11-02-2022, 03:39 AM | #111 | |||
Rep 6,962
I would start a new thread to get more traction to it.
YT: G Dubyou |
11-02-2022, 04:18 AM | #112 | ||||
Rep 316
11-02-2022, 04:25 AM | #113 |
Rep 6,962
Did you watch the video on post 27?
YT: G Dubyou |
11-02-2022, 04:35 AM | #114 |
Rep 316
Yup I did and everything was pretty simple except for not getting any power. The ground tap works fine because I confirmed it with my volt meter. The red/blue tap reads zero for volts. I even tried different sized taps that I got from blendmount and none of them gave a reading.
11-02-2022, 04:47 AM | #115 | |
Rep 6,962
It looks like you're going to be the guineapig. Best thing to do is find the power with the meter. Checking some other threads, it seems people have found some wiring differences in the model years. https://g80.bimmerpost.com/forums/sh....php?t=1958562
YT: G Dubyou |
emargul204.50 |
11-02-2022, 04:53 AM | #116 | ||
Rep 316
I started the other thread. I am hoping to figure out what the big mirror connector does just to make sure this isn't a my car issue vs. an "LCI" difference. If I can find out what it does and make sure that function of the car/mirror works then it will rule out a my car issue. |
Limegrntaln13476.00 |
11-02-2022, 04:58 AM | #117 | |
Rep 6,962
It sounds like if there are 4 pins in that plug, and the only one that's changed, was red/green from red/blue, that, that would be the red/green wire would be the power wire that replaced the red/blue in the 2023 model.
YT: G Dubyou |
11-02-2022, 05:12 AM | #118 | ||
Rep 316
The small connector with the red/green wire all the way on the right is where I found the constant 12v. It has 3 pins on it. The big connector right below with the 4 pins I can't get any power from. |
11-02-2022, 11:16 AM | #119 | |
Rep 6,962
YT: G Dubyou |
emargul204.50 |
11-02-2022, 03:22 PM | #120 | ||
Rep 316
11-02-2022, 04:16 PM | #121 | |||
Rep 6,962
Good work. Saves people a lot of headache. Make sure you keep your other thread open, and just make updates, so, people can have a place to go to for the 23 model years.
YT: G Dubyou |
emargul204.50 |
11-03-2022, 05:08 AM | #122 | ||||
Rep 316
11-04-2022, 01:25 AM | #123 | |||||
Rep 6,962
YT: G Dubyou |
emargul204.50 |
11-27-2022, 02:26 PM | #124 |
Rep 3,995
Knocked this out today using Posi-Lock taps.
Popping off the mirror makes this 1000% easier. For all you Uniden peeps, this 3 suction cup mount is awesome. https://www.ebay.com/itm/185449408753
01-02-2023, 01:27 PM | #125 |
Rep 100
2023 M3 Competition with the driving assistance and park assistance packages here. This i4 video on the mirror tap has the exact same mirror which was pretty helpful in case anybody is interested. I also used the second smallest set of the BlendMount taps.
https://youtu.be/qN5ImEMEYIg |
emargul204.50 kgelfen3602217.00 |
02-02-2023, 09:28 AM | #126 |
Rep 110
I've seen people tap the black connector like the video posted early on in this thread. I've seen other videos tapping into the pink connector.
Is there a difference either connector to tap into?? |
02-02-2023, 09:39 AM | #127 | |
Rep 50
I have ‘23 g80 m3c. |
T0RM3NT3642.00 |
02-02-2023, 09:42 AM | #128 | |
Rep 56
I tapped into the red/pink one. I think I have a blown fuse on the black connector. Mines a 2023. I did an hour test to see if the detector would power off. Looked inside and it wasn't on. Going to see about the blown fuse tho and possibly put it in the black connector later. If thats the problem |
02-02-2023, 02:39 PM | #129 | ||
Rep 110
Just finished. It was SUPER simple. Took less than 3 mins, used a trim stick, stuck in the red/black into the black connector, two zip ties around the connection points and upper wire area with the cloth. I debated getting the blendmount, the OEM rubber mount from the UNIDEN R3 works fine. I wanted the radar to be on the right side of the mirror too, not directly under.
Bryantbjb52.00 |
02-04-2023, 07:04 PM | #130 |
Rep 217
Drives: 2023 M3 Comp Xdrive
Definitely harder than my f80 mirror tap.
I used the blendmount wire. There are 4 sizes. I used the second smallest connectors. If you try to put the bigger ones in they require too much force and bend. Definitely use needle nose pliers to remove the plug. I have driver assistant professional so this link was helpful in removing the plastic cover. Also, I have idrive 8. https://youtu.be/qN5ImEMEYIg |
MMM.PWR3452.00 |
03-11-2023, 11:30 PM | #131 |
Rep 21
