04-05-2024, 03:54 PM | #1 |
Rep 11
Dent In Carbon Buckets Head Rest
No clue if anyone else has had this issue or if it’s normal, but for some reason my driver head cushion on my bucket seats has formed somewhat of a indent, guessing from all the launches. Passenger side seems fine and looks new. Car only has 2k miles on it, any advice?
04-05-2024, 07:06 PM | #2 |
Rep 2,863
Pic available?
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
04-05-2024, 09:16 PM | #3 |
Rep 147
https://youtu.be/Ei-D8oILN8s?si=BC8QdvBiT7vK7Lup
You can remove the actual headrest part with a t25. I wonder if you can just buy that piece as a replacement, maybe check the back of it for a part number. If not try using a blow dryer to heat it up slightly till it comes back to shape? |
04-06-2024, 09:21 PM | #4 |
Rep 11
It’s near impossible to get on pics, looks basically normal. Though if you look a little hard at the image you can see on the bottom left corner that’s where the indent is.
04-06-2024, 09:22 PM | #5 | |
Rep 11
04-07-2024, 09:36 AM | #6 | ||
Rep 777
But things ‘wear’ and will never be perfect. |
