01-09-2022, 12:17 PM | #23 |
Rep 7,009
The US version of the Laser Lights in dumbed down from the European Spec. Antidazzle is disabled, and the beam doesn't project near as far as those in the EU. I believe the US cars Project 600 meters, and the EU Project 900 meters.
YT: G Dubyou |
jimbethesda1865.00 |
01-09-2022, 12:19 PM | #24 |
Rep 2,311
Via software, correct? Or are the lights themselves different?
2001 330Ci (sold)
Limegrntaln13605.50 |
01-09-2022, 12:22 PM | #25 | |
Rep 7,009
YT: G Dubyou |
01-09-2022, 12:23 PM | #26 | ||
Rep 2,311
Almaretto Is this part of your coding? Or only the anti-dazzle part?
2001 330Ci (sold)
01-09-2022, 12:25 PM | #27 | |||
Rep 7,009
YT: G Dubyou |
01-09-2022, 01:12 PM | #28 | |||
Luxury at the redline :)
9108
Rep 7,563
I remember reading that BMW was able to make an endrun around the draconian US lighting laws to allow high-output laser high beams because the logic behind this was it only operated at higher speeds and in limited conditions, with assistence from a camera, so it was specifcally exempt from being typically nutured. The only difference is the US lights can't operate as indvidual beams (Anti-dazzle), which is only restricted by software. . |
01-09-2022, 01:21 PM | #29 | ||||
Rep 2,311
Maybe someone who has done anti-dazzle coding can chime in if there appears to be a brightness configuration setting that is set to a lower value in the US.
2001 330Ci (sold)
01-09-2022, 01:38 PM | #30 | |
9177
Rep 7,736
Current: 2023 Santorini Blue ///M8 ||| 2023 X3 M40 --> 2025 X5 M60 (ordered)
01-09-2022, 03:03 PM | #31 |
Rep 98
I like the laser lights because when I high beam people going to slow they definitely get the idea.
15 F82 M4 (sold)
16 F80 M3 (sold) 20 F90 35 Jahre 22 G80 M3 XDrive |
01-09-2022, 04:14 PM | #32 |
Rep 1,109
Not one mention of the fact that….headlight output aside, the daytime running lights look WAY better with the Laser option. That's reason enough (in my opinion) to get them.
chicagofan0019278.00 BardG212.50 |
01-09-2022, 04:31 PM | #33 |
Rep 609
The fact is they are the best brights available in the US. Whether they are as good as they could be, they are far superior to LED/HID, et al. I got them in the Executive package and glad I did. Noticeable improvement on unlit country roads.
BardG212.50 |
01-09-2022, 10:46 PM | #34 | ||
Rep 2,699
Drives: 23 X5MC
01-10-2022, 02:11 PM | #35 | |
Rep 14,141
Drives: G82 M4C X-Drive
01-10-2022, 02:51 PM | #36 |
mt4life
641
Rep 420
01-10-2022, 07:50 PM | #37 | ||
Rep 1,109
01-10-2022, 08:36 PM | #38 | |||
Rep 14,141
Clever girl.
01-11-2022, 08:18 AM | #39 |
Rep 2,030
Drives: G80 M3 Competition
I'm another for laser lights even if it's just for the DRLs. Really finishes the look.
01-11-2022, 04:24 PM | #41 | |
9108
Rep 7,563
What you are seeing when you operate the high-beam stalk is regular LED high-beam output, as you would get with the standard, non-laser G8X headlights. The laser light technology acts as an ancillary portion of the overall high-beam lighting, not a replacement to conventional LEDs. . |
01-12-2022, 04:07 PM | #42 |
Rep 72
Does anyone in the US market have video of anti-dazzle after recoding? I'd love to be able to add this functionality back as the lights were intended to work.
From what I remember some F8x drivers were not able to get it to work correctly even after redoing the code
G80 M3, BG 6MT
Chevy Colorado ZR2 718 Cayman S |
01-13-2022, 02:02 AM | #43 | |
9108
Rep 7,563
This dude below had the most accurate representation of Anti-Dazzle I've seen on a US-spec vehicle, in which this feature was recoded. Notice how the light beam pattern output on the vehicle ahead is eclipsed or "tunnels," so glaring light isn't cast into the upcoming driver's line of sight. Each headlight (left/right) independently moves vertically, horizontally or shutters, allowing the high beam or beamS to stay on even when other cars are present. This was really impressive, considering that the driver was traveling in a city setting, with tons of congestion, street lights and signs, which in my experience, causes the camera to typically be fooled by the reflectiveness but his seemed to work really well. View post on imgur.com https://www.bimmerpost.com/forums/sh...php?p=25722934 |
01-13-2022, 10:58 AM | #44 | |
Rep 72
G80 M3, BG 6MT
Poochie9107.50 |
