      03-14-2024, 08:41 AM   #1
stark_c
Drives: 2022 6MT G82
Clunk from the rear when accelerate after coasting (G82 6MT)
Hello! The car has 22k miles on it, it is a manual 2022 M4. I have been feeling a clunk (clunk/jerk/slight jolt) from the rear end of my car when I press the gas after coasting in gear. There is only one clunk each time. (let off gass to coast in gear -> wait x seconds -> press gas pedal -> clunk).
It happens in the 5th gear almost 100% of the time. It does not happen in lower gears; it is more pronounced in higher gears. It does not happen when I resume throttle immediately after I let off either.
Has anyone experienced this before?
      03-15-2024, 08:55 AM   #2
Krisp97
Krisp97's Avatar
Drives: 23 M3Cx
I can't say I have felt anything alarming but there is a degree of normalcy regarding a bit of drivetrain "slop"
If it feels alarming or above normal levels of slop I would take it in while its still warranted
2023 M3 Competition xDrive, Alpine White with Full Fjord Blue/Black interior
2022 Acura TLX Type S, Tiger Eye Pearl with Orchid White interior (traded in)
2019 Subaru WRX STi, Ice Silver (traded in)
2017 Ford Focus ST, Oxford White (traded in)
      03-15-2024, 02:53 PM   #3
Forzanerazzurri
6918
Drives: E46 M3 Coupe/G80 M3CX
      03-16-2024, 08:09 PM   #4
shwayne5
shwayne5's Avatar
Drives: BMW M3 G80 RWD
Are you able to put it on a lift and shift from reverse to drive to see if you can reproduce? Could be a failed bushing in the diff bracket. Ask me how I know… but it wasn’t because the stock bushings failed but an aftermarket stiffer bushind did. But what your describing sounds like what I had going on
      03-16-2024, 08:15 PM   #5
stark_c
I’m don’t have access to a lift unfortunately. It’s not a terribly obvious clunk for me, more fitting description would actually be a jolt. I will ask the dealership to make a diag. Thanks for replying!
      03-19-2024, 02:00 PM   #6
dimab0
Drives: BMW M4 (G82)
I bet new differential fluid solves the issue. Takes no time for dealer to do this...
mathys202.50
