04-26-2024, 09:00 PM | #265 | |
Rep 7,002
I posted all of the part numbers in the first post. Yours should be in there.
YT: G Dubyou |
04-26-2024, 09:57 PM | #266 |
Rep 323
Drives: '24 M4 Competition xDrive
Limegrntaln13549.50 thatguyM4208.00 |
04-26-2024, 11:22 PM | #267 |
Rep 7,002
I don’t wanna crash too hard. He’s a busy man.
YT: G Dubyou |
thatguyM4208.00 |
04-28-2024, 04:31 PM | #268 |
Rep 186
Get the harness on the site so I can schedule I'm setting appointments and getting booked out ..... and we're about to release M Mode this week .... on guys with ID 7 ....ID 8 is plug and play ID 7 will need to jump.a.wire ...
Limegrntaln13549.50 |
04-28-2024, 10:52 PM | #269 |
Rep 412
G83 needs a jump wire?
04-29-2024, 06:18 AM | #270 |
Rep 551
Drives: 2022 G83 M4
G83 just needs coding if you want to have the Euro turn signals otherwise it's just plug n play and simple coding to eliminate the flicker. No jump wire needed. The convertibles are already wired up for separate turn and brake signals.
04-29-2024, 08:27 AM | #271 |
Rep 2,678
So where's the definitive resource of ordering these at this point?
04-29-2024, 09:10 AM | #272 |
Rep 186
04-29-2024, 03:18 PM | #273 |
Rep 2,380
If you have a euro spec car already (UK RHD drive) , MY23 G82 with ID7 and you get the LCI tails, does it still need a wire and coding? TIA.
04-29-2024, 04:53 PM | #274 |
Rep 7,002
Wiring, it shouldn’t because that’s the standard setup, there. Coding it probably does. It was skeptical, but it takes :30 seconds, a cell phone and an enet cable and Bimmer utility.
YT: G Dubyou |
as7920601.50 |
04-29-2024, 04:53 PM | #275 |
Rep 551
Drives: 2022 G83 M4
Only will need coding to eliminate the startup flicker. Otherwise plug-n-play
04-29-2024, 08:11 PM | #276 |
Rep 412
Thanks. Wonder if the US spec LCI taillights will need coding on a G83?
04-29-2024, 08:16 PM | #277 |
Rep 7,002
Yes, but just coding. Very easy to do, yourself. I’m going to update the original post, once I gather all of the info from the posts throughout the entire thread. But, right now, you need to enable one switch that’s disabled in the coding. Check post 256 and a few before and after.
YT: G Dubyou |
04-29-2024, 08:18 PM | #278 |
Rep 412
Thanks
04-29-2024, 08:19 PM | #279 |
Rep 7,002
You’re welcome. Part numbers to the lights you need, on the OP.
YT: G Dubyou |
04-30-2024, 09:35 AM | #280 | ||
Rep 2,380
Have someone able to do the coding for me, if above true then I may be looking to get a set pretty quickly! |
04-30-2024, 09:38 AM | #281 | |
Rep 2,380
04-30-2024, 10:21 AM | #282 | |
Rep 551
Drives: 2022 G83 M4
You only need to run wiring and do some more advanced coding if you wish to separate the turn and brake signals or if you get the euro set with amber signals like I have and separate the turn and brake. G83's only require coding irregardless of which lights you purchase as they already have the respective wiring.
04-30-2024, 02:10 PM | #283 |
Rep 186
05-01-2024, 01:09 PM | #284 |
Rep 38
I tried ordering and got my order canceled because 2 of the parts had no current fulfillment time. Mine was from bmwpartsdirect.com
Where to order? |
05-01-2024, 01:32 PM | #285 | |
Rep 2,678
We're all in waiting mode now. |
Jrsred1019.50 Limegrntaln13549.50 |
