrox2503002.00
chicagofan0019153.50
forcefed2567.00
amrh296.50
g80z673.00
T0RM3NT3642.00
      12-02-2022, 06:13 PM   #71
tkblingx2
Drives: 2023 M3CX
A quick image of where I used the pry tool. Red for the first tool (there's a ridge between the two red lines so avoid that area), blue for the second. Good luck!
Appreciate 17
MunkyTool547.50
Vinnrox2503002.00
Bl0ck101.00
as7920597.00
T0RM3NT3642.00
khanyam4801.50
amrh296.50
SpinalTap109.50
OwnerF16852.00
svgM3635.50
Bur4k52.00
      12-03-2022, 08:50 AM   #72
M3 Competition
Drives: BMW M3
Another possible way may be drilling a hole in the middle of the piece that gets replaced anyway and then pull it out with a hook.
as7920597.00
Draper3460.50
      12-03-2022, 03:17 PM   #73
Vinnrox250
Vinnrox250's Avatar
Drives: 23 M3Cx
Great instructions man. But mine will not come out. Gave up.
      12-05-2022, 06:55 AM   #74
as7920
as7920's Avatar
United Kingdom
597
Drives: 2023 SG/FR M4 xDrive Competiti
It's in. Bloody hell that was hard work. LOL.
Lots of force. Had to work from top, down the side and it popped up into the sky and nearly hit the roof. Used 4-5 different tools.
Won't be doing that again.
MunkyTool547.50
Limegrntaln13473.50
      12-05-2022, 06:14 PM   #75
Vinnrox250
Vinnrox250's Avatar
Drives: 23 M3Cx
Man that was an a$$ whipping. I had better luck starting from right side and working down. Looks much better. But never again.
Thanks to Brit at BMW Parts Pros!
MunkyTool547.50
T0RM3NT3642.00
Limegrntaln13473.50
SpinalTap109.50
      12-06-2022, 08:04 AM   #76
G8XM3
Drives: G80 M3CX
so glad my LCI M3 came with this installed. not having to mess around and potentially damage parts!
      12-06-2022, 06:34 PM   #77
22M4C
Drives: 22 M4 Competition Converti
To confirm, this is the correct part number for M4 left side drive (US), correct?
65829501549
The image on getbmwparts is blank
https://www.getbmwparts.com/oem-part...hd-65829501549
      12-07-2022, 07:25 AM   #78
22M4C
65829501549
Nevermind, I have a G83 and that won’t fit as the control for the top is there…
      12-07-2022, 08:22 AM   #79
davidmct-M3
Drives: BMW 440i with MPSSK
Finally got round to this myself. UK car so swap left/right for USA.
Steps I used.
1. Blue tape around part
2. Use a wide bladed trim tool on the top (near rotary dial) edge (both sides of part) and pry. Might hear a pop
3. This frees up the left hand side a little so use trim tool to work this up
At this point I had the top edge up a few mm but couldn't raise it further (see slots on replacement part - it needs to exit vertically) nor get a pry tool in the front edge.
At this point my video stopped!
4. I now pushed the top back in a little whilst pulling on left side. Rear popped up and then part just lifted out! basically just had to align it vertically but in a raised position.
Drop box link to video such as it is below (500MB).
https://www.dropbox.com/s/2m6qpdsde5...0p30H.MOV?dl=0
Ariboon379.50
T0RM3NT3642.00
MunkyTool547.50
      12-07-2022, 08:39 PM   #80
jpichardo91
Drives: 2023 M3Cx / 2020 BMW x5 M50i
Ready
      12-15-2022, 02:17 PM   #81
theone210
theone210
Germany
254
Drives: M4 competition xdrive
Still no m4 version
      12-15-2022, 04:07 PM   #82
khalua80
khalua80's Avatar
768
Drives: 23 M3Cx
Still no m4 version
Here you go right here.
https://paddleshifterz.com/product/o...-82-9-501-550/
as7920597.00
      12-27-2022, 03:45 PM   #83
cuggz
Drives: 335I
Sooooo
I’m just thinking out loud here
Why not just drill a big square through the plastic … then just pull it out
Saves alot of headache lol
      12-27-2022, 05:07 PM   #84
T0RM3NT
Mr. Irrelevant
T0RM3NT's Avatar
Drives: '23 G80M3CX Dravit/Silverstone
Admittedly, I did not read the entire thread. I was thinking the other day that BMW removed this center console "M3 Competition" branding that most of us want and gave us the xDrive badge on the back that most of us don't want. Does that sum it up?
Past results aren't a guarantee of future performance.
      12-27-2022, 08:33 PM   #85
Not_Speeding
Not_Speeding's Avatar
21
Drives: 2020 BMW 330, 2023 BMW M4
Just installed mine following the method shown by tkblingx2.
Spent 5 minutes lifting up the top part, but once its lifted the rest is easy.
      12-28-2022, 04:22 PM   #86
M3 Competition
Drives: BMW M3
Originally Posted by cuggz View Post
Sooooo
I was thinking about that as well. I don't see why it wouldn't work and it will probably be a lot easier this way, but I don't know if I have the strength to drill into the console.
      01-07-2023, 09:11 AM   #87
904_FireG80
904_FireG80's Avatar
309
Drives: 2018 F82 Comp, 2023 G80 Comp x
Super easy! 5 minute install, just have to use a little force and work from the top, and then down the right side.
T0RM3NT3642.00
MunkyTool547.50
Bur4k52.00
      01-18-2023, 04:33 AM   #88
twistedmorphine
Drives: M3 Competition
I tried with all the trim removal tools I had and didn't manage to pop the thing out. Only popped out the top and nothing further.
In the process, I damaged the surrounding silver trim ( anyone know where I can get a replacement for just the silver bit?
Thanks.
