      02-18-2024, 07:07 PM   #177
napeHbNYC
Drives: 2007 e60 550i RWD 6MT
This things definitely work, look at all the salt on it
mathys202.50
      02-23-2024, 02:27 PM   #178
ipilcher
ipilcher's Avatar
436
Drives: 2024 M3 Compensation
Originally Posted by Tobster3 View Post
Hey ipilcher
Presume your meaning for the bottom part of the front flaps?
I installed mine yesterday and it didn’t come with self tapping screws and I really didn’t want to mess with looking for some or drilling holes on the mud flaps so used 3M tape for the bottom part of the front flaps. Will see how it holds up. I bought mine some time ago, do the fronts come with 3 holes now?
The rear doesn’t need any, the screws provided for it pull it in really good.
Yup. That is what I was referring to.
Let us know how the tape holds up.
Tobster3634.00
      03-28-2024, 09:26 PM   #179
dmodem
dmodem's Avatar
Drives: 06 e90
As an FYI, these won't fit on a '24 Comp. The rear wheel liner sits about 1 1/2" in from the wheel well edge, and there's no way to mount them flush.
      03-29-2024, 08:38 AM   #180
forcefed
forcefed's Avatar
Drives: .
You need to use spacers and longer screws, they don't sit flush on my 23 either.
      03-29-2024, 08:46 AM   #181
GolfCoyote
GolfCoyote's Avatar
571
Drives: 2024 M3 Comp xDrive
24’ xdrive with TLG flaps, fits fine for me.
2015 VW GTI (446whp/414wtq)
2024 M3 Comp xDrive
      03-29-2024, 10:17 AM   #182
dmodem
dmodem's Avatar
Drives: 06 e90
The '24 Comp's liner is held with hex bolts far inside the wheel well, and as provided, the TLG flaps' extended screws are incompatible to hold the flap flush against the wheel well edge. If it were to be attached as expected, the flap would be pulled and turned in the wheel well in order to be secured. That's not the way it's supposed to fit, not what TLG's instructions show.
      04-07-2024, 07:44 PM   #183
Tony_M3
Tony_M3's Avatar
222
Drives: 2023 G80 6MT
Anyone have any recommendations/tips for installing the push pin rivets? I was able to install 3 out of 4 but kept bending the pins when trying to install the last one. I didn’t have any luck tapping any of them in with a hammer. The only way I was able to successfully install three of them was by holding the hammer against the pin and pushing as hard as possible. I’m using an 8oz ball and peen hammer; should I be using a heavier one?
Unfortunately I bent all of the extras that were provided so am currently waiting for the extras to arrive via Amazon.
      04-07-2024, 08:39 PM   #184
MintyG82
Drives: 2021 Mint Green M4 Comp
I just shimmied and spun the rivets on the one that was giving me some difficulty. Took a couple attempts but ending up working.
These flaps definitely do the job!
      04-10-2024, 10:35 AM   #185
TselaG80
Drives: SMB G80 M3 X-Drive
can these be made in gloss black?
      04-10-2024, 01:15 PM   #186
Diesel power
Drives: 24 Q8 E-Tron 24 M3 CX
These ones come in Gloss Black, I just ordered a set
https://g80.bimmerpost.com/forums/sh...1891632&page=7
      04-10-2024, 02:07 PM   #187
ipilcher
ipilcher's Avatar
436
You could always wrap them, either with black PPF (if such a thing exists) or vinyl and PPF.
      04-14-2024, 02:40 PM   #188
apeas2
Drives: M3
I just bought a 24 G80 comp Xdrive. Are you sure the rears won’t fit? I am surprised BMW would have made a change outside of a mid cycle refresh. Thanks.
      04-14-2024, 03:04 PM   #189
farishat
farishat's Avatar
Drives: 2004 E46 330i ZHP, 2024 G80 M3
They fit just fine.
