      05-09-2022, 06:04 PM   #67
Zirenz2006
Zirenz2006's Avatar
Drives: G80 M3 Comp IOMG
I'm going to order this but I think the factory start/stop has a more satin finish. Anyone have the satin one installed? What do you think. It looks like all the ones I'm seeing here are glossy.
Current: 2021 ///M3 Competition Isle of Man Green
Ordered: 2024 ///M2 Zandvoort Blue
Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i
r33_RGSport12972.00
      05-09-2022, 06:22 PM   #68
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Yes, Start button is satin.
Most guys goes with gloss since it catch your eyes better.
But, some guys also do Satin.
In a glance, you can really tell the difference since it is so small.
So, can't go wrong either way.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
Zirenz20061542.00
      05-09-2022, 07:31 PM   #69
Zirenz2006
Zirenz2006's Avatar
Thanks, I'm ordering satin
r33_RGSport12972.00
mattssi879.00
      05-12-2022, 12:57 PM   #70
Zirenz2006
Zirenz2006's Avatar
I can't get the silver ring off even with a pry tool. It moves a little but I'm afraid of breaking something.
r33_RGSport12972.00
      05-12-2022, 02:36 PM   #71
r33_RGSport
Turn it and try from different end.
Once you get one end lifted a little, turn it 180Ί and pry.
I have encountered a few where it comes off like butter just by grab and pull.
      05-12-2022, 06:02 PM   #72
HTTP 410
HTTP 410's Avatar
2142
Drives: 2022 M3 Competition
This worked for me. That and prayer.
2022 M3 Comp BGM/Fiona Red, Executive, Drivers Assistant Pro, Parking Assist, 826M black wheels
(SOLD) 2018 M2 BSM LCI, DCT, Executive, Drivers Assist, CarPlay
FISH225404.50
      05-18-2022, 01:33 AM   #73
aktif8
Drives: 22 M4c vert
I did the drill method - install done, painlessly, in about 90 seconds. Old button went in the trash, piece of cake.
r33_RGSport12972.00
element561091.00
      02-03-2023, 09:05 PM   #74
freshxdough
freshxdough's Avatar
3512
Drives: 2024 iX 50 | 2020 X3 M40i
does anyone have some good photos of a Satin button. I only see gloss. I like the satin button as it would match the normal red OEM start stop button. Thank you.
r33_RGSport12972.00
      08-11-2023, 11:47 AM   #75
M3Power22
Ball Crusher
33
Drives: 2022 G80 M3 - Alpine White
This thread gave me so much anxiety for changing out a stupid little button. FYI - Neither video worked for me so I wound up having to use two pry tools; one on each side to safely pop off the ring.
In the end, this small little mod that adds a nice pop! Oh and I was worried that the gloss red wouldn't match but it's not noticeable under natural lighting IMO.
r33_RGSport12972.00
      10-02-2023, 07:25 PM   #76
wallysboy
Drives: 335xi, m340iX 2020
I tried the RSG method but couldn’t lift the silver ring from the base so I tries your two pry tool method on each side and wound up popping out the entire knob intact with the silver rind still attached! Talk about anxiety. After much kanas hint of teeth and a flashlight I was able to pop the knob assembly back in place. Thankfully I didn’t break it. However, I am back to square one trying to get the silver ring off #*!
r33_RGSport12972.00
      10-02-2023, 08:53 PM   #77
r33_RGSport
Ugh, you should've just pop the button right there on before re-install the whole knob back. lol.
You can poke the button from the back if you have the whole knob assembly off.
      10-11-2023, 11:59 AM   #78
wallysboy
Yes I realized that when I tried the pliers method and popped out the entire knob again! Even with a thick towel on the silver ring, the pliers left marks on the silver ring. Wound up pulling the knob apart into two pieces and popped the red button in the knob. Unfortunately, I can’t seem to get the vol level again when popping the entire knob assembly back in the head unit like I did the first time! Now the vol isn’t perfectly level. Must have been extremely lucky the first time I popped it back in with the factory vol left alone- ��. Don’t know how to fix that but at least I have the red button now ��.
r33_RGSport12972.00
      10-11-2023, 01:19 PM   #79
r33_RGSport
The silver ring have splines. You will have to re-insert it to a correct splines, otherwise it won't sits flat.
      10-11-2023, 08:57 PM   #80
wallysboy
It sits flat. What I meant was the vol lettering not being level on the horizontal axis.
r33_RGSport12972.00
      10-11-2023, 09:49 PM   #81
r33_RGSport
Ahh, most likely the whole assembly didn’t lined up properly when you re-insert it.
      10-12-2023, 11:18 AM   #82
wallysboy
I spent at least an hour to try and get it all lined up correctly but this was the best I could do. I must have gotten really lucky when I reinserted the unaltered knob the first time. Do you know how difficult it is to remove the entire control unit?
r33_RGSport12972.00
      10-12-2023, 01:58 PM   #83
r33_RGSport
Not that hard. Plastic pry tool will pop the whole assembly out.
      12-29-2023, 02:48 PM   #84
adam12hicks
adam12hicks's Avatar
251
Drives: 2010 Montego Blue 128i Vert
Just did this on mine. Felt like it wasn’t wanting to pry off but then simply pulled on the silver ring with one hand while using the pry tool and it popped off easily. Then used the flathead screwdriver to pop out the insert with a simple twist at 90 then 270 degrees on the knob. Ring didn’t go all the way flush and hits a tiny bit of resistance on turning once assembled so maybe it’s not exactly aligned. Will try and pop it back off and re-align.
r33_RGSport12972.00
      01-15-2024, 03:51 PM   #85
David In HD
US ARMY
David In HD's Avatar
126
Drives: 2024 G80 M3 CP X-drive
2024 BMW M3  [0.00]
Originally Posted by Osage View Post
Cool. Thanks!
Where you able to find a cover for the volume buttom?
      01-15-2024, 03:52 PM   #86
David In HD
US ARMY
126
2024 BMW M3  [0.00]
Do you know where to buy the volume button cover? The silver one? Mine broke when I was removing it SMH.
      01-15-2024, 04:08 PM   #87
forcefed
forcefed's Avatar
Drives: .
I haven't seen oem ones, closest i can find is this https://www.aliexpress.com/item/1005006008580477.html
      01-15-2024, 04:29 PM   #88
David In HD
US ARMY
126
2024 BMW M3  [0.00]
Anyone have them installed? I found a similar one on amazon I'll try those first, because they have a 2-3 week ship time.
