05-04-2021, 01:56 PM | #309 |
Army Welder
1119
Rep 470
Drives: 2008 AW E92 M3
Went for a long drive to hurry on the break in process
2021 M2 MT SO
IG: von_bee_ YT: VonB |
05-06-2021, 07:24 AM | #310 |
///MFlight Member
454
Rep 246
I have to drive on the Autobahn on my way home so I was able to push the car. I got it up to 250kmh/155mph right after I did the break-in service. Next stop is the Nürburgring. Only in Germany....
05-06-2021, 08:12 AM | #311 |
Rep 485
I'm sure this has been asked a million times, but how easy would it be for someone who doesn't wrench to install?
05-06-2021, 09:12 AM | #312 |
Rep 3,292
It's very easy. The only difficulty is the angle your arm is required to be at. However, I attempted to get it back OUT for my break-in service and couldn't get it. I'm guessing there's something of a trick to it (and I understand that they don't survive being removed). It didn't get mentioned during the service.
05-06-2021, 09:41 AM | #313 |
Rep 3,056
Which clutch stop did you go with? BMS? You use all the rings it came with to prop it up as much as possible?
SMB M3 CS (gone) YMB F80 6MT (gone) |
05-06-2021, 10:00 AM | #314 |
Rep 1,254
i dont see any way that clutch stop is coming out without tearing it. Regardless, nobody is going to care or likely even notice that it is there. I certainly don't plan on removing mine for service.
05-06-2021, 10:15 AM | #315 | |
Rep 596
05-06-2021, 10:19 AM | #316 | |
Rep 596
05-06-2021, 10:20 AM | #317 |
Rep 574
Nice! How long is the break in? 1,200 miles right? Have you noticed any difference in exhaust sound?
05-06-2021, 10:26 AM | #318 |
Rep 3,056
I like to add rings not drop lol. I have a new BMW clutch stop just waiting. I may buy a 2nd to get the rings.
05-07-2021, 10:12 AM | #320 | |
Rep 477
05-07-2021, 11:45 AM | #321 |
Rep 67
Installed mirror tap and blendmount for Uniden R7 (after updating to the latest code that now has auto lockouts). It was not too hard an install thanks to the folks on bimmerpost identifying the correct leads to tap (I got a quote to do this install of $200 from a local electronics shop and that is a rip off for a 20 minute job). It's a little tight in there and I used a interior removal tool to remove the covers and they came off and went back on pretty easily, although one clip did break but did not cause any issue when putting it back together.
It should be noted if you do a mirror tap, even after you shutdown and lock your M3/M4 - G80/G82 the power for the detector will remain on for about 5 minutes before it shuts off unless you manually power it down, but it does turn off and hopefully doesn't drain the battery. The computer will let you know if there are any unusual battery drains, at least it does on my E93 M3 with the same tap and mount. If you are a little handy and want a clean install, I say go for it. Negative is the left most brown on the big connect and 12V positive is the red/pink on the far right of the big connect if you are interested. |
05-07-2021, 12:33 PM | #322 | |
Rep 3,292
05-07-2021, 04:29 PM | #323 |
///MFlight Member
454
Rep 246
Yeap, recommended break-in is at 1,200 miles or 1,600km. I got mine done right at 1,108. I noticed that I now have more power. It feels like it was "unlocked" from having 100% power. It definitely wants to really get up and go now when I hit the gas. The exhaust does sound a little better but it's not night and day difference.
05-08-2021, 12:44 AM | #324 |
///M3
187
Rep 138
Spent 4 years up in Geilenkirchen and racked up 56 laps on the 'Ring in my E46 and later E92 M3s. Enjoy!
JB E46 M3/AW E92 M3 ZCP/AW F80 M3/SG G80 M3C
05-08-2021, 04:57 PM | #325 |
Rep 290
Got a complimentary touch-up car wash from my detailer after the ceramic coat. Gotta say. Love that booty:
05-08-2021, 06:56 PM | #326 |
Rep 1,383
Bahamut709.50 Sedan_Clan25118.50 |
05-08-2021, 08:14 PM | #327 |
Rep 290
Yes it is! Such a dynamic color and get compliments on it quite a lot as well
05-08-2021, 11:14 PM | #329 |
Rep 1,497
Great colour the gold flake is the best part.
2022-G80 Xdrive BG
2014-GTR BE FBO 2016-HURACAN 610-4 (SOLD) 2021-G82 BASE (SOLD) |
05-08-2021, 11:19 PM | #330 |
Potato peeler
542
Rep 208
Waiting to run into your car in Waipio. 😉
2021 Brooklyn Grey G80 M3
2015 Mineral Grey F80 M3 | 2014 Glacier Silver F30 335i M-Sport | 2006 Jet Black E46 M3 | 1999 Arctic Silver E36 M3 |
